Client Suite 3.0
Re: Client Suite 3.0
rossbryant1956 wrote:save this file where?
Put it anywhere. Open up ReefAngel Client, go to Settings, then Load Memory File. Navigate to the settings file you just saved and it will load it up.
A few posts back, Dave explains what to do with it:
http://forum.reefangel.com/viewtopic.php?p=16602#p16602
Bogdan
Post by Bogdan »
Wherever on your computer.Then go Setting and Memory file and brows to where you saved the file.
Maybe it will work for you, it didn't for me.
Good luck.
Bogdan wrote:Wherever on your computer.Then go Setting and Memory file and brows to where you saved the file.
Good luck.
Be sure to close out the program and restart it after you load the memory file.
Also, make sure you're using the correct memory file for your library version. There's a couple floating around.
I just installed it and got it working.
Great tool Dave Thanks.
The online settings don't seem to let me click in there and do anything.
Actually the "Send Parameters to Reef Angel Portal for online viewing".
I'm getting text & email notifications pretty much every hour saying "pH has reached defined low threshold of 7. The current pH is: x.xx" Usually around 6.0.
I've watched the portal pretty much all day yesterday and had it open at work all morning today and never saw it dip very far out of range. IE today it has stayed pretty much at 7.86.
Also yesterday when it was happening I would go to the client and look at the graph and there was no indication of anything that far out of line.
Are there known issues like this?
I also have notifications set up on the RA Portal and have received nothing except when I my sump fan turned on at noon and brought the water in the sump down to 74°. This is OK, because the light came on at that time to and will start heating up the water,
Topcat
Post by Topcat »
Hi,
Is can you set it to C temp reading?? My controller is in Celsius.
Tony
*** sorry i found it i looked straight at it and didn't see it***
Thanks for the application to its great.....
Paulturner911
Post by Paulturner911 »
enigma32 wrote:@Paulturner911:
It seems to be usually related to the VC++ redistributable... I imagine the installer ensures that you have the right one though. (Perhaps it doesn't, or maybe if it used to work you have installed something that changed the version of the library you had...)
Maybe try reinstalling the client?
Otherwise I think you'll have to wait for the author or someone else familiar with .Net programming to respond... I won't touch that stuff ;)
Id love to get this up and running. I have installed and uninstalled many times over on 2 different hardrives. One was XP with some jacked up mods which may have affected the .NET, so I tried on a virgin Vista, both show the same error. Anyone else have any troubleshooting I could try?
Paulturner911
Problem was with the NET4 update....I had bought 1TB HD and started from scratch, works like a charm!! This thing is bad ass!!
Redadeath
Post by Redadeath »
after insatlling fresh new reef angel client suite
i cannot enter the memmory tab
i got the latest online version of libraries Controller is running dev libraries v.1.0.9
when it comes to programming i "always need help "
Reddy
Post by Reddy »
Redadeath wrote:after insatlling fresh new reef angel client suite
Download the RAMemory.ini file for the version of the libraries you are using. 1.1.0 is here:
http://forum.reefangel.com/viewtopic.php?p=34019#p34019
Load the RAMemory.ini file you just downloaded in the RAClient. In RAClient, click Settings, Load Memory File, and select the RAmemory.ini file.
Close the RAClient and open it again. Check to see if you can read memory.
duck
Post by duck »
Paulturner911 wrote:This is the error I am getting trying to run the program. I can run the dashboard and listener will run, logger will run, but when I switch notifier on, logger will stop.
Im getting that same error and have tried on different machines with clean installs. seems ill never get this working.
Does anyone know what is going on with the .Net stuff?
Seedlessone
Post by Seedlessone »
Okay why cant I see the refresh button anymore under memory. I can connect just fine but I cant scroll down to hit the refresh button. Ive tried everything all the way down to changing screen resolution.... Please help about to throw computer across room. All my tank parameters are showing so I know Im connected.
did you update the ini file?
For v1.0.9 libs, you need this one.
Reddy
Post by Reddy »
rimai wrote:For v1.0.9 libs, you need this one.
Is there a new RAMemory.ini for 1.1.0?
Try this one...
michaela
Post by michaela »
My client has stopped working. After I re-install the client it works for a couple of hours then it stops.
Listener has stopped (logger and notifier are both running), and attempts to reconnect don't work.
When I look in settings my ip address/port username and key are all erased. I can't even see the ip/port details unless i choose usb then change back to wifi. If i re-enter my details I am unable to save.
Christian.Canuel
Post by Christian.Canuel »
Hi can you help me :roll:
My code:
#include <Globals.h>
#include <RA_Wifi.h>
#include <Wire.h>
#include <OneWire.h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <LED.h>
#include <RA_TempSensor.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>
#include <Memory.h>
#include <RA_Colors.h>
#include <RA_CustomColors.h>
#include <Salinity.h>
#include <RF.h>
#include <IO.h>
#include <ORP.h>
#include <AI.h>
#include <PH.h>
#include <WaterLevel.h>
#include <ReefAngel.h>
////// Place global variable code below here
////// Place global variable code above here
//1 1ight
//2 light
//3 Heater
//4 Wp40
//5 ATO
//6 Skimmer
//7 Pompe Remonte
//8 Phosban
    ReefAngel.FeedingModePorts = Port4Bit | Port6Bit | Port8Bit; // Ports toggled in Water Change Mode
    ReefAngel.WaterChangePorts = Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit; // Ports toggled when Lights On / Off menu entry selected
    ReefAngel.LightsOnPorts = Port1Bit | Port2Bit; // Ports turned off when Overheat temperature exceeded
    ReefAngel.OverheatShutoffPorts = Port3Bit; // Use T1 probe as temperature and overheat functions
    InternalMemory.OverheatTemp_write( 805 );
    ReefAngel.Relay.On( Port2 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.Relay.On( Port7 );
    ReefAngel.StandardHeater( Port3,760,769 );
    ReefAngel.StandardATO( Port5,7200 );
My errors.., Sorry my log is in french..
*****2014-03-31 23:02:41*****
Message:
La référence d'objet n'est pas définie à une instance d'un objet.
StackTrace:
à ReefAngelWCFListener.ReefAngelListener.GetPortalLabels()
Message:
There was an error parsing the query. [ Token line number = 3,Token line offset = 25,Token in error = = ]
StackTrace:
à System.Data.SqlServerCe.SqlCeCommand.ProcessResults(Int32 hr)
à System.Data.SqlServerCe.SqlCeCommand.CompileQueryPlan()
à System.Data.SqlServerCe.SqlCeCommand.ExecuteCommand(CommandBehavior behavior, String method, ResultSetOptions options)
à System.Data.SqlServerCe.SqlCeCommand.ExecuteNonQuery()
à ReefAngelClient.DAO.DataAccess.ExecuteNonQuery(String query)
Message:
StackTrace:
Message:
StackTrace:
Message:
La valeur ne peut pas être null.
Nom du paramètre : String
StackTrace:
à System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
à System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info)
à ReefAngelClient.Form1.DisplayMemoryValues()
Christian
Keep going back some posts and you will find a patch.
Christian.Canuel
Thank you !
Everything is ok !!
Paul_Velasco
Post by Paul_Velasco »
Did something happen to my client? It just quit working today. Was working perfectly fine last night then this morning had a bunch of errors.
Uninstalled then reloaded it it still does not work.
Downloaded the client
Installed client
Loaded the .ini file with the memory load
Get this error when changing from Relay Box 1 to Box 2
Logger quit working
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
   at Transitions.Transition.add(Object target, String strPropertyName, Object destinationValue)
   at ReefAngelClient.Form1.SpinActiveRelayBar(SpinRelay spin)
   at ReefAngelClient.Form1.btnScrollRelayUp_Click(Object sender, EventArgs e)
   at System.Windows.Forms.Control.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ButtonBase.WndProc(Message& m)
   at System.Windows.Forms.Button.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.0.30319.1022 (RTMGDR.030319-1000)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
ReefAngelClient
    Assembly Version: 3.0.4768.39086
    Win32 Version: 3.0.4768.39086
    CodeBase: file:///C:/Users/Velasco/AppData/Roaming/ReefAngel/Client/ReefAngelClient.exe
    Win32 Version: 4.0.30319.1002 built by: RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
    Win32 Version: 4.0.30319.1001 built by: RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
DevExpress.Utils.v11.1
    Assembly Version: 11.1.10.0
    Win32 Version: 11.1.10.0
    CodeBase: file:///C:/Users/Velasco/AppData/Roaming/ReefAngel/Client/DevExpress.Utils.v11.1.DLL
System.Windows.Forms.DataVisualization
    Assembly Version: 3.5.0.0
    Win32 Version: 3.5.30729.5681
    CodeBase: file:///C:/Users/Velasco/AppData/Roaming/ReefAngel/Client/dlls/System.Windows.Forms.DataVisualization.DLL
System.ServiceModel
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel/v4.0_4.0.0.0__b77a5c561934e089/System.ServiceModel.dll
System.Core
    Win32 Version: 4.0.30319.1 built by: RTMRel
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Runtime.Serialization
    Win32 Version: 4.0.30319.1016 (RTMGDR.030319-1000)
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
DevExpress.XtraEditors.v11.1
    CodeBase: file:///C:/Users/Velasco/AppData/Roaming/ReefAngel/Client/DevExpress.XtraEditors.v11.1.DLL
DevExpress.Data.v11.1
    CodeBase: file:///C:/Users/Velasco/AppData/Roaming/ReefAngel/Client/DevExpress.Data.v11.1.DLL
System.Configuration
    Win32 Version: 4.0.30319.1015 (RTMGDR.030319-1000)
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    Win32 Version: 4.0.8876.1
    CodeBase: file:///C:/Users/Velasco/AppData/Roaming/ReefAngel/Client/dlls/System.Data.SqlServerCe.DLL
System.Data
    Win32 Version: 4.0.30319.1 (RTMRel.030319-0100)
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
System.Transactions
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Transactions/v4.0_4.0.0.0__b77a5c561934e089/System.Transactions.dll
System.Xml
    Win32 Version: 4.0.30319.1015 built by: RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
ReefAngelException
    Assembly Version: 1.1.0.0
    Win32 Version: 1.1.0.0
    CodeBase: file:///C:/Users/Velasco/AppData/Roaming/ReefAngel/Client/dlls/ReefAngelException.DLL
System.EnterpriseServices
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.EnterpriseServices/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
Google.GData.Calendar
    Assembly Version: 2.1.0.0
    Win32 Version: 2.1.0.0
    CodeBase: file:///C:/Users/Velasco/AppData/Roaming/ReefAngel/Client/dlls/Google.GData.Calendar.DLL
Google.GData.Client
    CodeBase: file:///C:/Users/Velasco/AppData/Roaming/ReefAngel/Client/dlls/Google.GData.Client.DLL
System.Windows.Forms.Calendar35
    Assembly Version: 3.5.4568.30457
    Win32 Version: 3.5.0.0
    CodeBase: file:///C:/Users/Velasco/AppData/Roaming/ReefAngel/Client/dlls/System.Windows.Forms.Calendar35.DLL
AForge.Controls
    Assembly Version: 2.2.2.0
    Win32 Version: 2.2.2.0
    CodeBase: file:///C:/Users/Velasco/AppData/Roaming/ReefAngel/Client/dlls/AForge.Controls.DLL
AForge.Video
    Assembly Version: 2.2.0.0
    Win32 Version: 2.2.0.0
    CodeBase: file:///C:/Users/Velasco/AppData/Roaming/ReefAngel/Client/dlls/AForge.Video.DLL
Accessibility
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
SMDiagnostics
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/SMDiagnostics/v4.0_4.0.0.0__b77a5c561934e089/SMDiagnostics.dll
System.Runtime.DurableInstancing
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.DurableInstancing/v4.0_4.0.0.0__31bf3856ad364e35/System.Runtime.DurableInstancing.dll
System.ServiceProcess
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ServiceProcess/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.ServiceProcess.dll
System.WorkflowServices
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.WorkflowServices/v4.0_4.0.0.0__31bf3856ad364e35/System.WorkflowServices.dll
System.ServiceModel.Web
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Web/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Web.dll
System.ServiceModel.Discovery
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Discovery/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Discovery.dll
System.ServiceModel.Activities
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Activities/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Activities.dll
System.ServiceModel.Routing
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Routing/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Routing.dll
System.ServiceModel.Channels
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Channels/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Channels.dll
System.IdentityModel
    Win32 Version: 4.0.30319.1001 (RTMGDR.030319-1000)
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.IdentityModel/v4.0_4.0.0.0__b77a5c561934e089/System.IdentityModel.dll
ReefAngelCrypto
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Users/Velasco/AppData/Roaming/ReefAngel/Client/dlls/ReefAngelCrypto.DLL
Transitions
    Assembly Version: 1.2.0.0
    Win32 Version: 1.2.0.0
    CodeBase: file:///C:/Users/Velasco/AppData/Roaming/ReefAngel/Client/dlls/Transitions.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
89delta
Post by 89delta »
My Client is doing the same. Nothing shows up in my general settings and I get the error saying con not connect to listener service. And i've reloaded the memory.ini file.
89delta
Post by 89delta »
Ok so I figured it out....un-install the client software and run regedit.Search for all reefangel registry settings. Delete only the ones for the client and re-install the software....works like a dream again.
Paul_Velasco
89delta wrote:Ok so I figured it out....un-install the client software and run regedit.Search for all reefangel registry settings. Delete only the ones for the client and re-install the software....works like a dream again.
Do you remember which files?
Tried this and regedit did not find any files. What search did you do in regedit to find the files?
grafxalien
Post by grafxalien »
Two quick questions. 1, is there a 1.1.1 memory file?
Two, I added a ranet relay expansion today. Every time I try to switch to box 2 in clientsuite the program crashes. Any ideas?
This is for libraries 1.1.1
Mayur
Post by Mayur »
got the client working with usb but when connected to wifi it not working
log file
*****3/23/2015 12:26:42 PM*****
Message:
StackTrace:
at System.Data.SqlServerCe.SqlCeCommand.ProcessResults(Int32 hr)
at System.Data.SqlServerCe.SqlCeCommand.CompileQueryPlan()
at System.Data.SqlServerCe.SqlCeCommand.ExecuteCommand(CommandBehavior behavior, String method, ResultSetOptions options)
at System.Data.SqlServerCe.SqlCeCommand.ExecuteNonQuery()
at ReefAngelClient.DAO.DataAccess.ExecuteNonQuery(String query)
*****3/23/2015 12:36:41 PM*****
Message:
Value cannot be null.
Parameter name: String
StackTrace:
at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
at System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info)
at ReefAngelClient.Form1.DisplayMemoryValues()
Did you update the INI file?
Mayur
Post by Mayur »
no
