Error Uploading
Re: Error Uploading
Did you check if you have the correct board selected under menu Tools->Board and also the correct COM port under menu Tools->Serial Port?
mason dixon
Re: Error Uploading
Post by mason dixon »
Got it working, didn't know I had to upload the memory file.
dapg8gt
Re: Error Uploading
Post by dapg8gt »
smoothdog wrote:I am getting this error when trying to upload the InitialInternalMemory on my new RA+. I have selected the correct board, the correct COM port and Checked the cable at least 3 times to make sure it is plugged in properly (black wire to the outside right pin):
Watchdog Timer
Version Menu
Simple Menu
Binary sketch size: 7,420 bytes (of a 258,048 byte maximum)
C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -P\\.\COM5 -b115200 -D -Uflash:w:C:\Users\SMOOTH~1\AppData\Local\Temp\build9041109765076733720.tmp\InitialInternalMemory.cpp.hex:i
Copyright (c) 2000-2005 Brian Dean,
Using Port : \\.\COM5
Using Programmer : stk500v2
Overriding Baud Rate : 115200
avrdude: Recv:
avrdude done. Thank you.
This is exactly what I have been getting for the last few hours I have tried to reinstall the software,double checking com port and board, reverting back to default coding ETC.. all I get is the red code at the bottom similar to this all I .. this is my first time trying to use it and have been combing the forum to find a fix without posting but I am at witts end LOL.. Not sure whats going on but the pin is def in the right area and the wizard code verifies and the screen blinks on reboot I will keep trying and hoping I figure it out.
dapg8gt
Re: Error Uploading
Post by dapg8gt »
Here is the screen shot. please tell me what the issue is thanks.. I know im new but ive been trying everything I can find to fix this issue and get my RA online unsuccessfully..
Dang I don't know why that IS sooo big. should I be doing it as a jpeg instead? I can change it if needed..sorry
reef angel issue
reef angel issue
Re: Error Uploading
Do you have RA+?
dapg8gt
Re: Error Uploading
Post by dapg8gt »
Yes I have the plus. I made sure it was checked in the box along with the right com port.
