Updated to 1.0.7 library, now I receive "Error Uploading".
mudcat1
Post by mudcat1 »
I just upgraded to the Reef Angel 1.0.7 library and I receive the error "Error Uploading". I am running Arduino 1.0.1 on Ubuntu Linux version 10.04. I did not change my code before upgrading to version 1.0.7.
The end of the Upload log says ...
avrdude: Recv: . [10]
# | 100% 6.49s
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x3dd1
0x04 != 0x[quote][/quote]44
avrdude: verification error; content mismatch
avrdude: Send: Q [51] [20]
avrdude: Recv: . [14]
avrdude done. Thank you.
What is causing this problem?
Re: Updated to 1.0.7 library, now I receive "Error Uploading
That's communication issue.
Is it happening all the time?
It is not related to the libs version or code.
mudcat1
Post by mudcat1 »
Yes it happened both times that I tried to upload it.
mudcat1
Post by mudcat1 »
Yes, it happened again today.
avrdude: verification error, first mismatch at byte 0x2e8d
0xe0 != 0xe2
But only when I use the 1.0.7 libraries.
Sebyte
Post by Sebyte »
Roberto
I am also getting coms failure due to timeout after moving to 1.0.7. libs.
I then did a cold boot of PC and replaced the wizard with the latest build. Still got the following error.
Watchdog Timer
Version Menu
Dimming Signal
Wifi Attachment
Custom Main Screen
Water Level Expansion Module
Simple Menu
Binary sketch size: 35,892 bytes (of a 258,048 byte maximum)
C:\Program Files\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -P\\.\COM4 -b115200 -D -Uflash:w:C:\DOCUME~1\SEBYTE\LOCALS~1\Temp\build7294684086977967832.tmp\_13_may_13.cpp.hex:i
avrdude: Version 6.0, compiled on Apr  6 2012 at 19:29:19
         System wide configuration file is "C:\Program Files\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf"
         Using Port                    : \\.\COM4
         Using Programmer              : stk500v2
         Overriding Baud Rate          : 115200
avrdude: Recv:
I have checked the usual, usb lead not plugged into head right, drivers loaded etc.
There has been no changes made to avrdude since 04/2012.
It even prints the time of compilation.
Is the controller rebooting?
Sebyte
Post by Sebyte »
Ok, problem identified and solved.
The 1.7.0 wizard has the Board defaulted to RA Plus, and I have the standard with optiboot. I thought that was the previous default so did not check.
Lesson learned, never assume that defaults will be carried over from version to version. :oops:
