manually turning on relay box ports?
pandimus
Post by pandimus »
So how do i manually operate relay box ports? i/e want to turn off skimmer to clean it?
bencollinz
Re: manually turning on relay box ports?
Post by bencollinz »
the portal, your smartphone or PC
http://forum.reefangel.com/portal.php
http://www.reefangel.com/download.aspx
click contributions.
all of those require your knowing how to forward a port in your router and using a service like dyndns.org, etc.
you really gotta do some searching and read some more.
pandimus
Post by pandimus »
Did search,and dont have wifi module.
bencollinz
ahh, see, you didn't state that.
PC client connected via USB is probably your best bet. The other method is to define the ports you want to shut down for maintenance and use them and program that as your ReefAngel.WaterChangePorts then for maintenance you would just go into waterchange mode from the existing method and all your pumps / skimmer / reactors whatever you would do would shutdown during that time.
pandimus
Post by pandimus »
I guess water change mode it is until I get an ip address to it.
