JEBO WP-40
Piper
Re: JEBO WP-40
What do you have speed and duration set to in the Portal?
Paulturner911
Re: JEBO WP-40
Ive got mine up and running in ReefCrest!! In the portal it only gives you one parameter with in reefcrest, SPEED.
ReefCrestMode(50,30,false) Does this mean it will run from 20-80% ????
JEBO WP-40
Ooh good point...you can change the duration in another mode and then Switch back to reefcrest or manually change the memory location.
Paulturner911
Re: JEBO WP-40
Just happens that was what I entered 50/30 in tidal swell mode too. Am I correct in saying ReefCrestMode(50,30,false) runs my pump from 20-80%?
Paulturner911
Re: JEBO WP-40
This is what I have so far for the other mode "calls" I have no Idea on what to do other than "if mode=xxxx" So Ive changed them to the correct mode names but I dont know what to do for the coding after that. Ihave tried this with short pulse and it says "too few arguments to function" Im sure Im missing something or it has to do with boolean(I dont know what that means)?!?!?
#define Constant 0
#define Lagoon 1
#define Random1 1 // Lagoonal
#define ReefCrest 2
#define Random2 2 // Reef Crest
#define ShortPulse 3
#define ShortWave 3
#define LongPulse 4
#define LongWave 4
#define NutrientTransport 5
#define Smart_NTM 5 // Nutrient Transport Mode
#define TidalSwell 6
#define Smart_TSM 6 // Tidal Swell Mode
// Read memory for RF Wave Settings
int mode=InternalMemory.RFMode_read();
int speed=InternalMemory.RFSpeed_read();
int duration=InternalMemory.RFDuration_read();
//ReefCrest
if (mode = ReefCrest) {
ReefAngel.PWM.SetDaylight ( ReefCrestMode(50,30,false) ); // ReefCrest at 50 +/- 30 in anti-sync mode
} else {
ReefAngel.PWM.SetDaylight( speed / 2 );
//Short Pulse
if (mode=ShortPulse) {
ReefAngel.PWM.SetDaylight( ShortPulseMode(speed,duration%2) );
} else {
//Long Pulse
if (mode=LongPulse) {
ReefAngel.PWM.SetDaylight( LongPulseMode(speed,duration%2) );
} else {
//Sine
if (mode=Sine) {
ReefAngel.PWM.SetDaylight( SineMode(speed,duration%2) );
} else {
//Nutrient Trans
if (mode=NutrientTrans) {
ReefAngel.PWM.SetDaylight( NutrientTransMode(speed,duration%2) );
} else {
//Tide Mode
if (mode=Tide) {
ReefAngel.PWM.SetDaylight( TideMode(speed,duration%2) );
} else {
//Tidal Swell Call
if (mode=TidalSwell) {
ReefAngel.PWM.SetDaylight( TidalSwellMode(speed,duration%2) );
} else {
#define Constant 0
#define Lagoon 1
#define ReefCrest 2
#define ShortWave 3
#define LongPulse 4
#define LongWave 4
//ReefCrest
} else {
//Short Pulse
} else {
//Long Pulse
} else {
//Sine
if (mode=Sine) {
} else {
//Nutrient Trans
} else {
//Tide Mode
if (mode=Tide) {
} else {
//Tidal Swell Call
} else {
JEBO WP-40
Boolean is a variable type that can be true or false.
Your code on the other hand will never work as you wrote it...the first if is fine
The second if needs to be included in the first if...
Your logic currently looks like this
If color = red then shape=round else shape = square
If color = blue then shape=triangle else shape = square
So its only going to work if color = blue because if its red the second if will make the shape a square...
You want your logic to look like this
If color=red then shape=round
Else if color=blue then shape=triangle
Else shape=square
The check for your mode needs to be all connected otherwise each test is independent.
I wrote this all in pseudo code so you could understand the difference but the syntax was in one of my previous posts.
Else shape=square
Paulturner911
Re: JEBO WP-40
This is what I uploaded. The pump is ramping up and down. I was not able to tell a difference with in tidal or reefcrest really. Is this because my code needs to all be inside the first } ?
#define Constant 0
#define Lagoon 1
#define ReefCrest 2
#define ShortWave 3
#define LongPulse 4
#define LongWave 4
//ReefCrest
} else {
//Tide Mode
if (mode=Tide) {
} else {
//Tidal Swell Call
} else {
#define Constant 0
#define Lagoon 1
#define ReefCrest 2
#define ShortWave 3
#define LongPulse 4
#define LongWave 4
//ReefCrest
} else {
//Tide Mode
if (mode=Tide) {
} else {
//Tidal Swell Call
} else {
Paulturner911
Re: JEBO WP-40
Screw it! Im just going to run what was posted for reefcrest. I would like to be able to utilize the features, but I am unable to code a lick of it. I guess im going to have to live with out for a while. Ill sit back and watch to see if anyone posts something I could use.
JEBO WP-40
I just got home...i'll try and post some real code for you to try..
JEBO WP-40
You know all in all a case statement would probably have been simpler for you.
Paulturner911
Re: JEBO WP-40
LOL. NONE of it is simple for me. Its just not my bag of tea! I went with this
} else {
and removed the tidal that you had created for me. Most people tend to run reefcrest so I chose that over tidal. I really appreciate all that you guys put up with! Im sure it tests your patience sometimes.
} else {
Re: JEBO WP-40
Paul,
Here is the full code to and functions to set all the published modes so far from the RA Portal (through the Vortech interface).
Here is the seperated function and below is the full INO file. This should help everyone get started.
// Read memory for RF Wave Settings and use for Tunze/Jaebo
// Change this to what you want your min/max based on vortech speed
// This is for those functions that take both, but only one memory slot.
int minOffset=5;
int maxOffset=10;
int min=speed-minOffset;
int max=speed+maxOffset;
if (mode==Constant) {
// Constant
ReefAngel.PWM.SetDaylight( speed );
ReefAngel.PWM.SetActinic( speed );
} else if (mode==Lagoon) {
// Lagoon
ReefAngel.PWM.SetDaylight( SineMode(min,max,duration,true) );
ReefAngel.PWM.SetActinic( SineMode(min,max,duration,false) );
} else if (mode==ReefCrest) {
// Reef Crest
ReefAngel.PWM.SetDaylight( ReefCrestMode(speed,duration,true) );
ReefAngel.PWM.SetActinic( ReefCrestMode(speed,duration,false) );
} else if (mode==ShortPulse) {
// Short Pulse
ReefAngel.PWM.SetDaylight( ShortPulseMode(min,max,duration,true) );
ReefAngel.PWM.SetActinic( ShortPulseMode(min,max,duration,false) );
} else if (mode==LongPulse) {
// Long Pulse
ReefAngel.PWM.SetDaylight( LongPulseMode(min,max,duration,true) );
ReefAngel.PWM.SetActinic( LongPulseMode(min,max,duration,false) );
} else if (mode==TidalSwell) {
// Tidal Swell
ReefAngel.PWM.SetDaylight( TidalSwellMode(speed,true) );
ReefAngel.PWM.SetDaylight( TidalSwellMode(speed,false) );
} else if (mode=NutrientTransport) {
// Smart_NTM
ReefAngel.PWM.SetDaylight( NutrientTransportMode(min,max,duration,true) );
ReefAngel.PWM.SetActinic( NutrientTransportMode(min,max,duration,false) );
} else {
// Default
ReefAngel.PWM.SetDaylight( TideMode(speed,minOffset,maxOffset) );
ReefAngel.PWM.SetActinic( TideMode(speed,minOffset,maxOffset) );
ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.StandardFan( Port2 );
ReefAngel.ActinicLights( Port3 );
ReefAngel.WavemakerRandom1( Port5,180,900 );
ReefAngel.WavemakerRandom2( Port6,90,900 );
ReefAngel.DayLights( Port7 );
ReefAngel.DayLights( Port8 );
//Moonlight Phase 9pm-10am (CH4-CH5)
if ( (hour() >=10) && (hour() <21) )
ReefAngel.PWM.SetChannel( 4,(0) );
ReefAngel.PWM.SetChannel( 4, MoonPhase() );
ReefAngel.PWM.SetChannel( 5,(0) );
ReefAngel.PWM.SetChannel( 5, MoonPhase() );
//Pump Delay and Over Flow Protection
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.Off(Port1);
//ATO Protection
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.Off(Port4);
//Kalk Dose 20sec @ 8pm-12pm (every 15min)
if (hour() >=20 || hour() < 12)
ReefAngel.Relay.Set(Port4, now()%900<22);
//Feed Mode Delay on Pump
static boolean feeding=false;
static unsigned long feedingstarted = now();
if (!feeding)
feeding=true;
if (now()-feedingstarted>900)
bitSet(ReefAngel.Relay.RelayMaskOff,Port5-1);
bitSet(ReefAngel.Relay.RelayMaskOff,Port6-1);
int minOffset=5;
int maxOffset=10;
// Constant
// Lagoon
// Reef Crest
// Short Pulse
// Long Pulse
// Tidal Swell
// Smart_NTM
} else {
// Default
ReefAngel.Portal( "paulturner911" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
// Parameters
// Main Relay Box
// Date and Time
byte ShortPulseMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync)
byte tspeed=0;
PulseMinSpeed=constrain(PulseMinSpeed,30,100);
PulseMaxSpeed=constrain(PulseMaxSpeed,30,100);
tspeed=(millis()%(PulseDuration*2)<PulseDuration?PulseMinSpeed:PulseMaxSpeed);
if (PulseSync)
return tspeed;
return (tspeed==PulseMinSpeed)?PulseMaxSpeed:PulseMinSpeed;
byte LongPulseMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync)
byte tspeed=0;
tspeed=(now()%(PulseDuration*2)<PulseDuration?PulseMinSpeed:PulseMaxSpeed);
if (PulseSync)
return tspeed;
byte SineMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync) {
double x,y;
x=double(now()%(PulseDuration));
x/=PulseDuration;
x*=2.0*PI;
if (!PulseSync) x+=PI; // shift the sine wave for the right pump
y=sin(x);// y is now between -1 and 1
y+=1.0; // y is now between 0 and 2
y/=2.0; // y is now between 0 and 1
// now compute the tunze speed
y*=double(PulseMaxSpeed-PulseMinSpeed);
y+=double(PulseMinSpeed);
y+=0.5; // for proper rounding
// y is now between PulseMinSpeed and PulseMaxSpeed, constrain for safety
return constrain(byte(y),30,100);
byte ReefCrestMode(byte WaveSpeed, byte WaveOffset, boolean PulseSync)
static unsigned long lastwavemillis=millis();
static int newspeed=WaveSpeed;
if ((millis()-lastwavemillis) > 5000)
if (random(100)<50) newspeed--; else newspeed++;
newspeed=constrain(newspeed,WaveSpeed-WaveOffset,WaveSpeed+WaveOffset);
newspeed=constrain(newspeed,0,100);
if (PulseSync)
return newspeed;
return WaveSpeed-(newspeed-WaveSpeed);
byte NutrientTransportMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync)
static byte WavePhase=0;
static time_t WaveStart=0;
static byte speed=PulseMinSpeed;
static byte anti_speed=PulseMinSpeed;
if (WavePhase==0)
WavePhase++;
WaveStart=now();
else if (WavePhase==1)
if (now()-WaveStart>2700)
WavePhase++;
if ((millis()-lastwavemillis) > PulseDuration)
if (speed==PulseMinSpeed)
speed=PulseMaxSpeed;
anti_speed=PulseMaxSpeed;
else if (WavePhase==2)
if (now()-WaveStart>4500) WavePhase++;
if (now()-WaveStart<=2760)
if (now()-WaveStart<=3300)
anti_speed=PulseMaxSpeed*sin(radians(map(now()-WaveStart,3300,4500,0,180)));
else if (WavePhase==3)
if (now()-WaveStart>7200) WavePhase++;
else if (WavePhase==4)
if (now()-WaveStart>9000) WavePhase=0;
if (now()-WaveStart<=7260)
if (now()-WaveStart<=8400)
anti_speed=PulseMaxSpeed*sin(radians(map(now()-WaveStart,7200,8400,0,180)));
anti_speed=0;
if (PulseSync)
return speed;
return anti_speed;
byte TidalSwellMode(byte WaveMaxSpeed, boolean PulseSync)
static byte speed=0;
static byte anti_speed=0;
if (WavePhase==0)
WavePhase++;
WaveStart=now();
if (now()-WaveStart>900) WavePhase++;
speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,0,900,0,90))))/10;
speed+=WaveMaxSpeed/2;
anti_speed=(WaveMaxSpeed*2*sin(radians(map(now()-WaveStart,0,900,0,90))))/5;
anti_speed+=WaveMaxSpeed/2;
if (now()-WaveStart>1800) WavePhase++;
speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,900,1800,90,180))))/20;
speed+=WaveMaxSpeed/20;
anti_speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,900,1800,90,180))))/20;
anti_speed+=WaveMaxSpeed/4;
if (now()-WaveStart>2700) WavePhase++;
speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,1800,2700,0,90))))/20;
anti_speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,1800,2700,0,90))))/20;
if (now()-WaveStart>3600) WavePhase++;
speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,2700,3600,90,180))))/20;
speed+=(WaveMaxSpeed*3)/20;
anti_speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,2700,3600,90,180))))/20;
anti_speed+=(WaveMaxSpeed*3)/20;
else if (WavePhase==5)
speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,3600,4500,0,90))))/20;
anti_speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,3600,4500,0,90))))/20;
else if (WavePhase==6)
if (now()-WaveStart>5400) WavePhase++;
speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,4500,5400,90,180))))/20;
speed+=(WaveMaxSpeed*5)/20;
anti_speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,4500,5400,90,180))))/20;
anti_speed+=WaveMaxSpeed/20;
else if (WavePhase==7)
if (now()-WaveStart>6300) WavePhase++;
speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,5400,6300,0,90))))/20;
anti_speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,5400,6300,0,90))))/20;
else if (WavePhase==8)
speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,6300,7200,90,180))))/20;
speed+=(WaveMaxSpeed*7)/20;
anti_speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,6300,7200,90,180))))/10;
else if (WavePhase==9)
if (now()-WaveStart>8100) WavePhase++;
speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,7200,8100,0,90))))/20;
anti_speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,7200,8100,0,90))))/2;
else if (WavePhase==10)
speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,8100,9000,90,180))))/2;
anti_speed=speed;
if (PulseSync)
return speed;
return anti_speed;
byte TideMode(byte WaveSpeed, byte minOffset, byte maxOffset)
// Contribution of lnevo
double moonOffset; // gap between high and low
double amplitude; // tide curve
double wavelength=12*SECS_PER_HOUR;
// Calculate the gap between high and low tide based on MoonPhase()
moonOffset=cos(((2*PI)/100)*MoonPhase());
moonOffset=((moonOffset+1)/2)*100; // Convert to percentage
// Find out the current tidal height
amplitude=sin(((2*PI)/wavelength)*now());
moonOffset=map(moonOffset,0,100,minOffset,maxOffset);
amplitude=amplitude*moonOffset;
// Adjust the calculate speed to be in our adjusted range
return constrain(WaveSpeed+amplitude,0,100);
Re: JEBO WP-40
In order to get to my TideMode you'll need to go to the memory location and set it to 11. That one current has no anti-sync. I'll see if I can come up with one. Comment out the code for the Actinic's forgot to mention that.
topjimmy
Re: JEBO WP-40
lnevo wrote:You know all in all a case statement would probably have been simpler for you.
Re: JEBO WP-40
Also keep in mind the function above does nothing and will not work if you have some statement elsewhere to handle feeding mode. If you want feeding mode, night mode, or anything else to override the "vortech" mode you will need to add it into the if at the beginning.
Paulturner911
Re: JEBO WP-40
It's byte size.
From Globals.h file:
#define Mem_B_RFMode VarsStart+55
Paulturner911
Re: JEBO WP-40
Thank You, I looked at mi255 and it was a four digit number.....So I waited for your reply.
Paulturner911
Re: JEBO WP-40
rimai wrote:It's byte size.
From Globals.h file:Code: Select all
I see its a definition, I see where I had others...
Lee had a comment block full of definitions on my previous code.
They are no longer in the recent code he posted this morning.
What does this do? Would it also go in the custom code are?
Last edited by Paulturner911 on Mon Apr 01, 2013 11:50 am, edited 1 time in total.
Re: JEBO WP-40
Open Globals.h file and you will see all the internal memory table.
It starts at 200.
It starts at 200.
- cosmith71
Re: JEBO WP-40
Can someone summarize the benefits of using RA to control this pump vs the stock controller? I tried to read through this thread, but it made my head hurt.
Paulturner911
Re: JEBO WP-40
For me it freed up 2 relays (1 is back to being my frag light down below)
It also is just cool to be able to use the portal and change the mode. Granted it will be on reefcrest 90% of the time, long pluse is great to stir up some junk
Im loving it! RA is a sleeper on the market. If people knew more about the people willing to help on here....well Lee and Roberto would have to get clones!
Re: JEBO WP-40
Full control, integration with feeding, water change, night modes. custom modes. sky is the limit.
Piper
Re: JEBO WP-40
You certainly don't need to run it via the RA but as the others already mentioned it's all about the controllability. The WP-40 at 100% speed was too much for my tank. I run it at ~80% with the RA and it's fine. I also want to do my own night modes and integrate it with my feeding mode.cosmith71 wrote:Can someone summarize the benefits of using RA to control this pump vs the stock controller? I tried to read through this thread, but it made my head hurt.![]()
~Charlie
- cosmith71
Re: JEBO WP-40
Thanks, guys. I think I'll go with a variable power supply until I get some extra cash for a dimmer expansion and the cable. Too many projects going right now!
It's definitely a cool add-on, though.
- cosmith71
Re: JEBO WP-40
By the way, the supplier whom I'm not allowed to name has the WP-40's on sale for 10% off until 4/4/13. The only catch is that it's a Chinese holiday and nothing ships until 4/5/13. Still a good deal, though.
Edit: It's Fish-Street. System wouldn't let me post the URL, probably cause I'm a noob.
