Lights cycle doubt
Bo0sted_Rafi
Lights cycle doubt
Post by Bo0sted_Rafi »
Hi to all! Just got an idea about the light cycle in my tank and I need to know if its possible to do I'm thinking. I'm running my rapidled DIY led fixture with the boostled arduino UNO controller. It can control 4 channels but for now I just running 2 channels, one for the whites and the other for the actinics. I can connect my fixture to the RA but now I want to change something.
I want to get the actinics on at "xx" hour at 60% and 30 minutes of fade duration. 30 minutes later I want the whites ones on but just at 12% for 2 hours and then ramps up to 45% for 4 hours and then again ramps down to 12% for 2 hours. In that point when these 2 hours finished, I need to get the blue ones for 1:30 hours and then finish the light cycle. That's possible?
Re: Lights cycle doubt
On your UNO or the RA???
Bo0sted_Rafi
Well, in the ra I think it would be easier. But If I can do it in the UNO would be perfect because I'm waiting for jebo wp25 and that's let me use the channel for control it.
Bo0sted_Rafi
Im incorrect. The arduino I'm using It is based on the ATMega328P Chip and is fully programmable.
That info I founded in the web.
This link shows the code
https://www.boostled.com/Articles.asp?ID=250
Just want to know the better way to get my lights working like I want
Copy and paste the PWMParabola and PWMSlope from the Globals.h for the RA. It does the calculations for what you want to do. That simple really :)
Bo0sted_Rafi
with my controller im running the slope dimming but now im trying to figure if i can do the custom slope code to work like i want now.
In other words, my white lights cycle start at 5pm. At this i want the lights at 12% for 1:30 hours. then, at 6:30 the slope ramps up to 45% for 4 hours. At 10:30pm again the slope ramps down to 12% and still at that % for 1:30 hour (12am)
Drew, Hope you can understand what im trying to say.
enigma32
Post by enigma32 »
Sounds to me like you need to define a different mathematical function for each time period.
You also need to be more specific about "ramps up" when you specify those functions-- do you mean you want it to ramp linearly?
If you can write a formula to determine the value based on the current time, it's easy to turn it into real code.
Here's a starting point (assuming you're talking about "ramping" linearly):
From 5pm to 6:30pm:
light_level = 12
From 6:30 to 10:30pm:
light_level = 12+(33*(seconds_since_6:30 divided by 4*60*60))
This sets the level as a percentage of how far we've progressed through the four hours, going from 12% to 45% (12+33)
I'm confused after this point, since you said it "ramps up" until 10:30, then ramps down, only to stay at 12% for 1.5 hours, until 12AM. But if it stays at 12% for 1.5 hours until 12AM, that means it was already at 12% at 10:30, so when did it "ramp down"?
Current setup:
60g 24" custom cube (fish and softies right now)
AI Sol Blue, Ecotech MP-10wES
Coralife skimmer
100% customer controller, transitioning to ReefAngel
Bo0sted_Rafi
enigma32 wrote:Sounds to me like you need to define a different mathematical function for each time period.
From 5pm to 6:30pm:
light_level = 12
Yes, I'm talking linearly. The same you write, at 6:30pm add 33% more and at 10:30pm get that 33% minus to get 12% again
Like this!!
Sorry for my 1 minute drawing
enigma32
Post by enigma32 »
Ah, that helps a lot!
How long do you want it to take for the transitions? For example, at the transition from 12% to 45% at 6:30PM, how long should it take to go from 12% to 45%? (I'm assuming the same amount of time for each transition)
Current setup:
Coralife skimmer
Bo0sted_Rafi
3 minutes its ok. Remember that's only in the white channel. The blue ones use other slope time.
enigma32
Post by enigma32 »
So, mathematically speaking, you're looking for this:
From 5PM to 5:03
white_level = 12*seconds_since_fivepm/180
From 5:03 to 6:30PM
white_level = 12
From 6:30PM to 6:33PM
white_level = 12+(33*seconds_since_sixthirty/180)
From 6:33PM to 10:30PM
white_level = 45
From 10:30PM to 10:33PM
white_level = 45-(33*seconds_since_tenthirty/180)
From 10:33PM to 12AM
white_level = 12
From 12AM to 12:03AM
white_level = 12-(12*seconds_since_midnight/180)
Right? I'll try and whip up some code for you later tonight if somebody else doesn't beat me to it.
Current setup:
Coralife skimmer
Lights cycle doubt
You should be able to do this...
ReefAngel.PWM.SetDaylight(PWMSlope(17,0,0,3,0,12,3,0));
ReefAngel.PWM.SetDaylight(PWMSlope(18,30,22,33,12,45,3,ReefAngel.PWM.GetDaylightValue()));
The first line sets the daylight port to start at 5:00 and end at 12:03am with a 3 minute ramp up and down from 0%-12%. Otherwise value is 0.
The second line overrides the value from 6:30-10:33 with a 3 minute ramp up and down the value from 12%-45%, otherwise the value is what it's already set at.
The write to the pwm port happens during the ShowInterface function at the end of your loop.
This is based on the timing that enigma posted...
Bo0sted_Rafi
I will make the harness to the drivers to test it! I don't understand the arduino sketch of the lamp controller to modify that controller
Bo0sted_Rafi
lnevo wrote:You should be able to do this...
I paste that code in my sketch and i will monitoring the light cycle. I need to make the harness to connect the led lamp but i can see if the parameters of the lights change in the portal or the iphone app. i let you know. Thanks to you and for enigma32 too
What's the purpose of the 3 min transition? You could easily do an if statement hour() > X ReefAngel.SetActinic percentage ...then... if else, if else ...else 0%
No?
Lights cycle doubt
He wanted a slope...3 minutes was specified..
Just noticed PAGE 2 of the thread. Lol!!! Duh. Everyone nice work thus far.
Bo0sted_Rafi
The 3 minutes slope is for the transition of light as natural as possible. Thanks
