Upload PDE/INO via wifi?
sf340flier
Quick question: When I need to upload a new sketch or change something on my RA, is there any way I can do this via the wifi? It's a little inconvenient to unscrew and remove the relay box and controller so that I can bring the unit next to my desktop.
In the alternative, is there a way to power the RA without the relay box attached?
Anyone have any ideas? Thanks!
Sebyte
Re: Upload PDE/INO via wifi?
It is not possible to upload code via the wifi unit due to limitations.
The alternative is to use a long USB cable to extend the TTL cable. You can find cables that have a booster built in and I think they go up to 50ft.
As for powering the head unit, you can buy a lead from the RA store, see http://www.reefangel.com/QuickViewUSBPower.html
sf340flier
00Warpig00
If you purchased your RA from Roberto as a new item I believe it ships with the cable needed to power the RA from a USB port (power only via that cable, programming is via TTL USB cable)
Nick
Nick
180G FOWLR
20GH QT#1
29G QT#2
20GH QT#1
29G QT#2
sf340flier
I did purchase an RA+ from this site. Darn! I already ordered a new power cable, didn't realize they were the same:(
Probably not the last mistake I make!
It's always good to have a spare.. the cables are a little sensitive... actually the ports are just extra secure
- Sacohen
I had the same question. Found the answer here. Thanks.
One additional part to my question is if use a long USB extension or bring my laptop to the head unit, do I need to power off the Reef Angel to unplug the Wifi adapter and plug in the computer or is it hot swappable?
- Sacohen
- cosmith71
Edit: RA does not, RA+ apparently does.00Warpig00 wrote:If you purchased your RA from Roberto as a new item I believe it ships with the cable needed to power the RA from a USB port (power only via that cable, programming is via TTL USB cable)
Nick
I got the RA and upgraded to the RA+. The more I learn, the more I wish I would have started out with the RA+.
- DrewPalmer04
Ditto lol
