No graphs on iPhone and portal
raymond_q
Hey guys I'm having a issue with seeing the graphs on my iPhone and portal. I could see current temp, ph and relays that are on. I just used the wizard to generate my codes
- cosmith71
Re: No graphs on iPhone and portal
Do you mean you're accessing the portal from your iPhone browser?
raymond_q
No iPhone app and through a pc
From my experience it means your RA is not sending data to the portal. When you view the portal or iphone app and you see the live data it is because your connecting to the RA. But if the graphs aren't getting data it's because somehow your RA is not forwarding. Can you post your code. I've seen this happen if the portal timer is used for other things.
Also can you confirm your iphone app and portal are seeing info when you log in?
raymond_q
Posted: Fri Apr 19, 2013 11:01 am
Can you post your code?
Top
Quote
Report this post
raymond_q
Posted: Wed Apr 24, 2013 6:25 pm
here is the code, temp is still flashing between current tank temp and error
ReefAngel.FeedingModePorts = Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardHeater( Port1,760,790 );
ReefAngel.SingleATO( true,Port2,240,0 );
ReefAngel.StandardLights( Port4,21,0,6,0 );
ReefAngel.Wavemaker( Port5,700 );
ReefAngel.Relay.Set( Port6, !ReefAngel.Relay.Status( Port5 ) );
ReefAngel.Portal( "raymond_q" );
Top
Quote
Report this post
raymond_q
If you set a portal key, you need to change your code or disable the key in the portal.
raymond_q
Do you mean the password key? If so it is disable
raymond_q
Ok that worked thank you
