Another Wifi Config Problems
I just recieved my package today and i get my code in the module. Now im trying to config the wifi adapter and with the wifi utility i get the ip and the other things. Now i tried to get coded in the module but i didnt found something. I read diferents threads about and my 2000 port its closed. what do i need? any detailed instructions? Rimai?
Did you setup your router with a port forwarding with the port as 2000
Re: Another Wifi Config Problems
i use a link in another topic to verify the port and says the 2000 port its closed
So you need to go into your router setting and set up a port forwarding when you setup your wifi unit they gave you an IP Address put that IP address in your port forwarding with the port as 2000
Is your wifi attachment blinking slow green and no blue right now?
Yeah, so your wifi attachment is already setup.
You should have the ip address from the wifi utility, right?
Go to your browser and type http://ipaddress.com:2000
Do you see "Reef Angel Controller Web Server"?
now i tried to config again and the blue blink too. i got the ip that the wifi utility gave me.
the wifi utility dont gave me an ip for the attatchment. its appears like 0.0.0.0 port 2000
You may have the wrong ssid or password.
They are case sensitive.
im using the correct ssid and password. i tried with caps and without and got the same results
i tried again and now they give me an ip address but the blue light still blinking
when i use the ssid and password with the capslock as reccomended i recieve this.
and the lights are slow green blink and the blue blinks constantly
if i use the ssid and password without the capslock then i recieve an ip and only blinks the green lights
now i get to my router to get the 2000 port open but my network dont show the attatchment connected to the network. need help.
I did not say use caps lock.
I said it is case sensitive, which means "ReefAngel" is different than "reefangel", which is different than"Reefangel" and different than "REEFANGEL".
So, you have to make sure you type both ssid and password in the same case as you have setup in your router.
other thing is i verify my network and the attatchment not shown in my network conection
ok but in my modem they are all in capslock. two different ways get different results in the wifi utility but anything works from there
What security and encryption are you using?
If you are not using WPA2-PSK with AES encryption, I recommend you try that.
rimai, i get another type of router and let me set the port fowarding and give me the ip i need. now i enter the ip to the portal setup and in my iphone app and the portal says unreacheable address and the iphone app wont connect. any other thing i need to do after that?>
the router setup give me another public ip for the rawifiatatchment, thats dont matter?
What kind of router do you have
First one was a thompson tg782 and now i use an old one 2wire 1800hg
Still without luck on this! the problem now its the modem/router config shows the rawifiatch stays inactive in the home network. any suggestion? i dont know if the problem its the router or someting.
Yes. I got IP address and follow all the steps to port forwarding and test it with ping in cmd but in the modem details shows me inactive device. That's the router or I need another thing in the controller?
Ok, so what happens when you browse http://ipaddress:2000 ??
You may want to attach the wifi unit and "reset to factory defaults" and then start the process again since you switched routers. Just a thought, I had to do that when I changed mine. Are you on a mac or a pc?
Reefcam: dansreef.swanndvr.net login: guest pw: guest
its a PC. i already do that. I reset to factory settings when change the router and with the second one let me connect the attatchment and give me a valid ip. When I enter to the modem settings, i do the steps to port fowarding like the router manual said. The modem showns the wifi attatchment inactive. Im trying to find another router to make another test because i think the problem its the router. Do i need to change anything in the code?
ok i think i got this resolved. the portal update some info but now dont let me do anything. i think i change something in the ip of the portal and iphone app. i need to assign a public ip for this device?
