external lcd screen
cm1981
external lcd screen
Post by cm1981 »
Is there a way to attach a different lcd screen considering how small the one on the controller is. If so, whats the easiest way of doing this. I don't want anything crazy. Just want a bigger screen to view whats on the controller screen.
Re: external lcd screen
As long as your screen works on 3-wire SPI, it should work.
You would need a library for your new screen though
cm1981
Post by cm1981 »
Any projects to add a bigger screen or to have the controller come with a second screen? I had read that it was stopped, but hopefully thats not true.
thanks
The project is moving and prototypes have been made, but the final revision is still to be completed.
