no clue what is going on. everything's been fine for 4 days and then today this...see attached.
re-calibrated both sensors, no help.
my refrac says the water is 1.026...
SAL readings going crazy, PH now off
bencollinz
Re: SAL readings going crazy, PH now off
What happens when you place the probe in a cup with tank water?
bencollinz
it's declining still but now it's steady.rimai wrote:What happens when you place the probe in a cup with tank water?
That looks like you got some sort of stray voltage.
Can you double check you pumps and float switches?
bencollinz
this started when I added the water level expansion.rimai wrote:That looks like you got some sort of stray voltage.
I don't have any float switches in there yet. I unplugged everything including return pump and got this...
Strange...
What happens if you disconnect the water level?
bencollinz
I unplugged everything except the SAL, including temp and PH and now it says SAL is 6ppt.rimai wrote:Strange...
If I put the probe in the calibration fluid it's 6ppt as well.
what the heck should I try next?
I rebooted as well, no change.
Is the salinity module connected straight into the relay box?
bencollinz
so, to sum up all my troubleshooting, one word, microbubbles. thank you for your help!
moved the sensors to a different part of my sump and all is grand now.
