PH calibration using 4 - 7 solutions
Graham2212
Good day all. I'm a complete newby to marine aquariums (my first tank has been running for almost 3 months now). Just received my new Reef Angel. Can anyone help with the calibration of the PH probe? I have managed to get hold of solutions 4 and 7 (not the recommended 7 and 10). I believe that I can still perform the calibration with these solutions, but that there needs to be a change in the config code? Can anyone provide me with this code adjustment? Much appreciated!!
Sebyte
Re: PH calibration using 4 - 7 solutions
Take a look at http://forum.reefangel.com/viewtopic.ph ... d&start=10
Roberto explains the calculation when using 4 & 7 calibration fluids.
Graham2212
Thanks very much for the values to use. Where do I go on the programme to make these adjustments (to the configuration code I believe) - (feeling a bit overwhelmed at the moment)?
Try this method:
http://forum.reefangel.com/viewtopic.php?t=2246
Graham2212
How do I navigate to the setup() section of my code?
Graham2212
ReefAngel.PHMin=217;
ReefAngel.PHMax=512;
ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit;
InternalMemory.OverheatTemp_write( 290 );
ReefAngel.StandardATO( Port1,50 );
ReefAngel.WavemakerRandom1(Port5,15,60); // Turn Port5 on/off random cycles that lasts from 15 to 60 secs
ReefAngel.WavemakerRandom2(Port6,15,60); // Turn Port6 on/off random cycles that lasts from 15 to 60 secs
ReefAngel.Portal( "Graham2212" );
int x,y;
// Parameters
// Salinity
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,66, "SAL:" );
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,66, ReefAngel.Params.Salinity );
// Main Relay Box
// Date and Time
Graham2212
Could you kindly let me know if I'm on the right track here?
Graham2212
Thanks very much for your help? Would you be able to possibly help me with customizing my main screen? I would love a graph of temp, ph and salinity, actual values in the middle, with the relay box graphic below... do I need to create a new post?
That's how it is now, isn't it?
For custom screens, start with this post:
http://forum.reefangel.com/viewtopic.php?f=14&t=109
