error with ra preloaded code
raymond_q
Post by raymond_q »
this is the error it was to big to put on here so I attached it to notepad
error.txt
(75.5 KiB) Downloaded 423 times
Re: error with ra preloaded code
Do you get this error everytime you try to upload any code?
raymond_q
Post by raymond_q »
I am not sure this is the only 1 I have tried.
raymond_q
Post by raymond_q »
i just loaded a new code with wizard and this is what I got
Watchdog Timer
Version Menu
Wifi Attachment
Simple Menu
Binary sketch size: 27,464 bytes (of a 30,720 byte maximum)
C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cstk500v1 -P\\.\COM4 -b57600 -D -Uflash:w:C:\Users\RAYMOND\AppData\Local\Temp\build5749569528960650357.tmp\sketch_apr09a.cpp.hex:i
Copyright (c) 2000-2005 Brian Dean
Using Port : \\.\COM4
Using Programmer : stk500v1
Overriding Baud Rate : 57600
avrdude: Send: 0 [30] [20]
avrdude: Recv:
avrdude: stk500_getsync(): not in sync: resp=0x0c
avrdude done. Thank you.
Looks like you have the wrong board selected.
raymond_q
Post by raymond_q »
i have it on ra controller
If you have the standard RA, please select w/ optiboot option.
raymond_q
Post by raymond_q »
ok did that. now it seems like the attached error code comes up again
So, is it doing it every time?
Were you ever able to upload any code successfully?
raymond_q
Post by raymond_q »
yes the code seems to be on the ra but it still has the errors on the arduino program.
raymond_q
Post by raymond_q »
ill swing by on friday to drop the unit
