So there are a couple fixes in this. No new functionality though. The big changes for this are:
- Fixed compilation of standard menu - would not compile properly unless PWM Expansion was enabled
- The PWMExpansion define statement is now all uppercase: PWMEXPANSION. Compiler errors are the reason behind it.
#define PWMEXPANSION - Wifi requests - removed labeling unknown requests. Worked good for serial communications but could lead to some problems with wifi stuff.
