pwm voltage?
pandimus
pwm voltage?
I thought i read somewhere that pwm voltage should be between 0-10vdc. now i was trying to figure out how to make it 5v max, and couldnt find anything. Then i went and rechecked the products page and it says 10vdc. Can it be adjusted and how? i am assuming i can code it to make maximum 50%. I am talking about straight from the relay box. not the expansion.
thanks
Johnny
thanks
Johnny
Re: pwm voltage?
You will need to remove the booster from the relay box and solder some jumper wires.
Even at 50%, the signal is still 0-10vdc, with 50% duty cycle.
Sent from my Galaxy S3 using Tapatalk 2
pandimus
Re: pwm voltage?
just jumper it straight across where the pins used to be? or is there an order?rimai wrote:You will need to remove the booster from the relay box and solder some jumper wires.
Re: pwm voltage?
You need to remove lm358 and resistors.
Then, connect the in to out with jumper wires
pandimus
pandimus
pandimus
Re: pwm voltage?
Easy mod.just De solder like said then connect jumpers from + volts in to out on both sides of the lm358...Thanks
mls228
pwm voltage?
I have my relay box open now. Can you guys describe in terms of pins what to do? Thanks!
mls228
pwm voltage?
Sorry to ask again. "Measure twice, cut once."rimai wrote:You need to remove lm358 and resistors.
I'll remove R19, R20, R21, R22 and the LM358 (IC1), then jumper as described. Correct?
baroutas
- Contact:
Re: pwm voltage?
Roberto if i want change the actinic port from 0-10 to PWM and oposite what must do or remove?
Re: pwm voltage?
Unless you have one of the latest board revisions (rev 8.1), it will be very hard for you to do this.
baroutas
- Contact:
Re: pwm voltage?
How can i see that? I order my RA Noveber 2012.
Re: pwm voltage?
Opening the box, but I'm almost positive the rev 8.1 wasn't around at that time.
baroutas
- Contact:
mls228
Re: pwm voltage?
Life got in the way but 8 months later I made this change and it works perfectly. Thanks Roberto.
