A Few more Questions
cain
Re: A Few more Questions
Post by cain »
features file, i got this from the library folder.
ReefAngel_Features.h
Use this instead:
#define DisplayLEDPWM
#define wifi
#define SIMPLE_MENU
#endif  // __REEFANGEL_FEATURES_H__
cain
Post by cain »
rimai wrote:Use this instead:
#define wifi
#define SIMPLE_MENU
i put this in the library and save it.
however, still getting "sketch too big" when i went to verify.
Make sure to replace everything in the ReefAngel_Feature.h file with that.
cain
Post by cain »
OK, verified it and no more errors.
lemme try it for a day or 2, see how it works.
TY.
cain
Post by cain »
i have this on my controller display
C00:00 L00:00 19
what does this mean?
TY.
it means you won't have clouds or lightning today.
Every midnight, the RA will check whether you have cloud or not.
And for every cloud you have, there's a chance of lightning.
You can change all the parameters on the defines within your code.
rimai wrote:You could, but it would be sharing one of the channels.
What time do you want the moonlight on?
cain
Post by cain »
simulate lunar cycle?
i dont know what time, can you give an advise?
my lights are from 12pm-930pm.
cain
Post by cain »
rimai wrote:it means you won't have clouds or lightning today.
BTW, i've already tested this for 2 days, everything is working perfectly. although i didnt see any lihgtning yet since i put my chance of lightning at 30%.
I want to see a video of the lightining on your tank :)
Choose the time frame for moonlights. For your reference, I turn mine on at 9pm and off at 9am, but some people do opposite of lighting cycle.
Don't forget we are sharing the channel, so the moonlights will actually be on whenever you have your actinics on too.
cain
Post by cain »
when lightning is in forecast, i'll get a video.
if we are sharing with the actinic, wouldnt the actinic turn on if the moonlights are on?
we can simulate the lunar cycle intensity right?
It will not turn your LEDs on, because we are going to kill the relay that powers the drivers and change the PWM output to moon phase intensity.
cain
Post by cain »
rimai wrote:It will not turn your LEDs on, because we are going to kill the relay that powers the drivers and change the PWM output to moon phase intensity.
ok. got it. relay is already on/off, it turns on at 11:58am and turns off at 9:32pm. so no problem there.
Try this:
// Autogenerated file by RAGen (v1.0.4.92), (09/01/2011 21:51)
// RA_090111_2151.pde
#define DisplayImages
#define WavemakerSetup
#define DateTimeSetup
#define VersionMenu
#define ATOSetup
#define MetalHalideSetup
#define DirectTempSensor
#define SingleATOSetup
#define StandardLightSetup
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
randomSeed(analogRead(0));
  ReefAngel.PHMin=526;// 526=PH7.0
  ReefAngel.PHMax=813;// 813=PH10.0
  ReefAngel.FeedingModePorts = B10000000;
  ReefAngel.OverheatShutoffPorts = B01000000;
  ReefAngel.Relay.On(Port8);
  ReefAngel.Timer[1].SetInterval(random(10,150));
  ReefAngel.Timer[1].Start();
  ReefAngel.Relay.On(Port4);
  // Specific functions
  ReefAngel.StandardATO(Port1);
  ReefAngel.MHLights(Port3);
  ReefAngel.Relay.Toggle(Port4);
  ReefAngel.StandardFan(Port6);
  // Have PWM on from 12p to 9:30p, with gradual 150 minute ramp up and 180 down for actinic, and 120 minute ramp up and down for daylight starting at given times
  // From 12pm to 1pm, actinic will slowly ramp up from 10% to 100%, and from 12:30p to 2p, daylight will slowly ramp up from 10% to 50%
  // From 8:30p to 9:30p, actinic will slowly ramp down from 100% to 10%, and from 7p to 8:30p daylight will slowly ramp down from 50% to 10%
 if (hour()<16)
  	if  (hour()<12)
  		ActinicPWMValue=Moonphase();
    	ActinicPWMValue=PWMSlope(12,0,21,30,10,100,150,ReefAngel.PWM.GetActinicValue());
  	if  (hour()<21)
    	ActinicPWMValue=PWMSlope(12,0,21,30,10,100,180,ReefAngel.PWM.GetActinicValue());
  	else if (hour()=21 && minute()<=30)
  DaylightPWMValue=PWMSlope(12,30,20,30,10,50,120,ReefAngel.PWM.GetDaylightValue());
  CheckCloud();
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 8
#define Max_Cloud_Duration 20
#define Min_Clouds_per_Day 1
#define Max_Clouds_per_Day 2
  // In this example, start could be after 11:30am
#define Start_Cloud_After NumMins(15,00)
  // In this example, end could before 6:00pm
#define End_Cloud_Before NumMins(18,00)
#define Lightning_Change_per_Cloud 10
  static byte cloudchance=255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  static byte cloudindex=0;
  static int LastNumMins=0;
#ifdef forcecloudcalculation
    if (cloudchance==255)
#else
#endif
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
  if (cloudchance)
    //is it time for cloud yet?
        else lightningstatus=0;
        if (lightningstatus)
          DaylightPWMValue=100;
          ActinicPWMValue=100;
          DaylightPWMValue=0;
          ActinicPWMValue=0;
        delay(1);
      cloudindex++;
      if (cloudindex < numclouds)
      int x=0;
      if ((cloudstart/60)>=10) x=11; else x=17;
      if ((cloudstart%60)>=10) x=29; else x=35;
    if (lightningchance)
      int x=0;
      if (((cloudstart+(cloudduration/2))/60)>=10) x=51; else x=57;
      if (((cloudstart+(cloudduration/2))%60)>=10) x=69; else x=75;
      ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60));
  cstart*=60;
  cend*=60;
  if (n>cend) return PWMStart;
byte MoonPhase()
  int m,d,y;
  int yy,mm;
  long K1,K2,K3,J,V;
  byte PWMvalue;
  m=month();
  d=day();
  y=year();
  yy=y-((12-m)/10);
  mm=m+9;
  if (mm>=12) mm-=12;
  K1=365.25*(yy+4712);
  K2=30.6*mm+.5;
  K3=int(int((yy/100)+49)*.75)-38;
  J=K1+K2+d+59-K3;
  V=(J-2451550.1)/0.29530588853;
  V-=int(V/100)*100;
  V=abs(V-50);
  PWMvalue=4*abs(50-V); // 5.12=100% 4=~80%
  //pinMode(lowATOPin,OUTPUT);
  return (PWMvalue*100)/255;
cain
Post by cain »
ok, thanks. will need to go to homedepot tomorrow to splice this thing. :)
i'll splice it together with my actinic led's right? but how come in the code it says lowATOPin?
i'm not using my ATO molex.
Roberto, this varies in intensity like the moon right?
TY.
The lowATOPin is commented out. It's reminescent of previous code.
Yes, it will vary according to moon phase and you should splice with the Actinic channel.
cain
Post by cain »
ok, done splicing today, when i verified the code it says "moonphase was not declared in this scope".
if (hour()<16)
if (hour()<12)
if (hour()<21)
Sorry typo... :(
Change it to MoonPhase
cain
Post by cain »
another error,
ivalue required as left operand of assignment
if (hour()<21)
I had my RA hooked up and performing 2.5 hr long simulation yesterday when I was coding this for you and couldn't compile to verify errors.
Anyway, try this now:
#define VersionMenu
#define ATOSetup
if (hour()<16)
     if  (hour()<12)
        ActinicPWMValue=MoonPhase();
     if  (hour()<21)
     else if (hour()==21 && minute()<=30)
  CheckCloud();
void CheckCloud()
#else
#endif
      if (cloudchance)
  if (cloudchance)
          DaylightPWMValue=0;
          ActinicPWMValue=0;
        delay(1);
      cloudindex++;
      int x=0;
      int x=0;
  cstart*=60;
  cend*=60;
byte MoonPhase()
  int m,d,y;
  int yy,mm;
  long K1,K2,K3,J,V;
  byte PWMvalue;
  m=month();
  d=day();
  y=year();
  yy=y-((12-m)/10);
  mm=m+9;
  if (mm>=12) mm-=12;
  K2=30.6*mm+.5;
  J=K1+K2+d+59-K3;
  V-=int(V/100)*100;
  V=abs(V-50);
cain
Post by cain »
thanks Roberto!
cain
Post by cain »
it's working, nice, real cool.
do you think i need another moonlight for a 3ft tank?
I have a 3ft tank and I use 2.
But I can see it with just one in the center, with just some lack of coverage at the extremities.
aranax
Post by aranax »
Hey Robert et al,
Can you please help me with my MoonPhase code? I have the Meanwell P drivers so I need them to start at 15 but I want them at 0 for a period of time.
I'd like to have:
from 12:30PM to 6:00PM - PWMChannel[LEDPWM3]=PWMSlope(12,30,22,00,15,60,240,PWMChannel[LEDPWM3])
from 6:00PM to 4:00AM (next day) -
PWMChannel[LEDPWM3]=MoonPhase()
from 4:00AM to 12:30PM -
PWMChannel[LEDPWM3]=0;
Thanks.
-J
Try this:
  if (now()>ScheduleTime(12,30,0) && now()<=ScheduleTime(18,0,0))
  else if (now()>ScheduleTime(18,0,0) || now()<=ScheduleTime(4,0,0))
    PWMChannel[LEDPWM3]=MoonPhase();
aranax
Post by aranax »
Thanks Robert. So far, so good.
-J
