https://github.com/reefangel/Libraries/issues/71
Basically, it is not http authentication as we were originally trying.
It's actually using the portal key as authentication.
I need people to test it.
My initial tests worked fine.
Here is how it will work.
You must use the Portal function with a key in your code. Example:
ReefAngel.Portal("reefangel","mysecretkey");
http://ipaddress:2000/?key=mysecretkey
http://ipaddress:2000/r99?key=mysecretkey
If you fail to provide the correct key, the controller will simply display "Invalid Key".
We will need the apps to be updated for this to work with the key.
