Custom Main Screens
Re: Custom Main Screens
My take on the custom screen. The temperature text changes color depending on the state of the heater and fan.
Green = Heater and fan off, temp good.
Red = Temp too high, fan on.
Blue = Temp too low, heater on.
Edit: This assumes the fan is on relay 1 and the heater is on relay 2.
Code:
Code:
byte x;
byte y = 2;
char text[7];
// *********** CHANGE TEMP READOUT COLOR DEPENDENT ON FAN AND HEATER STATUS ***********
int TempColor; // Color for drawing temperature
boolean FanOn = ReefAngel.Relay.Status(Port1); // Get the status of the fan relay
boolean HeatOn = ReefAngel.Relay.Status(Port2); // Get the status of the heater relay
if (HeatOn)
TempColor = COLOR_NAVY; // Blue text, too cold, heater is on
if (FanOn)
TempColor = COLOR_RED; // Red text, too warm, fan is on
if (!HeatOn && !FanOn)
TempColor = COLOR_GREEN; // Green text, no fan or heater on
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 30, 2, "Colin's Reef"); // Put a banner at the top
ReefAngel.LCD.DrawDate(6, 119); // Put the date and time at the bottom
ReefAngel.LCD.Clear(COLOR_BLACK, 1, 11, 132, 11); // Draw a black line under the banner
x = 12;
y += MENU_START_ROW+1; // MENU_START_ROW is 10, according to globals.h, so y=2+10+1=13
ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, x, y+6, "Tank Temp pH");
ConvertNumToString(text, ReefAngel.Params.PH, 100); // Get pH reading and convert
ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+75, y+18, text, Font8x16); // Put pH on the screen
ConvertNumToString(text, ReefAngel.Params.Temp[T1_PROBE], 10); // Get T1 temp and convert
y += MENU_START_ROW*2;
x = 10;
ReefAngel.LCD.DrawHugeNumbers(COLOR_WHITE, TempColor, x, y, text); // Draw the temperature, white numbers on a colored background
x += (16*4) + 8;
ReefAngel.LCD.DrawText(DPColor,DefaultBGColor,8,y+25,"White %");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(), DPColor, 24, y+35, 1); // Draw the white light %
ReefAngel.LCD.DrawText(APColor,DefaultBGColor,x+8,y+25,"Blue %");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(), APColor, x+24, y+35, 1); // Draw the blue light %
// Code for drawing the relay box
ReefAngel.LCD.DrawOutletBox(12, 92, TempRelay);
I had NO IDEA that all these awesome designs and ideas would come from me creating these template functions to allow people to customize their displays.
Great idea for your display. Simple and clean. Looks great!
Thanks! And thanks for the templates. I'm having a blast with my Reef Angel. I doubt this is the final version of my main screen.binder wrote:I had NO IDEA that all these awesome designs and ideas would come from me creating these template functions to allow people to customize their displays.
Ok, so I'm getting ready to add the WiFi module. I noticed in the sample code there are pingserial() commands scattered about that have something to do with the WiFi module. How often do these need to be put in?
The libraries should take care of that for you.
If you are designing a custom main screen, just make sure to call it if you have lots of drawing on the screen.
Is that because of the length of time the drawing takes?
Latest version:
byte x;
byte y = 2;
char text[7];
if (HeatOn)
if (FanOn)
ReefAngel.LCD.DrawText(COLOR_WHITE, COLOR_BLACK, 0, 1, " Colin's Reef "); // Put a banner at the top
pingSerial(); // Hit the Wifi Attachment
x = 12;
x = 10;
ReefAngel.LCD.Clear(TempColor, x, y-1, x+63, y-1); // Draw a line above and below the temp
ReefAngel.LCD.Clear(TempColor, x, y+16, x+63, y+16); // To make it look nicer and easier to read
x += (16*4) + 8;
ReefAngel.LCD.Clear(COLOR_BLACK,5,y+22,127,y+22); // Draw a box around the light area
ReefAngel.LCD.Clear(COLOR_BLACK,5,y+22,5,y+46); //
ReefAngel.LCD.Clear(COLOR_BLACK,127,y+22,127,y+46); //
ReefAngel.LCD.Clear(COLOR_BLACK,5,y+46,127,y+46); //
ReefAngel.LCD.DrawOutletBox(14, 92, TempRelay);
im trying to use the custom screen that showed here but when I upload the code, still showing the graph of the standard screen. Where in the code i remove that graph?
Add this to the very end of the code posted above:Bo0sted_Rafi wrote:im trying to use the custom screen that showed here but when I upload the code, still showing the graph of the standard screen. Where in the code i remove that graph?
I wrote that but give me an error when i tried to compile
Dont let me erase the last code
#define SIMPLE_MENU
#define NUMBERS_8x16
int avgph[10];
unsigned long totalavgph=0;
byte avgindex=0;
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port5Bit | Port3Bit | Port3Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port5Bit | Port3Bit | Port6Bit;
ReefAngel.LightsOnPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port7Bit ;
for (int a=0;a<10;a++) avgph[a]=analogRead(PHPin);
totalavgph=0;
avgph[avgindex]=analogRead(PHPin);
avgindex++;
if (avgindex==10) avgindex=0;
totalavgph+=avgph[a];
totalavgph/=10;
totalavgph=map(totalavgph, ReefAngel.PHMin, ReefAngel.PHMax, 700, 1000); // apply the calibration to the sensor reading
totalavgph=constrain(totalavgph,100,1400);
if (totalavgph <= 645) ReefAngel.Relay.Off(Port3);
if (totalavgph >= 660) ReefAngel.Relay.On(Port3);
// ReefAngel.CO2Control( Port3,645,660 );
ReefAngel.StandardFan( Port4,780,788 );
ReefAngel.WavemakerRandom( Port6,600,180 );
ReefAngel.StandardLights( Port7,0,30,12,30 );
ReefAngel.StandardLights( Port8,12,0,2,30 );
ReefAngel.Portal( "Bo0sted_Rafi" );
byte x;
byte y = 2;
char text[7];
boolean FanOn = ReefAngel.Relay.Status(Port4); // Get the status of the fan relay
boolean HeatOn = ReefAngel.Relay.Status(Port7); // Get the status of the heater relay
if (HeatOn)
if (FanOn)
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 30, 2, "Rafi's Reef"); // Put a banner at the top
x = 12;
ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, x, y+6, "Tank Temp CA pH");
x = 10;
x += (16*4) + 8;
Take that code out of loop() and put it under your #includes (after "Place global variable code below here").
Try this:
Try this:
#define SIMPLE_MENU
int avgph[10];
byte avgindex=0;
byte x;
byte y = 2;
char text[7];
if (HeatOn)
if (FanOn)
x = 12;
x = 10;
x += (16*4) + 8;
totalavgph=0;
avgindex++;
totalavgph/=10;
Heres my custom main.
Im not the best at coding so i have chopped quite a bit from other people
Ideally i would love to take out the bottom two rows and have:
Tank Name
Vortech
2 LED Channels (got a vertex illumilux)
Temp
PH
Relays
ATO - Plan on getting one of the new ones - so if theres a way to see how full the reservoir is
if anyone is willing to help me, you would be awesome in my eyes
Oh, and no peripherals are connected right now as im in the process of switching tanks - incase youre wondering
// Autogenerated file by RAGen (v1.2.2.171), (05/14/2012 18:11)
// RA_051412_1811.ino
#define VersionMenu
#define DisplayLEDPWM
#define wifi
#define SIMPLE_MENU
#define CUSTOM_MAIN
#define RFEXPANSION
#define FONT_8x8
ReefAngel.LCD.DrawDate(6, 122);
ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params);
ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,DefaultBGColor,15,5,"Ariel's Reef");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,1,30,"Vortech:");
byte vtechmode = InternalMemory.RFMode_read();
if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,DefaultBGColor,50,30,"Constant");
else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_PURPLE,DefaultBGColor,50,30,"Lagoon");
else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,DefaultBGColor,50,30,"Reef Crest");
else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,DefaultBGColor,50,30,"Short Pulse");
else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,DefaultBGColor,50,30,"Long Pulse");
else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,DefaultBGColor,50,30,"Night");
ReefAngel.LCD.DrawOutletBox(12, 97, TempRelay);
ReefAngel.SetTemperatureUnit(1); // set to Celsius Temperature
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.On(Port6);
ReefAngel.Relay.On(Port7);
ReefAngel.Relay.On(Port8);
ReefAngel.MHLights(Port1);
ReefAngel.MHLights(Port2);
ReefAngel.StandardHeater(Port4);
Tank Name
Vortech
Temp
PH
Relays
One thing I noticed is that you will want to make all these strings the same length:
The "Constant", "Lagoon", etc. should be the same length and if they are not, then you should pad them. Looks like "Short Pulse" is the longest at 11 chars.
The reason for this is when you change the modes and go from a larger text string to a smaller text string, there will be "ghosting" occurring from the extra characters not being overwritten.
Secondly, you say you want to change the layout of what is displayed? Do you not like having the 3 rows of 2 columns in the middle? Does that need to be changed for you?
Did you still want the date to be at the bottom of the screen? If not, you just need to remove this line: from the DrawCustomMain() function and the date will no longer be displayed.
So "Constant" should be "Constant " and "Lagoon" should be "Lagoon ".
Yeah i like the date and time at the bottombinder wrote:One thing I noticed is that you will want to make all these strings the same length:The "Constant", "Lagoon", etc. should be the same length and if they are not, then you should pad them. Looks like "Short Pulse" is the longest at 11 chars.Code: Select all
if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,DefaultBGColor,50,30,"Constant"); else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_PURPLE,DefaultBGColor,50,30,"Lagoon"); else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,DefaultBGColor,50,30,"Reef Crest"); else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,DefaultBGColor,50,30,"Short Pulse"); else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,DefaultBGColor,50,30,"Long Pulse"); else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,DefaultBGColor,50,30,"Night");
The reason for this is when you change the modes and go from a larger text string to a smaller text string, there will be "ghosting" occurring from the extra characters not being overwritten.Code: Select all
Thanks for pointing that out! So let me just make sure i understand, I should rather have all the vortech modes lined up in the code? (im not so savvy when it comes to coding and terms used, what is padding? the gap between the end of the word and the quotations? )
E.G:
"Lagoon "
"Constant "
"Reef Crest "
I like the 3x2 layout, just would like to be able to change the paramaters viewed to something like this:
Ariel's Reef
Vortech : Reef Crest
Temp 1: 26 PH: 8.3
White : 70% Blue: 20%
ATO level : 65% etc
(ATO level will get its data from the pressure sensor)
Did you still want the date to be at the bottom of the screen? If not, you just need to remove this line:from the DrawCustomMain() function and the date will no longer be displayed.Code: Select all
Replies in red
EDIT - well my beautiful formatting has been destroyed by vBulletin/PHPBB
click edit the post and it will all look correct
Custom Main Screens
yes, the gap between the end of the word and quotation mark. the padding is simply just spaces. so count the letters and use spaces to fill in the extras like i mentioned.Thanks for pointing that out! So let me just make sure i understand, I should rather have all the vortech modes lined up in the code? (im not so savvy when it comes to coding and terms used, what is padding? the gap between the end of the word and the quotations? )
E.G:
"Lagoon "
"Constant "
"Reef Crest "
the 3x2 layout you like will have to be created manually with copying and updating the function that displays it. i can help with it later tonight or tomorrow when i get home and can have access to a keyboard and look things up better with formatting. you can look at the DrawMonitor function inside the nokialcd.cpp file to get an idea.I like the 3x2 layout, just would like to be able to change the paramaters viewed to something like this:
Ariel's Reef
Temp 1: 26 PH: 8.3
ATO level : 65% etc
Ok, here's some code for you based on what you were wanting. I added comments to it and cleaned up things as well (I fixed the spacing issue). Here's the DrawCustomMain function as well as a helper function for drawing your custom monitor box. So just copy and paste these 2 functions into your INO file and replace the existing DrawCustomMain().
The colors may need to be adjusted for you, but that's really easy to change. Also, I assumed that your Blue LED were on the AP channel and the White LED were on the DP channel. They can be flipped if needed. We may also need to adjust the spacing of the column based on the size of the text labels. You will just have to adjust it accordingly and experiment with it.
EDIT: Fixed my typo errors with the code
// Draw the custom monitor, function listed below
DrawCustomMonitor(15, 60);
if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,DefaultBGColor,50,30,"Constant ");
else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_PURPLE,DefaultBGColor,50,30,"Lagoon ");
else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,DefaultBGColor,50,30,"Reef Crest ");
else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,DefaultBGColor,50,30,"Long Pulse ");
else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,DefaultBGColor,50,30,"Night ");
void DrawCustomMonitor(byte x, byte y) {
// To change the column (move it right or left), you will need to adjust the value for X
// The Labels start at X and the values for them start at X+18.
// If you have to move them farther right (making 18 a larger number), you will need to adjust the values for X below for the second column.
// The 2nd column labels start at X+60 and the values start at X+78
// left column - top item
ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor,x,y,"T1:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T1_PROBE], T1TempColor, x+18, y,10);
// left column - middle item, White LED is on DP Channel
ReefAngel.LCD.DrawText(DPColor,DefaultBGColor,x,y+10,"White:");
// you may have to move the value farther to the right
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(), DPColor, x+18, y+10,1);
// left column - bottom item
ReefAngel.LCD.DrawText(T3TempColor,DefaultBGColor,x,y+20,"ATO Level:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.WaterLevel.GetLevel(), T3TempColor, x+18, y+20,0);
// right column - top item
ReefAngel.LCD.DrawText(PHColor,DefaultBGColor,x+60,y,"PH:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.PH, PHColor, x+78, y,100);
// right column - middle item, Blue LED is on AP Channel
ReefAngel.LCD.DrawText(APColor,DefaultBGColor,x+60,y+10,"Blue:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(), APColor, x+78, y+10,1);
// right column - bottom item (not used)
//DrawText(APColor,DefaultBGColor,x+60,y+20,"AP:");
//DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(), APColor, x+78, y+20,1);
Reason: Fixed typos in code
Re:
binder wrote:Ok, here's some code for you based on what you were wanting. I added comments to it and cleaned up things as well (I fixed the spacing issue). Here's the DrawCustomMain function as well as a helper function for drawing your custom monitor box. So just copy and paste these 2 functions into your INO file and replace the existing .
Wow, thanks dude - You have saved me days of work
Il fiddle around with it a bit and post a screenshot when its working nicely
Edit - its throwing up this error
I just fixed up my code in the previous post. I know the WHITE and Params errors should be gone now. I'm not sure why it is giving you the error about the WaterLevel member. It should be available because it found the Water Level Expansion Module.
Make sure you are running the latest libraries. Perhaps Roberto can shed some more light on this error.
Make sure you add this in your includes up top:
//Custom Main, Graph & Menu
byte x = 6;
byte y = 2;
byte t;
char text[7];
static byte vtechmode=0;
ReefAngel.LCD.DrawDate(6, 2);
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 6, 90, "--------------------");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 6, 126, "--------------------");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 93, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 103, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 113, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 123, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 93, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 103, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 113, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 123, "|");
ReefAngel.LCD.DrawText(0,255,18,12,"EcoSmart Vortech");
if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,22,"Constant");
else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,21,"Lagoon");
else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,21,"Reef Crest");
else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,21,"Short Pulse");
else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,21,"Long Pulse");
else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,21,"Nutrient Trnsp.");
else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,21,"Tidal Swell");
else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,45,21,"Night");
ReefAngel.LCD.DrawText(0,255,10,30,"Display");
ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 10, 40, text, Num8x8);
ReefAngel.LCD.DrawText(0,255,100,30,"pH");
ConvertNumToString(text, ReefAngel.Params. PH, 100);
ReefAngel.LCD.DrawLargeText(COLOR_PLUM, 255, 85, 40, text, Num8x8);
ReefAngel.LCD.DrawText(0,255,43,48,"Salinity");
ConvertNumToString(text, ReefAngel.Params.Salinity, 100);
ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN, 255, 49, 58, text, Num8x8);
ReefAngel.LCD.DrawOutletBox(12, 77, TempRelay);
ReefAngel.LCD.DrawText(0,255,8,68,"Sump");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T3_PROBE], COLOR_CORNFLOWERBLUE, 40, 68, 10);
ReefAngel.LCD.DrawText(0,255,70,68,"Room");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], COLOR_CORNFLOWERBLUE, 99, 68, 10);
Barry
Current tank info: 150g mixed reef
"Some of the worst mistakes of my life were hair cuts" -Jim Morrison
- DrewPalmer04
That will display the mode your mp40 is running? Only if you're controlling it via the RF module? The RA sets the mode and then that code displays it on your custom main. I hope you have the RA+ or you'll run out of space quickly.
Yes, using this part of the coding.DrewPalmer04 wrote:That will display the mode your mp40 is running? Only if you're controlling it via the RF module? The RA sets the mode and then that code displays it on your custom main. I hope you have the RA+ or you'll run out of space quickly.
Barry
It's not my code. Anther member posted it in this thread. I just wanted to change it up a litte bit. Should I still open another thread with it? Thanks
Barry
Yes, but post your code and that code seperately so we can see how it needs to be integrated.
After a day of tweaking the code I think i finally have it the way I like it.
I cant take credit, I mostly copied and pasted others codes from this thread.
byte x = 6;
byte y = 2;
byte t;
char text[7];
ReefAngel.LCD.DrawDate(6, 4);
ReefAngel.LCD.DrawLargeText(0,255,10,16," WP40 Mode:");
if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,27,"Constant");
else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,26,"Lagoon");
else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,26,"Reef Crest");
else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,26,"Short Pulse");
else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,26,"Long Pulse");
else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,26,"Nutrient Trnsp.");
else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,26,"Tidal Swell");
else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,255,45,26,"Night");
ReefAngel.LCD.DrawLargeText(0,255,17,49,"Sump");
ReefAngel.LCD.DrawHugeText(COLOR_RED, 255, 12, 65, text, Num12x16);
ReefAngel.LCD.DrawLargeText(0,255,100,40,"pH");
ReefAngel.LCD.DrawLargeText(COLOR_BLUE, 255, 89, 55, text, Num8x8);
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,15,89, "WP40L");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,20,100, ReefAngel.PWM.GetDaylightValue());
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,88,89, "WP40R");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,95,100, ReefAngel.PWM.GetActinicValue());
ReefAngel.LCD.DrawOutletBox(12, 113, TempRelay);
Barry
