wizard problem
Redadeath
Re: wizard problem
Post by Redadeath »
rimai wrote:Yes, single offset for both.
Replace what you have with the code above
sorry this is the first time i replace code would you help me
here is my code would you replace it for me so i learn
    ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port5Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port5Bit;
    ReefAngel.LightsOnPorts = Port7Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port8Bit;
    ReefAngel.Relay.On( Port5 );
    ReefAngel.StandardFan( Port4 );
    ReefAngel.ActinicLights( Port7 );
    ReefAngel.DelayedStartLights( Port8 );
    ReefAngel.Portal( "redadeath" );
also what application would i use to modify the values of internal memmory
clientsuite - portal- ...etc
thank you roberto
when it comes to programming i "always need help "
Re: wizard problem
Replace this:
Redadeath
Re: wizard problem
Post by Redadeath »
It ignoring my internal memory setting now and it started from zero although I adjust the start on 13% and it is in auto mode
Redadeath
Re: wizard problem
Post by Redadeath »
Redadeath
Re: wizard problem
Post by Redadeath »
I set both to start at 13% and end 50 %
also the client suite is stucked to on mode and i cannot change it to auto
would you please define the problem roberto as i am getting bored
thank you
Re: wizard problem
Sorry...
Wrong functions :(
    ReefAngel.ActinicLights( Port7 ); // turn port 7 with actinic offset over standard lights schedule
    ReefAngel.DelayedStartLights( Port8 ); // turn port 8 using standard lights schedule
    ReefAngel.PWM.ActinicPWMParabola(InternalMemory.ActinicOffset_read()); // Parabola using actinic offset
    ReefAngel.PWM.DaylightPWMParabola(InternalMemory.ActinicOffset_read()); // Parabola using actinic offset
Redadeath
Re: wizard problem
Post by Redadeath »
thank you roberto
it worked now well
Redadeath
Re: wizard problem
Post by Redadeath »
hi roberto
i need the actinic to start before daylight with 60 minutes
note : that i have both blue led and white led working on acticin offset
i need to make blue led start before white with 60 minutes
this is the original code
    ReefAngel.PWM.StandardActinic(InternalMemory.ActinicOffset_read()); // Parabola using actinic offset
    ReefAngel.PWM.StandardDaylight(InternalMemory.ActinicOffset_read()); // Parabola using actinic offset
i tried to modify this line like shown by adding +60 but it didnt work
what should i do
thank you
 ReefAngel.PWM.StandardActinic(InternalMemory.ActinicOffset_read()+60); // Parabola using actinic offset
Re: wizard problem
Remove the offset from the daylight channel
ReefAngel.PWM.StandardDaylight();
Redadeath
Re: wizard problem
Post by Redadeath »
but i still need to start the white led before the metal halide
so
actinic start first
then white led
then metalhalide
Redadeath
Re: wizard problem
Post by Redadeath »
what i am running now on the actinic offset it bothe white and blue led
and the metal halide on standard day light schedule
and what i am trying to modify i having different offset for white and blue led
i hope you understand what i mean
Re: wizard problem
What you posted should have worked then.
Redadeath
Re: wizard problem
Post by Redadeath »
So do i have to add+60 to the code as i showed before
Redadeath
Re: wizard problem
Post by Redadeath »
CODE: SELECT ALL
Re: wizard problem
Yeah, that should have worked.
Redadeath
Re: wizard problem
Post by Redadeath »
I tried it but it didnt work
Re: wizard problem
What if you do this:
ReefAngel.PWM.StandardActinic(120);
Redadeath
Re: wizard problem
Post by Redadeath »
Why 120 i just need it to start before white led with 60 minutes
Redadeath
Re: wizard problem
Post by Redadeath »
Here is my light system so u can imqgine what i am talking about
I have blue and white led and metal halide i need blue first then white then metal halide
Re: wizard problem
Just use hard code setting.
120 is the offset from halide.
Redadeath
Re: wizard problem
Post by Redadeath »
ReefAngel.PWM.ActinicPWMParabola(120); // Parabola using actinic offset
Would this code work
Re: wizard problem
It should...
Just try it.
Redadeath
Re: wizard problem
Post by Redadeath »
I try it doesnt work and both white and blue channels ignored my pwm settings
Redadeath
Re: wizard problem
Post by Redadeath »
rimai wrote:Ahh..
So, you want mh on the standardlights and both actinic and daylight on the standardlights + offset?
Is that it?
Both AP and DP will dim together, right? Or you also want offset for AP and DP?
This is what i need
Offset for ap and offset for dp
Redadeath
Re: wizard problem
Post by Redadeath »
CODE: SELECT ALL
When i use this code the relay start at the time of the actinic offset and shut down at the end in the same time the ap pwm signals still works for additional hour while the relay is already been shutdown
Re: wizard problem
Ahh, you need to offset the relay port too then.
Redadeath
Re: wizard problem
Post by Redadeath »
would you give me the code for that Roberto please
but it is ignoring my internal memory settings for % of starting parabola
Re: wizard problem
ReefAngel.StandardLights(Port7,60);
There is a doxygen doc with all the functions here:
http://www.easte.net/RA/html/class_reef ... class.html
