New libraries now i have trouble
johniii
Post by johniii »
trying to update the time o my dosing pumps and getting an error. Worked fine before the update.
    ReefAngel.AddStandardMenu();  // Add Standard Menu
    ReefAngel.LightsOnPorts = Port2Bit | Port4Bit | Port6Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port4Bit | Port6Bit | Port7Bit | Port8Bit;
    byte ShortPulseMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync)
      byte tspeed=0;
      PulseMinSpeed=constrain(PulseMinSpeed,30,100);
      PulseMaxSpeed=constrain(PulseMaxSpeed,30,100);
      if (PulseSync)
        return tspeed;
    byte LongPulseMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync)
      byte tspeed=0;
      tspeed=(now()%(PulseDuration*2)<PulseDuration?PulseMinSpeed:PulseMaxSpeed);
      if (PulseSync)
        return tspeed;
    byte SineMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync) {
      double x,y;
      x=double(now()%(PulseDuration));
      x/=PulseDuration;
      x*=2.0*PI;
      if (!PulseSync) x+=PI; // shift the sine wave for the right pump
      y=sin(x);// y is now between -1 and 1
      y+=1.0; // y is now between 0 and 2
      y/=2.0; // y is now between 0 and 1
      // now compute the tunze speed
      y*=double(PulseMaxSpeed-PulseMinSpeed);
      y+=double(PulseMinSpeed);
      y+=0.5; // for proper rounding
      // y is now between PulseMinSpeed and PulseMaxSpeed, constrain for safety
      return constrain(byte(y),30,100);
    byte ReefCrestMode(byte WaveSpeed, byte WaveOffset, boolean PulseSync)
      static unsigned long lastwavemillis=millis();
      static int newspeed=WaveSpeed;
      if ((millis()-lastwavemillis) > 5000)
        if (random(100)<50) newspeed--; else newspeed++;
        newspeed=constrain(newspeed,WaveSpeed-WaveOffset,WaveSpeed+WaveOffset);
        newspeed=constrain(newspeed,0,100);
      if (PulseSync)
        return newspeed;
        return WaveSpeed-(newspeed-WaveSpeed);
    byte NutrientTransportMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync)
      static byte WavePhase=0;
      static time_t WaveStart=0;
      static byte speed=PulseMinSpeed;
      static byte anti_speed=PulseMinSpeed;
      if (WavePhase==0)
        WavePhase++;
        WaveStart=now();
      else if (WavePhase==1)
        if (now()-WaveStart>2700)
          WavePhase++;
        if ((millis()-lastwavemillis) > PulseDuration)
          if (speed==PulseMinSpeed)
            speed=PulseMaxSpeed;
            anti_speed=PulseMaxSpeed;
      else if (WavePhase==2)
        if (now()-WaveStart>4500) WavePhase++;
        if (now()-WaveStart<=2760)
        if (now()-WaveStart<=3300)
          anti_speed=PulseMaxSpeed*sin(radians(map(now()-WaveStart,3300,4500,0,180)));
      else if (WavePhase==3)
        if (now()-WaveStart>7200) WavePhase++;
      else if (WavePhase==4)
        if (now()-WaveStart>9000) WavePhase=0;
        if (now()-WaveStart<=7260)
        if (now()-WaveStart<=8400)
          anti_speed=PulseMaxSpeed*sin(radians(map(now()-WaveStart,7200,8400,0,180)));
          anti_speed=0;
      if (PulseSync)
        return speed;
        return anti_speed;
    byte TidalSwellMode(byte WaveMaxSpeed, boolean PulseSync)
      static byte speed=0;
      static byte anti_speed=0;
      if (WavePhase==0)
        WavePhase++;
        WaveStart=now();
        if (now()-WaveStart>900) WavePhase++;
        speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,0,900,0,90))))/10;
        speed+=WaveMaxSpeed/2;
        anti_speed=(WaveMaxSpeed*2*sin(radians(map(now()-WaveStart,0,900,0,90))))/5;
        anti_speed+=WaveMaxSpeed/2;
        if (now()-WaveStart>1800) WavePhase++;
        speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,900,1800,90,180))))/20;
        speed+=WaveMaxSpeed/20;
        anti_speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,900,1800,90,180))))/20;
        anti_speed+=WaveMaxSpeed/4;
        if (now()-WaveStart>2700) WavePhase++;
        speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,1800,2700,0,90))))/20;
        anti_speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,1800,2700,0,90))))/20;
        if (now()-WaveStart>3600) WavePhase++;
        speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,2700,3600,90,180))))/20;
        speed+=(WaveMaxSpeed*3)/20;
        anti_speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,2700,3600,90,180))))/20;
        anti_speed+=(WaveMaxSpeed*3)/20;
      else if (WavePhase==5)
        speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,3600,4500,0,90))))/20;
        anti_speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,3600,4500,0,90))))/20;
      else if (WavePhase==6)
        if (now()-WaveStart>5400) WavePhase++;
        speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,4500,5400,90,180))))/20;
        speed+=(WaveMaxSpeed*5)/20;
        anti_speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,4500,5400,90,180))))/20;
        anti_speed+=WaveMaxSpeed/20;
      else if (WavePhase==7)
        if (now()-WaveStart>6300) WavePhase++;
        speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,5400,6300,0,90))))/20;
        anti_speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,5400,6300,0,90))))/20;
      else if (WavePhase==8)
        speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,6300,7200,90,180))))/20;
        speed+=(WaveMaxSpeed*7)/20;
        anti_speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,6300,7200,90,180))))/10;
      else if (WavePhase==9)
        if (now()-WaveStart>8100) WavePhase++;
        speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,7200,8100,0,90))))/20;
        anti_speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,7200,8100,0,90))))/2;
      else if (WavePhase==10)
        speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,8100,9000,90,180))))/2;
        anti_speed=speed;
      if (PulseSync)
        return speed;
        return anti_speed;
    byte TideMode(byte WaveSpeed, byte minOffset, byte maxOffset)
      // Contribution of lnevo
      double moonOffset; // gap between high and low
      double amplitude;  // tide curve
      double wavelength=12*SECS_PER_HOUR;
      // Calculate the gap between high and low tide based on MoonPhase()
      moonOffset=cos(((2*PI)/100)*MoonPhase());
      moonOffset=((moonOffset+1)/2)*100; // Convert to percentage
      // Find out the current tidal height
      amplitude=sin(((2*PI)/wavelength)*now());
      moonOffset=map(moonOffset,0,100,minOffset,maxOffset);
      amplitude=amplitude*moonOffset;
      // Adjust the calculate speed to be in our adjusted range
      return constrain(WaveSpeed+amplitude,0,100);
    ReefAngel.SingleATO( true,Port1,120,0 );
    ReefAngel.StandardLights( Port2,14,0,22,0 );
    ReefAngel.DosingPumpRepeat( Port3,0,60,240 );
    ReefAngel.StandardLights( Port4,14,0,22,0 );
    ReefAngel.DosingPumpRepeat( Port5,30,60,240 );
    ReefAngel.StandardLights( Port6,14,0,22,0 );
    ReefAngel.StandardHeater( Port7,785,788 );
    ReefAngel.StandardHeater( Port8,785,788 );
    ReefAngel.PWM.SetDaylight( ReefCrestMode(35,15,true) );
    ReefAngel.PWM.SetActinic( ReefCrestMode(35,15,false) );
did you read the post about upgrading the libraries and the file that needs updated?
johniii
Re: New libraries now i have trouble
Post by johniii »
did That
error is
Globals\Globals.cpp.o: In function 'LongPulseMode (unsigned char, unsigned char, int, unsigned char)':
C:\Users]Sabrina\Documents\Arduino\libraries\Globals/Globals.cpp: 265: multiple definition of 'LongPulseMode (unsigned char, unsigned char, int, unsigned char)'
it does the above for all wave modes in the code
johniii
Post by johniii »
I'll try a clean install in a while
johniii
Post by johniii »
from checking global.cpp it seems the wave functions were added there. So do i not have to code them in anymore
johniii
Post by johniii »
ok just uploaded like this
}[code]
works fine.  The wave modes are in the global.cpp
all we have to do now is call the mode
