Temp error
Temp error
I have the temp display reading the correct temp and flashes errors every few times a minute. Is this something that can be fixed?
Re: Temp error
Check if the probe connector is good.
Could be that the wires got stripped. You may need a new probe, since you got it used
Re: Temp error
Connectors look good. Woke up this morning to find the screen black had to reset the unit. Any ideas?
Re: Temp error
here is the code, temp is still flashing between current tank temp and error
ReefAngel.FeedingModePorts = Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardHeater( Port1,760,790 );
ReefAngel.SingleATO( true,Port2,240,0 );
ReefAngel.StandardLights( Port4,21,0,6,0 );
ReefAngel.Wavemaker( Port5,700 );
ReefAngel.Portal( "raymond_q" );
Re: Temp error
Came home to a back screen again but everything seemed fine on the portal. Had to reset. Could this a code or hardware issue
Re: Temp error
I don't know what happened to my post...
I could have sworn I mentioned you should not use wavemaker function, but I can't seem to find it...
Your relay box is a prototype and is so old that it doesn't have the dampening components to reduce the inductive spike of wavemaker pumps.
Re: Temp error
Ok I'll try that tonight. Would this solve the temp error too? Also my temp relay turn on at 76 and my heater is set to 76.4 and automatically turns off when temp is set, the relay is set to turn off at 79 but the relay turns off before 79. Could this be due to the wavemaker a too?
