Hi,
I have the Reef Angel basic and I would like to add the ORP to it. What exactly would I need to buy? Do I need to buy any expension or just the ORP module and the probe?
Will there be enough memory on the RA basic to support such module?
What do I need to get the ORP?
daniella3d
Re: What do I need to get the ORP?
No, all I have right now is the standard stuff. One PH probe, 2 temp probes, and the wifi module, that's it.
You don't need the expansion hub at this time then. All you need is the module.
daniella3d
Ok thanks. I just saw that the module come with a probe, so I all will need to order then is the module.
How long is the cable for the probe? do I need to order an extension or special cable?
About 3 feet. There is also extension cable if you need.
daniella3d
yes guess I will need the extension cable because 3 feet is too short.
I will also need to find the solution for calibration, not an easy task from what I can see.
