Wifi firmware update problem
I'm using the graphical wifi setup (bundled with the installer) and when I click update firmware it shows "downloading latest firmware image"
It doesn't move past this point. I even left it downloading overnight. (The wifi unit displays a single fast blinking green light)
Is there a way to manually download the firmware and apply it? Also which firmware is the latest stable version?
Re: Wifi firmware update problem
Roving Networks was bought out by Microchip and they have made several changes over the past year, including changes on the ftp server and changes on the firmware.
The latest version is 4.0:
http://www.rovingnetworks.com/Current_Firmware
This is the change log:
http://www.rovingnetworks.com/FAQs/What ... iFly_v4_xx
And here is how to update:
http://www.rovingnetworks.com/FAQs/How_ ... y_versions
You will need a serial terminal such as Tera Term or putty.
Thank you,rimai wrote:Roving Networks was bought out by Microchip and they have made several changes over the past year, including changes on the ftp server and changes on the firmware.
Im using mac, any idea what program to use?
At factory reset, the module is at 9600 baud 8-N-1, but after it has been setup, it changes to 57600 baud 8-N-1.
Im trying to download the update using ftp update wifly3-400.img but it keeps saying "530 Login authentication failure"
Ive looked in their instructions and it doesnt mention login details? am i retarded?
rimai wrote:At factory reset, the module is at 9600 baud 8-N-1, but after it has been setup, it changes to 57600 baud 8-N-1.
It's probably that you are trying to use the old ftp server.
The new one is rn.microchip.com, which resolves to 198.175.253.161.
use this command to update the ftp address:
set f a 198.175.253.161
Thanks - will give it a shotrimai wrote:It's probably that you are trying to use the old ftp server.
Give it another shot...
The first 2 looks like the wifi wasn't connected...
The AUTH-ERR shown in the log tells that the wifi was not connected properly.
The 3rd one was issued mid way into the authentication process.
Thanks roberto, seems to have mostly fixed it.
Now i am getting this when i try run "ftp update wifly3-400.mif"
After you do the 1st ftp u for the .img file, you must save and reboot then do the 2nd ftp u with the .mif file.
Thanksrimai wrote:After you do the 1st ftp u for the .img file, you must save and reboot then do the 2nd ftp u with the .mif file.
Is it just "save" and "reboot"?
I have succesfully performed the updates and using the graphical wifi utility (mac) have connected to my network.rimai wrote:yeap
However, after connecting the wifi unit back to my reefangel and trying to browse to it in my web browser (192.168.0.15:2000/wifi) i get a message saying "no data received"
I can ping the unit and have confirmed it is on the network through the router monitoring tools. i feel like it needs the reefangel software/firmware installed on it?
Lights were flashing on it. Yellow I thinkrimai wrote:Did you check wifi attachment when generating the code?
Ok, but does your code have wifi stuff?
You must either check mark wifi attachment on the wizard when generating or add it later.
Can you post your code?
My code should have wifi....rimai wrote:Ok, but does your code have wifi stuff?
Edit - Attached codes
- Memory.ino
- (1.15 KiB) Downloaded 380 times
- Binder_Homescreen.ino
- Main Code
- (4.71 KiB) Downloaded 365 times
I don't see wifi stuff in there.
Make sure to add this right above ShowInterface();
ReefAngel.Portal("Poiromaniax");
