My code - now with RAnet
Re: My code
Are you sure you uploaded this code?
It says timeout is 600 seconds. Was your ATO pump on for 600 seconds before it turned the red led again?
bencollinz
Re: My code
Post by bencollinz »
rimai wrote:Are you sure you uploaded this code?
yes, that is the current code.
the red light comes on after 10 mins every time I 'clear ATO' from menu, regardless of the port running or not.
The port did turn itself off at the proper % finally, though.
Re: My code
So, you are getting ato timeout even when the port is supposed to be off?
You are not overriding it off, are you?
If you do, it would definitely timeout.
bencollinz
Re: My code
rimai wrote:So, you are getting ato timeout even when the port is supposed to be off?
so, for example, right now, the red light is on. i'll 'clear ato', the water is at 56%, so the port turned on for ATO, the red light came back on ~1-2 mins, i 'clear ato' (the port still on all the while), the port shuts off at 60%.
it's on auto via portal or reboot, not changing to off.
bencollinz
Re: My code
and now the red light is on again. ~10 mins after I last pressed 'clear ato'
cleared it again, got it ~2 mins later
Re: My code
I think you found a bug :)
Can you disconnect the ATO Low float switch and see if the problem is fixed?
bencollinz
Re: My code
rimai wrote:I think you found a bug :)
I unplugged that, rebooted RA, let it sit for 20 mins and now my return pump port 2 just shut off.
but that was also the first time i set port 2 to auto instead of on.
bencollinz
Re: My code
the ATO pump went on and off just as it should without the float switch! and no red light to clear.
Re: My code
Yeah, just what thought.
The libraries code is sharing the part of the code with the low float switch.
I'll have to update it.
Should be fixed in the next update.
In the mean time, you can use the high ato port for your return.
Re: My code
bencollinz
Re: My code
just wanted to say the ATO pump went on/off as it should through the nite and it only takes ~1 min for it to go from 58% to 60%. no red light. I did not reconnect float switch yet.
My code
Awesome!
bencollinz
Re: My code
added floatswitch back with HighATO
    #define Heater      1
    #define Return      2
    #define Skimmer     3
    #define Vortech1    5
    #define Vortech2    6
    #define ATO         7
byte vtechmode;
        ReefAngel.FeedingModePorts = Port4Bit | Port5Bit | Port6Bit;
        ReefAngel.WaterChangePorts = Port7Bit | Port4Bit | Port5Bit | Port6Bit;
        ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port7Bit | Port4Bit | Port5Bit | Port6Bit;
        ReefAngel.Relay.On( Port2 );
	// Hardcode calibrations
	ReefAngel.PHMin=576; // PH7.0
	ReefAngel.PHMax=842; // PH10.0
        ReefAngel.SalMax=3000; // 35ppt
        ReefAngel.StandardHeater( Port1,796,802 );
        ReefAngel.WaterLevelATO( Port7,180,58,60 );
        // If water level less than 58, turn on auto top off relay; else, keep it off
            // if (ReefAngel.WaterLevel.GetLevel()<58) ReefAngel.Relay.On(Port7);
             // else ReefAngel.Relay.Off(Port7);
        ReefAngel.PWM.SetChannel( 0, MoonPhase() );
        ReefAngel.PWM.Channel1PWMParabola();
        ReefAngel.PWM.Channel2PWMParabola();
        ReefAngel.PWM.Channel3PWMParabola();
        ReefAngel.PWM.Channel4PWMSlope();
        // ReefAngel.SingleATOLow(Port2);
        if ( ReefAngel.HighATO.IsActive())
          ReefAngel.Relay.On(Port2);
          ReefAngel.Relay.Off(Port2);
        if (hour() <= 8 && hour() >= 20)
            ReefAngel.RF.UseMemory=false;
            vtechmode = 9;
             ReefAngel.RF.UseMemory=true;
             vtechmode = InternalMemory.RFMode_read();
        ReefAngel.Portal( "bencollinz" );
      char text[7];
        // Date and Time
        ReefAngel.LCD.DrawDate( 6, 2 );
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 6, 90, "--------------------");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 6, 126, "--------------------");
  for (byte Left=93; Left < 133; Left+=10)
    ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, Left, "|");
    ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, Left, "|");
 ReefAngel.LCD.DrawText(0,255,18,12,"EcoSmart Vortech");
  ReefAngel.LCD.Clear(255, 1, 19, 128, 29);
  if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,21,"Constant");
  else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,21,"Lagoon");
  else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,21,"Reef Crest");
  else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,21,"Short Pulse");
  else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,21,"Long Pulse");
  else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,21,"Nutrient Trnsp.");
  else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,21,"Tidal Swell");
  else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,45,21,"Night");
  ReefAngel.LCD.DrawText(0,255,10,30,"Temp");
  ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 10, 40, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,100,30,"pH");
  ReefAngel.LCD.DrawLargeText(COLOR_PLUM, 255, 85, 40, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,43,48,"Salinity");
  ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN, 255, 49, 58, text, Num8x8);
          // Main Relay Box
        ReefAngel.LCD.DrawOutletBox( 12, 77, TempRelay );
// water level
    ReefAngel.LCD.DrawText(0,255,8,68,"WL:");
    ReefAngel.LCD.DrawText( COLOR_CORNFLOWERBLUE,255, 40, 68, ReefAngel.WaterLevel.GetLevel() );
so far it's good.
had to use this code to get my RF working
    //#define Constant      0
    //#define Random1       1 // Lagoonal
    //#define Random2       2 // Reef Crest
    //#define ShortWave     3
    //#define LongWave      4
    //#define Smart_NTM     5 // Nutrient Transport Mode
    //#define Smart_TSM     6 // Tidal Swell Mode
    //#define Feeding_Start 7
    //#define Feeding_Stop  8
    //#define Night         9
    //#define Slave_Start   97
    //#define Slave_Stop    98
    //#define None          99
      ReefAngel.LCD.DrawText(0,255,20,50,"Assigning Slaves");
      ReefAngel.RF.SendData(Slave_Start,0,0);
      InternalMemory.RFMode_write(0);
      InternalMemory.RFSpeed_write(128);
      ReefAngel.Refresh();
      if (ReefAngel.Joystick.IsButtonPressed())
        ReefAngel.RF.SendData(Slave_Stop,0,0);
        ReefAngel.LCD.DrawText(0,255,50,60,"Done");
bencollinz
Re: My code
so my vortechs are always stuck in night mode
    #define Heater      1
    #define Return      2
    #define Skimmer     3
    #define Vortech1    5
    #define Vortech2    6
    #define ATO         7
byte vtechmode;
        ReefAngel.WaterLevelATO( Port7,120,58,60 );
        ReefAngel.PWM.Channel1PWMSlope();
        ReefAngel.PWM.Channel2PWMSlope();
        ReefAngel.PWM.Channel3PWMSlope();
        if (hour() >=8 && hour() < 20)
             ReefAngel.RF.SetMode(Feeding_Stop,0,0); //Temp fix for coming out of Night mode
      char text[7];
        // Date and Time
          // Main Relay Box
// water level
what do I need to change?
Re: My code
First off, it looks like your Night mode is set to go during the day. Can you check and see if during the night before 8am and after 8pm if you are still in Night mode.
This bit is what says what time... right now it says greater than 8am and before 8pm be in Night mode..
This bit says when not in night mode to use Memory. Can you confirm what values you have set in the portal for your Vortechs
As I said, it looks like your in Night mode during the day...
bencollinz
Re: My code
lnevo wrote:First off, it looks like your Night mode is set to go during the day. Can you check and see if during the night before 8am and after 8pm if you are still in Night mode.
so this instead?
            if (hour() <=8 && hour() > 20)
portal is set to tidal swell. RA display shows "night" and RF is breathing white.
Re: My code
Yep, you have the time right now. Give it a try.
Re: My code
Actually that condition would never happen.
Try this:
    if (ReefAngel.RF.Mode==Night) ReefAngel.RF.SetMode(Feeding_Stop,0,0);
Re: My code
Good catch. Can't believe I missed that... the other option is to just change the && to ||
bencollinz
Re: My code
rimai wrote:Actually that condition would never happen.
Try this:
thank you very much!!
this did it!
bencollinz
Re: My code
oh my god. I just can't win. port 1 on my relay box is not working now. you can hear the relay clicking when you change it from off/on or on/off via portal or android but no power is coming from the outlet.
bencollinz
Re: My code
I ran the controller tester sketch as well and that confirms port one doesn't work. what else can I try?
had to move my heater to port 3.
bencollinz
Re: My code
how do I code temp probe 2 to turn on port 3 at 76 and off at 77?
it's for a second tank.
My code
StandardHeater(Port3,76,77);
Oh wait..you need it for probe 2...one minute..
My code
void StandardHeater2(byte HeaterRelay, int LowTemp, int HighTemp)
if (ReefAngel.Params.Temp[T2_PROBE] == 0) return; // Don't turn the heater on if the temp is reading 0
if (ReefAngel.Params.Temp[T2_PROBE] <= LowTemp && ReefAngel.Params.Temp[T2_PROBE] > 0) ReefAngel.Relay.On(HeaterRelay); // If sensor 2 temperature <= LowTemp - turn on heater
if (ReefAngel.Params.Temp[T2_PROBE] >= HighTemp) ReefAngel.Relay.Off(HeaterRelay); // If sensor 2 temperature >= HighTemp - turn off heater
bencollinz
Re: My code
lnevo wrote:void StandardHeater2(byte HeaterRelay, int LowTemp, int HighTemp)
will try this, thank you!
bencollinz
Re: My code
sorry for stupid question: where do I put this in my code?
    #define Heater      1
    #define Return      2
    #define Skimmer     3
    #define Vortech1    5
    #define Vortech2    6
    #define ATO         7
byte vtechmode;
        ReefAngel.WaterLevelATO( Port7,120,58,60 );   // If water level less than 58, turn on auto top off relay; else, keep it off
        ReefAngel.PWM.SetChannel( 0,PWMSlope(21,30,8,0,15,31,10,15) );
  if (hour() >=8 && hour() < 21)
    ReefAngel.Relay.Off(Port8);
    ReefAngel.Relay.On(Port8);
      char text[7];
        // Date and Time
          // Main Relay Box
// water level
enigma32
Re: My code
Post by enigma32 »
You can put that block ("void StandardHeater2(byte HeaterRelay, int LowTemp, int HighTemp) ......") at the bottom of your file, beneath:
And you'll need to call the new function from within your loop, probably on the line after:
like:
StandardHeater2( Port3, 76, 77 );
^^^ I'm not sure about the range of the temperatures there. (i.e., should it be in "degrees F" or "degrees F times 10" ?)
FYI, I happened to run across this in the ReefAngel class:
OverheatProbe = T2_PROBE;
Not sure if that would be a problem for running a second tank? lnevo, did you take this into account?
In the end, I'd say something like:
        #define Heater      1
        #define Return      2
        #define Skimmer     3
        #define Vortech1    5
        #define Vortech2    6
        #define ATO         7
    byte vtechmode;
            StandardHeater2( Port3, 76, 77 ); // YOU SHOULD VERIFY THE TEMPERATURE VALUES HERE... I'M BASING THIS ON OTHER POSTS FROM THE FORUM.
          char text[7];
            // Date and Time
              // Main Relay Box
    // water level
                        ReefAngel.Relay.Off(HeaterRelay); // If sensor temperature >= HighTemp - turn off heater
Current setup:
60g 24" custom cube (fish and softies right now)
AI Sol Blue, Ecotech MP-10wES
Coralife skimmer
100% customer controller, transitioning to ReefAngel
My code
Overheat probe can be set to whatever...and yes the values are temp times 10...
So 77.5 would be 775.
Lee
My code
Lee
