Wave patterns
- Robert1969
Re: Wave patterns
And the line above it.
He's saying the whole function no longer needs to be manually added in your code:
byte ReefCrestMode(byte WaveSpeed, byte WaveOffset, boolean PulseSync)
static unsigned long lastwavemillis=millis();
static int newspeed=WaveSpeed;
if ((millis()-lastwavemillis) > 5000)
if (random(100)<50) newspeed--; else newspeed++;
newspeed=constrain(newspeed,WaveSpeed-WaveOffset,WaveSpeed+WaveOffset);
newspeed=constrain(newspeed,0,100);
if (PulseSync)
return newspeed;
return WaveSpeed-(newspeed-WaveSpeed);
Current setup:
60g 24" custom cube (fish and softies right now)
AI Sol Blue, Ecotech MP-10wES
Coralife skimmer
100% customer controller, transitioning to ReefAngel
Coralife skimmer
- Robert1969
Wave patterns
You just use the function...you no longer need to have the whole section in your code that was in the last post
- Robert1969
Re: Wave patterns
What part is the function. Sorry for all the noob questions most of the time I feel so lost with this thing
Wave patterns
The function is part of the libraries.
You use it by setting the port connected to your pump with the result of the function like this...
ReefAngel.PWM.SetActinic( ReefCrestMode(45,10,true));
You put a line like that inside your loop section.
- Robert1969
Re: Wave patterns
So If I wanted a Long Pulse and my WP40 is plugged into my daylights i would do something like this...
ReefAngel.PWM.SetDaylight( LongPulseMode(45,10,true));
What is the 45,10 the pump speed and wave length?
Also what does the true do?
Wave patterns
45 is the % 10 is the time between pulses and true means sync.
If you had two pumps you could set one true and one false for an anti sync effect.
Re: Wave patterns
That's what I thought.
45 is the % of speed.
What format is the time in, seconds or milliseconds?
Re: Wave patterns
It's in the original post
Each function has a different unit. Short Pulse and NTM are milliseconds, but Long Pulse is seconds.
Also, your code is missing one parameter. It's supposed to be 4 total.
Check the original post.
Re: Wave patterns
Sorry Roberto. Like I said I'm a complete noob to coding.
It looks like I left out the PulseMinSpeed or PulseMaxSpeed.
So would it be like this?
ReefAngel.PWM.SetDaylight( LongPulseMode(45,70,10,true));
Re: Wave patterns
Thanks for making me figure it out.
Again "Teach a man to fish".
Re: Wave patterns
So I've scanned throughout the last 5 or so pages and didn't see it. Is there ant way we can get Lagoon mode add to the wave patterns?
Dustin
Dustin
Re: Wave patterns
Well, Lagoon is nothing more than reefcrest with a very close min and max range.
Re: Wave patterns
Ok I got most everything setup last night.
There's only a couple of things I need to tackle still, but the first and what seems to be the easiest is hooking up and coding the WP40.
I know all the wave patterns are on the first page (Thank Roberto), but can someone equate them to the different modes on the WP40?
H: High, constant, non-variable flow (13,000 LPH)
L: Low, constant, non-variable flow at a third of the speed (4,300 LPH)
W1: Short pulses which, when timed correctly will create a back and forth motion and form a gentle standing wave in your tank. Adjust the controller to change the speed of the pulses and vary the size of the wave according to your tank.
W2 & W3: Pump gradually speeds up and slows down incrementally to create a varied flow pattern. Adjustable to form the wave best suited to your tank.
Else: Reef Stream Mode, a mixed, changing pattern that creates a random flow cycle similar to what you would find in a natural reef.
I currently use W1 on a slow speed 16-18V and a medium wave length.
Re: Wave patterns
Could I just ask as I may be looking at this a bit to simplistically:
I have 2x wp40's that I want to connect to my light ports and for example I want a long pulse minimum power at 10% maximum at 50 lasting for 20 seconds each anti-sync I would enter the below into my loop?
ReefAngel.PWM.SetDaylight( LongPulseMode(10,50,20,true))
ReefAngel.PWM.SetActinic( LongPulseMode(10,50,20,false))
Dave
Dave
Re: Wave patterns
I'm just getting into coding and by no means am an expert, but this looks correct.
The criteria for Long Pulse is...
Long Pulse
PulseMinSpeed - % for minimal speed
PulseMaxSpeed - % for maximum speed
PulseDuration - Duration (seconds) in which each pulse will be held. The pump will stay at minimal speed for PulseDuration and will stay at maximum speed for PulseDuration.
PulseSync - true if you want to sync pumps to same cycle. one false and one true if you want to anti-sync pumps.
Long Pulse
Re: Wave patterns
Hi SacohenSacohen wrote:I'm just getting into coding and by no means am an expert, but this looks correct.
Long Pulse
Its how I see it as well; I should thank you really as you have been asking all the questions I would have put
We will see what the masters of the "black art" say, I hope we are both not mistaken
Thanks again
Dave
Re: Wave patterns
Yeap, that's all you needcoolbird wrote:Could I just ask as I may be looking at this a bit to simplistically:
Dave
Re: Wave patterns
You mean I got something right Robertorimai wrote:Yeap, that's all you needcoolbird wrote:Could I just ask as I may be looking at this a bit to simplistically:
Dave
Re: Wave patterns
Well... Almost there.... You just missed the ; at the end of the 2 lines, but the idea was there and I consider this just a typo....
Re: Wave patterns
I still forget parens, semicolons, braces all the time...thats what compiler errors are for
Re: Wave patterns
Nope Roberto no typo I had missed them offrimai wrote:Well... Almost there.... You just missed the ; at the end of the 2 lines, but the idea was there and I consider this just a typo....
Re: Wave patterns
Hey folks, not trying to hijack your thread here. I need a bit of help with my controllable pump... Still trying to figure out if it's doable and if so how... I can't post links or send private messages I'm such a noob, but if you search for 'Help to connect a certain controllable pump to my ATO DWM' you will find it.
Re: Wave patterns
I seem to be missing something here I am using the lines below but I was trying to get the pumps to alternate and as I understand it to do this you need one on false and the other on true (or have I got this wrong,,,again)coolbird wrote:You mean I got something right Robertorimai wrote:Yeap, that's all you needcoolbird wrote:Could I just ask as I may be looking at this a bit to simplistically:
DaveI will try not to make a habit out of it,,,,,,,thanks
Doesn't seem to matter whether I have them false and true or both on true they seem to be coming on for 20 seconds at the set percentage then both dropping back to the reduced powerthen after 20 seconds back up to 30% again!!
ReefAngel.PWM.SetDaylight( LongPulseMode(10,30,20,true));
ReefAngel.PWM.SetActinic( LongPulseMode(10,30,20,false));
Any advice would be welcome.
Dave
Re: Wave patterns
Yes, your code looks correct.
What do you see in the screen for AP/DP?? Are they alternating?
Re: Wave patterns
On the ra screen its just showing the both solid at 30, not changing at all either of them!!rimai wrote:Yes, your code looks correct.
Edit:
When you run through the wizard am i supposed to change anything in the light settings?
Re: Wave patterns
Oh, I know now what is happening.
I don't think the pump can go much lower than 30%.
So, anything lower than 30% is capped at 30%.
If people that have been using this pump can confirm that the pump can indeed go lower than 30%, please let me know and I'll certainly change the libraries.
