Time for additional Ethernet add-on with PWM output
				topjimmy
Re: Time for additional Ethernet add-on with PWM output
I might have found the problem. I don't think that the header pins I am using are in tight enough. What do you think the best way to get a good connection would be?
				topjimmy
I am thinking about removing the headers and just soldering the wire to the board.  The pins I got from radio shack seem so loose in the header, they just don't make good contact. Maybe the pins I got have to small a diameter.
Do you all just solder your permanent projects?
- DrewPalmer04
DB headers just take them apart and use the pins. They fit very nicely.
				topjimmy
DB?DrewPalmer04 wrote:DB headers just take them apart and use the pins. They fit very nicely.
Did you mean MB?
- DrewPalmer04
http://en.m.wikipedia.org/wiki/D-subminiature
The pins out of the header. No need to buy the entire cable. The shack sells just the header for you to use the pins.
				topjimmy
Ahh I see, I have a ton of those asking to be sacrificed.DrewPalmer04 wrote:http://en.m.wikipedia.org/wiki/D-subminiature
- DrewPalmer04
				topjimmy
If only this could be controlled via the apps or portal.  I have half a mind to maybe attach a little LCD and some buttons to change a few settings.
							- DrewPalmer04
LCD is a good idea. I'll be working on RA communication with the Ethernet module soon. Just have to finish my other project first. Might be a week or two. But I'll see what I can figure out. Tons of people have been requesting that. I just wasn't sure if Roberto had plans to create a "RA" expansion based on this module or not. I didn't want to double develop it.
				topjimmy
Well let me help. Just let me know what you want to try and we can work on it together.  Of course it would also be very cool if Roberto wanted to chime in.
I really don't see why they should not communicate like any other expansion. Data is data. It's just sending it to the right place in the right format.
- DrewPalmer04
Exactly. It'll be easiest through I2C Wire.h lib. I attempted to read RA RTC values before and the RA didn't like that. But for just normal communication it should be easy as pie. Just going to use SDL SDA pins and go for it. When I find time.
				topjimmy
Did you have to jumper your SDA/SCL pins on the head unit or are they already done?  I assume they are standard jumpers if needed.
Making the ethernet board a slave should not be to difficult. Might have to solder direct to the pins? How does it work for other expansions? They use the hub on the relay.
- DrewPalmer04
I already had the jumpers. I have the RF expansion. I last tried to connect to the jumpers last time. I was reading too frequently I think for the RTC. This was causing the RA to spaz. The usb port is exactly that. It contains the SDA SCL. The expansion hub (I believe) is a I2C expander which allows people to connect various # of devices. I'll be using the USB port the next go around. But I'll have to get an I2C expander
				topjimmy
So it is usb in form but i2c in function?DrewPalmer04 wrote:I already had the jumpers. I have the RF expansion. I last tried to connect to the jumpers last time. I was reading too frequently I think for the RTC. This was causing the RA to spaz. The usb port is exactly that. It contains the SDA SCL. The expansion hub (I believe) is a I2C expander which allows people to connect various # of devices. I'll be using the USB port the next go around. But I'll have to get an I2C expander
				topjimmy
My sketch is too big with the jebo pump control functions to even add the code to begin transmission let alone do anything else.
I wonder if it would be better to move the pump control to the ethernet board, and just leave the LED control on my RA. That or I need to upgrade to an RA+...
- DrewPalmer04
That depends on the mA draw of the pump and how it's controlled. RA is using a opamp and the Ethernet module is only straight from the pin. Check mA max for both.
				topjimmy
hmm good point.  I think I saw a guy on ReefCentral that made his own arduino controller. I'll have to look it up.  What I guess I don't understand is why I need to include the functions for the pumps if I import the rf library that has all the modes in it. If I had the RF expansion mod and the wifi mod, the sketch fits.  What am I missing?  I am a little cloudy I guess on how the internal mem settings function with the expansion mods
The RF module doesn't implement the vortech modes, it just triggeres them on the vortech controller. Now you are trying to implement all those functions. It might work if you pick one or two that you want to use...Personally, I always recommend getting the plus if possible since even with all that I'm doing, I'm only using a fraction of the space whereas from my first wizard and customization I was over the 32k limit on the RA.
				topjimmy
I think I am going to have to upgrade.  Is it just a swap out of the board?
yestopjimmy wrote:I think I am going to have to upgrade. Is it just a swap out of the board?
				topjimmy
Well I am just going to pic a few of the wave functions for now.
Roberto, what library can I look at to see the i2c functions? I know obviously wire.h but do you have some other written that would help with communications?
No sense reinventing the wheel.
RA_PWM.cpp
And this is what I load in the dimming module for your reference:
#include <avr/wdt.h>
byte PWMports[] ={
  3,5,6,9,10,11};
byte ChannelValue[] = {
  0,0,0,0,0,0};
byte cmdnum=255;
byte datanum=255;
  Serial.begin(57600);
  Wire.onReceive(receiveEvent);
  Wire.onRequest(NULL);
  Wire.begin(8);
  randomSeed(analogRead(0));
  pinMode(3,OUTPUT);
  pinMode(5,OUTPUT);
  pinMode(6,OUTPUT);
  pinMode(9,OUTPUT);
  pinMode(10,OUTPUT);
  pinMode(11,OUTPUT);
  wdt_enable(WDTO_1S);
  wdt_reset();
  //Serial.println(ChannelValue[0],DEC);
  if (cmdnum!=255)
    ProcessCMD(cmdnum,datanum);
    cmdnum=255;
    datanum=255;
  wdt_reset();
  if (howMany==5)
    cmd1=Wire.read();
    cmd2=Wire.read();
    cmd3=Wire.read();
    cmd4=Wire.read();
    cmd5=Wire.read();
    if (cmd1=='$' && cmd2=='$' && cmd3=='$')
      cmdnum=cmd4;
      datanum=cmd5;
      //Serial.println(cmd4,DEC);
      //Serial.println(cmd5,DEC);
    for (int a=0;a<howMany;a++)
      Wire.read();
void ProcessCMD(byte cmd, byte data)
  wdt_reset();
  // Individual Channel
  if (cmd>=0 && cmd<=5)
    ChannelValue[cmd]=data;
    analogWrite(PWMports[cmd],data);
				topjimmy
- DrewPalmer04
Very cool...that's super helpful
				topjimmy
I also managed to get more pump functions to fit, once  I realized that they were written for two pumps, using both daylight and actinic channels
I only have one pump......
				topjimmy
Quick update: I loaded the code Roberto posted for the PWM expansion onto the Uno\Ethernet.  I soldered the SDA , Clock, and ground to the 4a,5a and grn.  I used 10k resistors connected to the +5v header to the clock and sda connections.  The relay and the head unit did not like it. The relay buzzed and the head unit would randomly reset.
I did set up the head units jumpers, and used a fresh wizard with pwm exp. enabled.
I don't know if I can use that 5v header. I figured it was ok but maybe I'm mistaken. I can post the hybrid code that is part Drews ethernet, part PWM expansion if anyone is interested in looking it over.
Edit: Added mish mash of code.
#include <SPI.h>
#include <Ethernet.h>
byte PWMports[] ={
  3,5,6,9,10,11};
  0,0,0,0,0,0};
byte cmdnum=255;
byte datanum=255;
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00 }; //YOUR MAC off sticker
IPAddress ip(192,168,1, 110); //YOUR STATIC IP HERE
IPAddress remoteserver(198,171,134,6); // forum.reefangel.com
EthernetClient clientout;
unsigned long lastmillisout=millis();
unsigned long lastmillisin=millis();
boolean sending=false;
char strout[400];
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
/*||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||| ETHERNET MODULE  |||||||||||||||||||||||||||||||||||||||||||||||*/
void ethernetmodule() //create ethernet function for loop
  // listen for incoming clients
  EthernetClient client = server.available();
  if (client) {
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    while (client.connected()) {
      while (client.available()) {
        char c = client.read();
        if (sending==false) Serial.write(c);
      while (Serial.available()){
        memset(strout,0,sizeof(strout));
        int b=Serial.readBytesUntil('>',strout,sizeof(strout));
        client.print(strout);
        client.print(">");
        if (millis()-lastmillisin>2000)
          client.stop();
        client.stop();
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
    if (Serial.available())
      int b=Serial.readBytesUntil('\n',strout,sizeof(strout));
      if (b>10)
        sending=true;
        Serial.print(strout);
        Serial.println(" HTTP/1.0");
        Serial.println();
        if (clientout.connect(remoteserver, 80))
          clientout.print(strout);
          clientout.println(" HTTP/1.0");
          clientout.println();
    while (clientout.available()) {
      char c = clientout.read();
      Serial.print(c);
      if (millis()-lastmillisout>8000)
        clientout.stop();
        sending=false;
    if (!clientout.connected())
      clientout.stop();
      sending=false;
    clientout.stop();
    sending=false;
  //GET /status/submitp.aspx?t1=806&t2=0&t3=0&ph=441&id=test&em=0&rem=0&key=&atohigh=0&atolow=0&r=0&ron=0&roff=255 HTTP/1.0
  //GET /status/submitp.asp?t1=806&t2=0&t3=0&ph=441&id=test&em=0&rem=0&key=&atohigh=0&atolow=0&r=0&ron=0&roff=255 HTTP/1.0
  //Host: forum.reefangel.com
  //Connection: Keep-Alive
/*||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||| END ETHERNET MODULE  |||||||||||||||||||||||||||||||||||||||||||||||*/
  Wire.begin(8);
  pinMode(3,OUTPUT);
  pinMode(5,OUTPUT);
  pinMode(6,OUTPUT);
  pinMode(9,OUTPUT);
//  pinMode(10,OUTPUT);
//  pinMode(11,OUTPUT);
  // start the Ethernet connection and the server:
  Ethernet.begin(mac, ip);
  server.begin();
  // Ethernet connection ok and server started
  wdt_reset();
  if (cmdnum!=255)
    cmdnum=255;
    datanum=255;
  wdt_reset();
  if (howMany==5)
    cmd1=Wire.read();
    cmd2=Wire.read();
    cmd3=Wire.read();
    cmd4=Wire.read();
    cmd5=Wire.read();
      cmdnum=cmd4;
      datanum=cmd5;
      Wire.read();
  wdt_reset();
}- DrewPalmer04
Show me some pics of what you're up to.
				topjimmy
I don't have a pic but I'll try to explain betterDrewPalmer04 wrote:Show me some pics of what you're up to.
On the 5v header I have two 10k resistors soldered to the pin, one goes to the pin for SDA, one to the SCL. Then from the relay unit I use the Data - , Data + and Grd, Each of those is soldered to the appropriate pin.
I assume that once power is supplied to the board. That all 5v pins are now "hot" and that there is no need to bring in any other 5v feed. The RA head unit is powering the Uno. So power is then dispersed through the regulator to all the +vcc pins.
Does it matter that I used the pin on the board as the +5v pull up for the resistor? Or does it have to be on the line coming in to the board?
				topjimmy
