Is there a way to attach a different lcd screen considering how small the one on the controller is. If so, whats the easiest way of doing this. I don't want anything crazy. Just want a bigger screen to view whats on the controller screen.
external lcd screen
Re: external lcd screen
As long as your screen works on 3-wire SPI, it should work.
You would need a library for your new screen though
cm1981
Any projects to add a bigger screen or to have the controller come with a second screen? I had read that it was stopped, but hopefully thats not true.
thanks
thanks
The project is moving and prototypes have been made, but the final revision is still to be completed.
- Sacohen
