There is a post somewhere about the new firmware and modules...it's like a two step process now or something like that....bhazard wrote:Had a little trouble with the wifi module at first, but got it up and running. I can't update the firmware through the wifi utility though, so it is either the newest firmware, or something else needs to be fixed.
I'm loving the Reef Angel way more than the Apex already. Built in ATO is a nice touch, and I can get rid of my Avast top off.
If you have the avast pressure switch, you can wire that to one of the ato ports and still have a pressure switch in lieu of a float. Can then use the float for backup. And you could still use both floats...
I have my two float switches wired in parallel doing different things connected to one ato port. The higher one watches my sump for an overflow (and doubles as a salt water ato during water changes) and the lower one alarms if my sump is running too low and my pump may cavitate soon.
Just some food for thought...
