Can't Upload any code.
- Sacohen
I first tried uploading the sketch that the wizard created and this is the error I got...
Watchdog Timer
Version Menu
Wifi Attachment
Simple Menu
Binary sketch size: 31,500 bytes (of a 258,048 byte maximum)
C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -P\\.\COM3 -b115200 -D -Uflash:w:C:\Users\Steve\AppData\Local\Temp\build6010104045777780908.tmp\sketch_may09a.cpp.hex:i
Using Port : \\.\COM3
Using Programmer : stk500v2
Overriding Baud Rate : 115200
avrdude: Recv:
avrdude done. Thank you.
I have the USB to TTL Cable connected with the black lead to the right most pin on the connection.
The 2 left pins are open.
Then I tried to upload the WiFi Test Code and got this error...
Watchdog Timer
Version Menu
Wifi Attachment
Simple Menu
Binary sketch size: 30,138 bytes (of a 258,048 byte maximum)
C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -P\\.\COM3 -b115200 -D -Uflash:w:C:\Users\Steve\AppData\Local\Temp\build6010104045777780908.tmp\WifiTestCode.cpp.hex:i
avrdude: Recv:
Now I never see the head unit re-boot.
As a matter of fact there are no lights or anything on the head unit.
Watchdog Timer
Version Menu
Wifi Attachment
Simple Menu
avrdude: Recv:
Watchdog Timer
Version Menu
Wifi Attachment
Simple Menu
avrdude: Recv:
Which controller do you have? Sounds like you have the wrong board selected.
- Sacohen
Re: Can't Upload any code.
Sorry. I thought I covered all the questions.
I have the RA+ and the software is set to Reef Angel Plus Controller.
- Sacohen
According to the Arduino interface yes, but like I said I don't see activity on the head unit.
No lights, no LCD screen. Am I supposed to or not?
Here is a video of what is going on on the program interface...
[youtube]http://www.youtube.com/watch?v=uz0n_ar8WD0[/youtube]
You must have the controller turned on to be able to program it.
- Sacohen
Ok. I feel like an idiot, but I can't figure out how to turn the head unit on.
I don't see any switches on it.
I have the USB-TTL cable plugged in. I heard my computer go "bodoink" when I plugged the USB cable in.
There is no power light or status light. The LCD screen is not light up.
I tried pushing the joystick in to see if that was the on/off button. Nothing.
HELP.
HELP.
The power is provided when plugged into a plugged in relay box.
Do you have the RA+? It should have shipped with a USB power cable that you plug into one of the temp probes if you need power at your computer.
- Sacohen
I thought I ordered the. RA+.
I don't see any cable like you are talking about in my package.
Is there a way to tell looking at it?
Look at the part in the store for a visual reference. Its called USB power cable.
- Sacohen
Then you'll need to have it plugged into the relay box
- Sacohen
- Sacohen
OK. I got the RA + board.
Installed it and plugged it into the relay box.
I got power n the head unit and the LCD is on.
Plugged the TTL-USB connection in to the head unit and my laptop.
I loaded the Wifi Test code and tried to upload it.
I got the following error...
"Serial port Com 3 is already in use. Try quitting any programs that may be using it."
I don't know of anything that would be using it.
mudcat1
I seem to remember having this problem at one time awhile ago. I have multiple usb ports on my laptop so I think I moved the TTL-USB cable to a different USB port and it started working.Sacohen wrote:OK. I got the RA + board.
- Sacohen
