Adding PWM and Tuning with Internal Memory
Paulturner911
Re: Adding PWM and Tuning with Internal Memory
Post by Paulturner911 »
Thank you soo much!
No problem. Keep us posted!
Paulturner911
Everything seems to work! I need to do a bit of dialing in as to what speed and duration do on the different modes. I did notice that on the min max, I entered min/max percentage that I wanted the pump to run 20/90, so when I had a value of 50 in the portal some would show 40/140. I had to go back and look why. Got it!
Thanks yet AGAIN
I had a bug...here's a fix. The delay would only work the first water change.
Here's the fix
//Feed Mode Delay on Pump
static boolean feeding=false;
static unsigned long feedingstarted = now();
  if (!feeding)
  feeding=true;
} else {
  feeding=false;
[/code
Here's the whole ino.
[code]
ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.StandardFan( Port2 );
ReefAngel.ActinicLights( Port3 );
ReefAngel.WavemakerRandom1( Port5,180,900 );
ReefAngel.WavemakerRandom2( Port6,90,900 );
ReefAngel.DayLights( Port7 );
ReefAngel.DayLights( Port8 );
//Moonlight Phase 9pm-10am (CH4-CH5)
if ( (hour() >=10) && (hour() <21) )
ReefAngel.PWM.SetChannel( 4,(0) );
ReefAngel.PWM.SetChannel( 4, MoonPhase() );
ReefAngel.PWM.SetChannel( 5,(0) );
ReefAngel.PWM.SetChannel( 5, MoonPhase() );
//Pump Delay and Over Flow Protection
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.Off(Port1);
//ATO Protection
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.Off(Port4);
//Kalk Dose 20sec @ 8pm-12pm (every 15min)
if (hour() >=20 || hour() < 12)
ReefAngel.Relay.Set(Port4, now()%900<22);
  if (!feeding)
  feeding=true;
} else {
  feeding=false;
///// Place your custom code below here
// Read memory for RF Wave Settings and use for Tunze/Jaebo
int mode=InternalMemory.RFMode_read();
int speed=InternalMemory.RFSpeed_read();
int duration=InternalMemory.RFDuration_read();
// Change this to what you want your min/max based on vortech speed
// This is for those functions that take both, but only one memory slot.
int minOffset=5;
int maxOffset=10;
int min=speed-minOffset;
int max=speed+maxOffset;
// keep wavemakers off for first 15 minutes of feeding mode.
if (now()-feedingstarted<=900 && ReefAngel.DisplayedMenu==FEEDING_MODE) {
    ReefAngel.PWM.SetDaylight( 0 );
    ReefAngel.PWM.SetActinic( 0 );
} else if (mode==Constant) {
  // Constant
    ReefAngel.PWM.SetDaylight( speed );
    ReefAngel.PWM.SetActinic( speed );
} else if (mode==Lagoon) {
    // Lagoon
    ReefAngel.PWM.SetDaylight( SineMode(min,max,duration,true) );
    ReefAngel.PWM.SetActinic( SineMode(min,max,duration,false) );
} else if (mode==ReefCrest) {
    // Reef Crest
    ReefAngel.PWM.SetDaylight( ReefCrestMode(speed,duration,true) );
    ReefAngel.PWM.SetActinic( ReefCrestMode(speed,duration,false) );
} else if (mode==ShortPulse) {
    // Short Pulse
    ReefAngel.PWM.SetDaylight( ShortPulseMode(min,max,duration,true) );
    ReefAngel.PWM.SetActinic( ShortPulseMode(min,max,duration,false) );
} else if (mode==LongPulse) {
    // Long Pulse
    ReefAngel.PWM.SetDaylight( LongPulseMode(min,max,duration,true) );
    ReefAngel.PWM.SetActinic( LongPulseMode(min,max,duration,false) );
} else if (mode==TidalSwell) {
    // Tidal Swell
    ReefAngel.PWM.SetDaylight( TidalSwellMode(speed,true) );
    ReefAngel.PWM.SetDaylight( TidalSwellMode(speed,false) );
} else if (mode=NutrientTransport) {
    // Smart_NTM
    ReefAngel.PWM.SetDaylight( NutrientTransportMode(min,max,duration,true) );
    ReefAngel.PWM.SetActinic( NutrientTransportMode(min,max,duration,false) );
} else {
    // Default
    ReefAngel.PWM.SetDaylight( TideMode(speed,minOffset,maxOffset) );
    ReefAngel.PWM.SetActinic( TideMode(speed,minOffset,maxOffset) );
ReefAngel.Portal( "paulturner911" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
// Parameters
// Main Relay Box
// Date and Time
byte ShortPulseMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync)
  byte tspeed=0;
  PulseMinSpeed=constrain(PulseMinSpeed,30,100);
  PulseMaxSpeed=constrain(PulseMaxSpeed,30,100);
  tspeed=(millis()%(PulseDuration*2)<PulseDuration?PulseMinSpeed:PulseMaxSpeed);
  if (PulseSync)
    return tspeed;
    return (tspeed==PulseMinSpeed)?PulseMaxSpeed:PulseMinSpeed;
byte LongPulseMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync)
  byte tspeed=0;
  tspeed=(now()%(PulseDuration*2)<PulseDuration?PulseMinSpeed:PulseMaxSpeed);
  if (PulseSync)
    return tspeed;
byte SineMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync) {
  double x,y;
  x=double(now()%(PulseDuration));
  x/=PulseDuration;
  x*=2.0*PI;
  if (!PulseSync) x+=PI; // shift the sine wave for the right pump
  y=sin(x);// y is now between -1 and 1
  y+=1.0; // y is now between 0 and 2
  y/=2.0; // y is now between 0 and 1
  // now compute the tunze speed
  y*=double(PulseMaxSpeed-PulseMinSpeed);
  y+=double(PulseMinSpeed);
  y+=0.5; // for proper rounding
  // y is now between PulseMinSpeed and PulseMaxSpeed, constrain for safety
  return constrain(byte(y),30,100);
byte ReefCrestMode(byte WaveSpeed, byte WaveOffset, boolean PulseSync)
  static unsigned long lastwavemillis=millis();
  static int newspeed=WaveSpeed;
  if ((millis()-lastwavemillis) > 5000)
    if (random(100)<50) newspeed--; else newspeed++;
    newspeed=constrain(newspeed,WaveSpeed-WaveOffset,WaveSpeed+WaveOffset);
    newspeed=constrain(newspeed,0,100);
  if (PulseSync)
    return newspeed;
    return WaveSpeed-(newspeed-WaveSpeed);
byte NutrientTransportMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync)
  static byte WavePhase=0;
  static time_t WaveStart=0;
  static byte speed=PulseMinSpeed;
  static byte anti_speed=PulseMinSpeed;
  if (WavePhase==0)
    WavePhase++;
    WaveStart=now();
  else if (WavePhase==1)
    if (now()-WaveStart>2700)
      WavePhase++;
    if ((millis()-lastwavemillis) > PulseDuration)
      if (speed==PulseMinSpeed)
        speed=PulseMaxSpeed;
        anti_speed=PulseMaxSpeed;
  else if (WavePhase==2)
    if (now()-WaveStart>4500) WavePhase++;
    if (now()-WaveStart<=2760)
    if (now()-WaveStart<=3300)
      anti_speed=PulseMaxSpeed*sin(radians(map(now()-WaveStart,3300,4500,0,180)));
  else if (WavePhase==3)
    if (now()-WaveStart>7200) WavePhase++;
  else if (WavePhase==4)
    if (now()-WaveStart>9000) WavePhase=0;
    if (now()-WaveStart<=7260)
    if (now()-WaveStart<=8400)
      anti_speed=PulseMaxSpeed*sin(radians(map(now()-WaveStart,7200,8400,0,180)));
      anti_speed=0;
  if (PulseSync)
    return speed;
    return anti_speed;
byte TidalSwellMode(byte WaveMaxSpeed, boolean PulseSync)
  static byte speed=0;
  static byte anti_speed=0;
  if (WavePhase==0)
    WavePhase++;
    WaveStart=now();
    if (now()-WaveStart>900) WavePhase++;
    speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,0,900,0,90))))/10;
    speed+=WaveMaxSpeed/2;
    anti_speed=(WaveMaxSpeed*2*sin(radians(map(now()-WaveStart,0,900,0,90))))/5;
    anti_speed+=WaveMaxSpeed/2;
    if (now()-WaveStart>1800) WavePhase++;
    speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,900,1800,90,180))))/20;
    speed+=WaveMaxSpeed/20;
    anti_speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,900,1800,90,180))))/20;
    anti_speed+=WaveMaxSpeed/4;
    if (now()-WaveStart>2700) WavePhase++;
    speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,1800,2700,0,90))))/20;
    anti_speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,1800,2700,0,90))))/20;
    if (now()-WaveStart>3600) WavePhase++;
    speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,2700,3600,90,180))))/20;
    speed+=(WaveMaxSpeed*3)/20;
    anti_speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,2700,3600,90,180))))/20;
    anti_speed+=(WaveMaxSpeed*3)/20;
  else if (WavePhase==5)
    speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,3600,4500,0,90))))/20;
    anti_speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,3600,4500,0,90))))/20;
  else if (WavePhase==6)
    if (now()-WaveStart>5400) WavePhase++;
    speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,4500,5400,90,180))))/20;
    speed+=(WaveMaxSpeed*5)/20;
    anti_speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,4500,5400,90,180))))/20;
    anti_speed+=WaveMaxSpeed/20;
  else if (WavePhase==7)
    if (now()-WaveStart>6300) WavePhase++;
    speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,5400,6300,0,90))))/20;
    anti_speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,5400,6300,0,90))))/20;
  else if (WavePhase==8)
    speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,6300,7200,90,180))))/20;
    speed+=(WaveMaxSpeed*7)/20;
    anti_speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,6300,7200,90,180))))/10;
  else if (WavePhase==9)
    if (now()-WaveStart>8100) WavePhase++;
    speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,7200,8100,0,90))))/20;
    anti_speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,7200,8100,0,90))))/2;
  else if (WavePhase==10)
    speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,8100,9000,90,180))))/2;
    anti_speed=speed;
  if (PulseSync)
    return speed;
    return anti_speed;
byte TideMode(byte WaveSpeed, byte minOffset, byte maxOffset)
  // Contribution of lnevo
  double moonOffset; // gap between high and low
  double amplitude;  // tide curve
  double wavelength=12*SECS_PER_HOUR;
  // Calculate the gap between high and low tide based on MoonPhase()
  moonOffset=cos(((2*PI)/100)*MoonPhase());
  moonOffset=((moonOffset+1)/2)*100; // Convert to percentage
  // Find out the current tidal height
  amplitude=sin(((2*PI)/wavelength)*now());
  moonOffset=map(moonOffset,0,100,minOffset,maxOffset);
  amplitude=amplitude*moonOffset;
  // Adjust the calculate speed to be in our adjusted range
  return constrain(WaveSpeed+amplitude,0,100);
Paulturner911
lnevo wrote:The iOS apps don't work right in my experience changing memory modes. Try doing it from a direct http connection...
http://reefangelwifi:2000/mi214,900
Modify the above to suit your needs.
I was able to do this a month ago. what am I doing wrong?
If I type:
in my browser, I get oops google could not find. Its the correct port on my router....
Please help
make sure you change "reefangelwifi" to whatever the IP address is of your reef angel controller. Google is giving you the error because it can't find "reefangelwifi" as a domain name.
That will only work on your home network. If you are, then most likely your router dropped the dns name that gets assigned when it gets a dhcp address. Try disconnecting / reconnecting the module to make sure it refreshes the lease and try again. Otherwise check in your router, make sure it's also a static reservation. If it's already a static reservation, then sometimes the name you give it in the static reservation overrides the default name the device registers with.
Paulturner911
Thanks....That was it!
