Hi All
Can anyone tell me if its normal for the PH calibration to reset itself each time I upload / make an adjustment to my code, or when my wi-fi unit is disconnected and reconnected (which I have resorted to doing every 3rd day due to connection being lost)?
PH calibration resets after each upload
Graham2212
Re: PH calibration resets after each upload
Are you using hard code calibration?
Can you post your code?
Graham2212
Thanks very much for your help again! I'm not sure if it's hard coded - still trying to get used to RA... Can you tell me?
ReefAngel.PHMin=217;
ReefAngel.PHMax=512;
ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit;
InternalMemory.OverheatTemp_write( 290 );
ReefAngel.StandardATO( Port1,600 );
ReefAngel.WavemakerRandom1( Port5,15,60 );
ReefAngel.WavemakerRandom2( Port6,15,60 );
ReefAngel.Portal( "Graham2212" );
int x,y;
// Salinity
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,66, "SAL:" );
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,66, ReefAngel.Params.Salinity );
Graham2212
BTW, I'm using PH solutions of 4 and 7 to do my calibration, and therefore the reason for the calibration manipulation...
These lines will always be used by the controller:
That's what I meant with hard coded.
You have to remove them to use the calibration numbers stored in the memory or you can simply use the numbers you acquired while doing the calibration.
Graham2212
Ok, (excuse the stupid questions)... So if i remove these lines, i will still be able to (based on my code), have the option to calibrate with a 4 and 7 ph solution?
Graham2212
Thank you very much for all your help! I really appreciate it!
