Meanwell LDD LED drivers
javisaman
Anyone have the Meanwell LDD drivers? I have the dimming expansion module and would like to utilize it for an array of the LDD drivers. The problem is that the dimming expansion outputs at 0-10V, while the LDD drivers require a 0-6V 1mA 100-1K Hz PWM dimming input. Is there a way to modify the expansion module so that it'll output this signal properly?
Re: Meanwell LDD LED drivers
Drop it off along with that box I let you borrow and I'll remove the booster and make it a 0-5VDC PWM signal instead.
Everyone that uses LDD drivers has requested me to either remove the booster to have 0-5VDC PWM or they already bought them without the booster.
javisaman
Yes will do, I'll be sending you an email soon about all of the things I need. The biggest complication is that I have two aquariums running simultaneously at the moment and only one reef angel with accessories.The dimming expansion is still on my old tank, but I'm getting a new LED fixture over here.
