Here is my code:
#define WDT
#define NUMBERS_8x16
#include <avr/pgmspace.h>
ReefAngel.FeedingModePorts = Port5Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit;
ReefAngel.Relay.On( Port5 );
ReefAngel.StandardHeater( Port1,780,790 );
ReefAngel.SingleATO( true,Port3,300,0 );
ReefAngel.StandardLights( Port4,9,0,22,0 ); //LED Fans
ReefAngel.StandardLights( Port6,9,0,22,0 ); //UV LED
ReefAngel.StandardLights( Port7,11,0,20,0 ); //DR-Cyan LED
ReefAngel.StandardLights( Port8,22,0,9,30 ); //SUMP LIGHT
ReefAngel.PWM.SetDaylight( PWMSlope(10,0,21,0,10,100,30,10) ); //BLUE LED
ReefAngel.PWM.SetChannel( 0, PWMSlope(9,0,22,0,10,100,60,10) ); //RB LED
ReefAngel.PWM.SetChannel( 1, PWMSlope(10,30,21,0,10,55,120,10) ); //CW LED
ReefAngel.PWM.SetChannel( 2, PWMSlope(10,30,21,0,10,75,120,10) ); //CW LED
if ( ReefAngel.Params.PHExp < 665 ) ReefAngel.Relay.Off(Box1_Port2); //CO2 Switch
if ( ReefAngel.Params.PHExp >= 680 ) ReefAngel.Relay.On(Box1_Port2); //CO2 Switch
ReefAngel.AddWifi();
byte x = 6;
byte y = 2;
byte t;
ReefAngel.LCD.DrawDate(6, 2);
ReefAngel.LCD.Clear(COLOR_SLATEGREY, 1, 11, 132, 11);
ReefAngel.LCD.DrawLargeText(COLOR_BLUE,255,12,16,"Steve's Reef", Font8x16);
ReefAngel.LCD.DrawText(COLOR_BLUE,255, 6, 101, "--------------------");
ReefAngel.LCD.DrawText(COLOR_BLUE,255, 6, 126, "--------------------");
ReefAngel.LCD.DrawText(COLOR_BLUE,255,10,30,"TANK");
ReefAngel.LCD.DrawLargeText(COLOR_SLATEGREY, 255, 15, 40, text, Num8x16);
ReefAngel.LCD.DrawText(COLOR_BLUE,255,85,30,"CR pH");
ConvertNumToString(text, ReefAngel.Params.PHExp, 100);
ReefAngel.LCD.DrawLargeText(COLOR_SLATEGREY, 255, 85, 40, text, Num8x16);
ReefAngel.LCD.DrawOutletBox(12, 87, TempRelay);
ReefAngel.LCD.DrawText(COLOR_BLUE,255,12,58,"Room");
ConvertNumToString(text, ReefAngel.Params.Temp[T3_PROBE], 10);
ReefAngel.LCD.DrawLargeText(COLOR_SLATEGREY, 255, 15, 68, text, Num8x16);
ReefAngel.LCD.DrawText(COLOR_BLUE,255,81,58,"Tank pH");
ReefAngel.LCD.DrawLargeText(COLOR_SLATEGREY, 255, 85, 70, text, Num8x16);
ReefAngel.LCD.DrawText(0,255,15,109, "RB");
ReefAngel.LCD.DrawText(COLOR_SLATEGREY,255,14,119, ReefAngel.PWM.GetChannelValue(0));
ReefAngel.LCD.DrawText(0,255,105,109, "CW");
ReefAngel.LCD.DrawText(COLOR_SLATEGREY,255,106,119, ReefAngel.PWM.GetChannelValue(1));
ReefAngel.LCD.DrawText(0,255,55,109, "BLUE");
ReefAngel.LCD.DrawText(COLOR_SLATEGREY,255,60,119, ReefAngel.PWM.GetDaylightValue());
ReefAngel.LCD.DrawMonitor( 15, 39, ReefAngel.Params );
#endif // defined DisplayLEDPWM && ! defined RemoveAllLights7' /
