How many variable speed ports?
kirkwood
Post by kirkwood »
I am still doing comparative shopping on controllers and would like to know how many ports on the reef angel are variable speed?
The Apex Lite has zero variable speed ports while the Apex has 4 variable speed ports.
Re: How many variable speed ports?
The RA includes 2 PWM or Analog dimming channels on the relay box. A dimming module would add another 6 channels of controllable ports in either PWM or analog.
kirkwood
Post by kirkwood »
lnevo wrote:The RA includes 2 PWM or Analog dimming channels on the relay box. A dimming module would add another 6 channels of controllable ports in either PWM or analog.
If I connect my blue and white LEDS to the 2 dimmable channels can I use a multi-outlet plug for each channel so that I can plug 3 whites and 3 blues into each of the dimmable channels?
Outlet plugs can take care of on/off for LED drivers. The two dimming ports can handle 3 drivers each I believe.
kirkwood
Post by kirkwood »
So are all 8 outlets on the RA created the same? I thought I was reading something that said powerheads should be plugged into ports 5 and 6 or something like that.
I am just trying to make sense of all this, and understand everything the RA can do out of the box before I make a purchase.
At this time I won't be using the dimming functionality but I want to make sure I but the correct RA (PWM or Analog) so that in the future I have the right tech. Roberto has recommended analog to me, but I see a lot of people getting the PWM unit and then in the future they can get the analog expansion.
DrewPalmer04 wrote:Outlet plugs can take care of on/off for LED drivers. The two dimming ports can handle 3 drivers each I believe.
it depends on each drivers current draw. the ra can only output a max mA on each channel. i forget what that value is. i know it is posted somewhere on the forum.
enigma32
Post by enigma32 »
You could also work around the current limitation without too much effort, to control more drivers.
Current setup:
60g 24" custom cube (fish and softies right now)
AI Sol Blue, Ecotech MP-10wES
Coralife skimmer
100% customer controller, transitioning to ReefAngel
Port 5 and 6 have dampening circuitry to handle the constant on/off and inrush current from the powerheads constantly cycling.
lnevo wrote:Port 5 and 6 have dampening circuitry to handle the constant on/off and inrush current from the powerheads constantly cycling.
So a Jebao WP40 should be plugged into 5 or 6?
The dimmer controls the speed of the pump when it is on correct?
The power for the wp40 doesnt need to plugged into ra at all. 5 and 6 are for non controllable pumps that we control by turning them on and off very rapidly.
Ok thanks. I may have it plugged into my power strip that is plugged into the RA so when I do maintenance or feedings it turns off.
You can just set the pwm/analog port to go to 0% for the same functionality.
Yeah I was thinking of that too.
