i need to forward port 2000 to ip address 192.168.1.10
using a mac computer and clearspot 4g wifi...did all the steps to set up the wifi and it appears to work but wont display the ip address on the RA when i push on the joystick as in the manual.....in fact it wont do anything to my iphone and i think the last step seem to be to port forward but i cant find where to look up how to do this
the manual has a long part in tera term but im told that i dont need tera term ?? please help me someone
thanks.
wifi installing how do you forward the port
ReefDevil
ReefDevil
Re: wifi installing how do you forward the port
I figure it out, thanks roberto for the help..
the clear wireless had to change some settings and rename some things
then it would forward the port
its working on my cell phone, however im concerned something is not 100% because in the setup steps it says to push the joystick for the RA to show the ip address and it does not do that at all
I think that theres something wrong in the documentation...the RA does not do that. Enjoy your working wifi!!
ReefDevil
its not working right, it did fill in ph temp etc... but whats showing on the ra and my phone are totally different numbers??
ReefDevil
ph and temp work,,,ai sol with cable are running 100 percent, cant turn off any of the pumps etc
is there like a safety i need to turn off or something
I think you need to turn direct connect on if you are using iphone app.
ReefDevil
tried that...it reports the temps and ph but cant turn off any outlets or adjust the lights sometimes it has percentage numbers for the 3 light channels somet only light on the wifi that lights up anytime is the green one slow flashes
ReefDevil
the second tab at the bottom controls...the whole page doesnt do anything when moving any of them
