Error when compiling InitialInternalMemory
brettb
Hey guys I keep getting the following error when compiling the InitialInternalMemory or any other internal memory memory code generated by the wizard. I have tried deleting the \Users\brett\Documents\Arduino folder and re installing but no luck. What could be the issue?
Simple Menu
C:\Users\brett\Documents\Arduino\libraries\RA_NokiaLCD\RA_NokiaLCD.cpp: In member function 'void RA_NokiaLCD::SendData(byte)':
C:\Users\brett\Documents\Arduino\libraries\RA_NokiaLCD\RA_NokiaLCD.cpp:640: error: 'pingSerial' was not declared in this scope
Simple Menu
Re: Error when compiling InitialInternalMemory
Make sure you are using libs 1.0.5
Download the latest RA Installer from the website.
It has been updated a few days ago.
brettb
downloaded and installed the latest 1.0.5 tonight.rimai wrote:Make sure you are using libs 1.0.5
When I go to Tools/Reef angel libraries version it confirms that I am using 1.0.5
bug
Use this file instead:
I'll update the RA Installer with this new file.
RA_NokiaLCD e;
e.Init();
e.BacklightOn();
InternalMemory.MHOnHour_write(15);
InternalMemory.MHOnMinute_write(30);
InternalMemory.MHOffHour_write(21);
InternalMemory.MHDelay_write(7);
InternalMemory.StdLightsOnHour_write(14);
InternalMemory.StdLightsOffHour_write(21);
InternalMemory.StdLightsOffMinute_write(30);
InternalMemory.DP1Timer_write(4);
InternalMemory.DP2Timer_write(4);
InternalMemory.LEDPWMActinic_write(20);
InternalMemory.LEDPWMDaylight_write(20);
InternalMemory.WM1Timer_write(10);
InternalMemory.WM2Timer_write(15);
InternalMemory.HeaterTempOn_write(766);
InternalMemory.HeaterTempOff_write(770);
InternalMemory.ChillerTempOn_write(774);
InternalMemory.ChillerTempOff_write(770);
InternalMemory.PHMax_write(830);
InternalMemory.PHMin_write(540);
InternalMemory.ORPMax_write(285);
InternalMemory.ORPMin_write(1400);
InternalMemory.RFMode_write(Constant);
InternalMemory.RFSpeed_write(50);
InternalMemory.RFDuration_write(8);
InternalMemory.PWMSlopeStartD_write(15);
InternalMemory.PWMSlopeEndD_write(100);
InternalMemory.PWMSlopeDurationD_write(60);
InternalMemory.PWMSlopeStartA_write(15);
InternalMemory.PWMSlopeEndA_write(100);
InternalMemory.PWMSlopeStart0_write(15);
InternalMemory.PWMSlopeEnd0_write(100);
InternalMemory.PWMSlopeDuration0_write(60);
InternalMemory.PWMSlopeStart1_write(15);
InternalMemory.PWMSlopeEnd1_write(100);
InternalMemory.PWMSlopeDuration1_write(60);
InternalMemory.PWMSlopeStart2_write(15);
InternalMemory.PWMSlopeEnd2_write(100);
InternalMemory.PWMSlopeDuration2_write(60);
InternalMemory.PWMSlopeStart3_write(15);
InternalMemory.PWMSlopeEnd3_write(100);
InternalMemory.PWMSlopeDuration3_write(60);
InternalMemory.PWMSlopeStart4_write(15);
InternalMemory.PWMSlopeEnd4_write(100);
InternalMemory.PWMSlopeDuration4_write(60);
InternalMemory.PWMSlopeStart5_write(15);
InternalMemory.PWMSlopeEnd5_write(100);
InternalMemory.PWMSlopeDuration5_write(60);
InternalMemory.ATOExtendedTimeout_write(120);
InternalMemory.ORPMin_write(2050);
InternalMemory.ORPMax_write(450);
InternalMemory.ActinicOffset_write(30);
InternalMemory.CO2ControlOn_write(770);
InternalMemory.CO2ControlOff_write(760);
InternalMemory.PHControlOn_write(800);
InternalMemory.PHControlOff_write(810);
InternalMemory.AISlopeStartW_write(0);
InternalMemory.AISlopeEndW_write(100);
InternalMemory.AISlopeDurationW_write(60);
InternalMemory.AISlopeStartB_write(0);
InternalMemory.AISlopeEndB_write(100);
InternalMemory.AISlopeDurationB_write(60);
InternalMemory.AISlopeStartRB_write(0);
InternalMemory.AISlopeEndRB_write(100);
InternalMemory.AISlopeDurationRB_write(60);
InternalMemory.RadionSlopeStartW_write(0);
InternalMemory.RadionSlopeEndW_write(100);
InternalMemory.RadionSlopeDurationW_write(60);
InternalMemory.RadionSlopeStartRB_write(0);
InternalMemory.RadionSlopeEndRB_write(100);
InternalMemory.RadionSlopeDurationRB_write(60);
InternalMemory.RadionSlopeStartR_write(0);
InternalMemory.RadionSlopeEndR_write(100);
InternalMemory.RadionSlopeDurationR_write(60);
InternalMemory.RadionSlopeStartG_write(0);
InternalMemory.RadionSlopeEndG_write(100);
InternalMemory.RadionSlopeDurationG_write(60);
InternalMemory.RadionSlopeStartB_write(0);
InternalMemory.RadionSlopeEndB_write(100);
InternalMemory.RadionSlopeDurationB_write(60);
InternalMemory.RadionSlopeStartI_write(0);
InternalMemory.RadionSlopeEndI_write(100);
InternalMemory.RadionSlopeDurationI_write(60);
InternalMemory.DelayedStart_write(7);
InternalMemory.PHExpMax_write(2500);
InternalMemory.PHExpMin_write(500);
InternalMemory.WaterLevelMax_write(3575);
InternalMemory.WaterLevelMin_write(2875);
InternalMemory.IMCheck_write(0xCF06A31E);
e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL+20, MENU_START_ROW*3, "Memory Updated");
e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL+25, MENU_START_ROW*6, "You can now");
e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL+25, MENU_START_ROW*7, "upload your");
e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL+33, MENU_START_ROW*8, "INO code");
brettb
InitialInternalMemory compiles fine now but any memory sketch generated by the wizard gives the same previous errors
brettb
Also, a bit off topic. T1 is not displaying on the graph on the LCD of the reef angel controller. What could cause this?
I'm not able to replicate the error.
Can you post the code you are getting the errors?
brettb
#include <avr/pgmspace.h>
RA_NokiaLCD e;
e.Init();
e.BacklightOn();
InternalMemory.OverheatTemp_write( 290 );
InternalMemory.HeaterTempOn_write( 248 );
InternalMemory.HeaterTempOff_write( 250 );
InternalMemory.ChillerTempOn_write( 255 );
InternalMemory.ChillerTempOff_write( 250 );
InternalMemory.ATOExtendedTimeout_write( 480 );
InternalMemory.ATOHourInterval_write( 0 );
Ahhh.
Memory Settings... I missed that part....
Thanks for contributing and informing about the bugs
It is the same thing.... You must replace the entire #include up top with the new one.
The other alternative is use hard coded settings.
Wizard will also be fixed next update.
brettb
No problem! =)
Iv just change the memory settings through the portal.
carlii
Ok the internal code above complies now, but I do I use these new dosing pump functions?
Also how do I add code for the third dosing pump?
How does the old intenal memory code:
InternalMemory.DP1RepeatInterval_write( 360 );
InternalMemory.DP1Timer_write( 8 );
InternalMemory.DP2RepeatInterval_write( 360 );
InternalMemory.DP2Timer_write( 8 );
translate into teh new internal memory code:
InternalMemory.DP1OnHour_write(360);
InternalMemory.DP1OnMinute_write(8);
InternalMemory.DP2OnHour_write(360);
InternalMemory.DP2OnMinute_write(8);
They are the same thing...
For the 3rd doser, you can use this:
InternalMemory.DP3Timer_write(4);
InternalMemory.DP3RepeatInterval_write(60);
carlii
So do I just ignore the dpon hour and minute?
Yeah, those memory locations are only used for a single dose schedule.
