Newbie - Need HELP
Express Reef
Newbie - Need HELP
Post by Express Reef »
Hi All,
Got my Reef Angel tried to load the code via the app now I`m getting an error message No Internal Memory Found??? :?: Is it broken now???
Newbie - Need HELP
You need to load the initialize memory sketch first
Express Reef
Re: Newbie - Need HELP
Thanx dude got it to work :P now just to get the wifi to work :roll:
Express Reef
What can be wrong? My lights off mode on the RA controller does not work...
Express Reef
Here is my code... but lights on/off does not work???
ReefAngel.AddStandardMenu();
ReefAngel.LightsOnPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit; // Turn on/off Ports 1 and 2 and 3 and 4 when Light On/Off menu option is selected
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port6Bit;
InternalMemory.OverheatTemp_write( 300 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardLights( Port1,9,15,18,15 ); // Actinic Lights
ReefAngel.StandardLights( Port2,9,45,18,15 ); // Daylight Lights
ReefAngel.StandardLights( Port3,10,15,19,45 ); // Actinic Lights
ReefAngel.StandardLights( Port4,10,45,17,45 ); // Daylight Lights
ReefAngel.StandardFan( Port5,260,265 );
ReefAngel.StandardHeater( Port6,255,260 );
ReefAngel.Portal( "Express Reef" );
ReefAngel.ShowInterface(); // Display everything on the LCD screen
