I know its too big because my ph coding its complicate but im trying to add the PWM codes and that adds 1800 bytes more than i without control my lights!!! Í think my custom screen its killing my memory too but if someone let me know what can i do to resolve this, let me know.
This its my code
#define SIMPLE_MENU
#define NUMBERS_8x16
int avgph[10];
unsigned long totalavgph=0;
byte avgindex=0;
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit | Port3Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit | Port6Bit;
ReefAngel.LightsOnPorts = Port1Bit | Port2Bit | Port6Bit | Port4Bit | Port5Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port7Bit ;
for (int a=0;a<10;a++) avgph[a]=analogRead(PHPin);
totalavgph=0;
avgph[avgindex]=analogRead(PHPin);
avgindex++;
if (avgindex==10) avgindex=0;
totalavgph+=avgph[a];
totalavgph/=10;
totalavgph=map(totalavgph, ReefAngel.PHMin, ReefAngel.PHMax, 700, 1000); // apply the calibration to the sensor reading
totalavgph=constrain(totalavgph,100,1400);
if (totalavgph <= 644) ReefAngel.Relay.Off(Port3);
if (totalavgph >= 656) ReefAngel.Relay.On(Port3);
// ReefAngel.CO2Control( Port3,644,655 );
ReefAngel.StandardFan( Port4,780,788 );
ReefAngel.WavemakerRandom( Port6,1200,240 );
ReefAngel.StandardLights( Port7,0,30,12,30 );
ReefAngel.StandardLights( Port8,12,0,2,0 );
ReefAngel.PWM.SetDaylight(PWMSlope(17,0,0,3,0,12,3,0));
ReefAngel.PWM.SetDaylight(PWMSlope(18,30,22,33,12,45,3,ReefAngel.PWM.GetDaylightValue()));
ReefAngel.PWM.SetActinic( PWMSlope(15,0,1,0,9,60,30,9) );
ReefAngel.Portal( "Bo0sted_Rafi" );
byte x;
byte y = 2;
char text[7];
// *********** CHANGE TEMP READOUT COLOR DEPENDENT ON FAN AND HEATER STATUS ***********
int TempColor; // Color for drawing temperature
boolean FanOn = ReefAngel.Relay.Status(Port4); // Get the status of the fan relay
boolean HeatOn = ReefAngel.Relay.Status(Port7); // Get the status of the heater relay
if (HeatOn)
TempColor = COLOR_NAVY; // Blue text, too cold, heater is on
if (FanOn)
TempColor = COLOR_RED; // Red text, too warm, fan is on
if (!HeatOn && !FanOn)
TempColor = COLOR_GREEN; // Green text, no fan or heater on
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 30, 2, "Rafi's Reef"); // Put a banner at the top
ReefAngel.LCD.DrawDate(6, 119); // Put the date and time at the bottom
ReefAngel.LCD.Clear(COLOR_BLACK, 1, 11, 132, 11); // Draw a black line under the banner
x = 12;
y += MENU_START_ROW+1; // MENU_START_ROW is 10, according to globals.h, so y=2+10+1=13
ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, x, y+6, "Tank Temp pH");
ConvertNumToString(text, ReefAngel.Params.PH, 100); // Get pH reading and convert
ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+75, y+18, text, Font8x16); // Put pH on the screen
ConvertNumToString(text, ReefAngel.Params.Temp[T1_PROBE], 10); // Get T1 temp and convert
y += MENU_START_ROW*2;
x = 10;
ReefAngel.LCD.DrawHugeNumbers(COLOR_WHITE, TempColor, x, y, text); // Draw the temperature, white numbers on a colored background
x += (16*4) + 8;
// Code for drawing the relay box
ReefAngel.LCD.DrawOutletBox(12, 92, TempRelay);
