what do i need
Talk about you and your tank/equipment
PostPosted: Fri May 17, 2013 1:44 pm
im switching from RKE to the RA and trying to figure out what i need. I have DIY LED's with two different dimmings one white one blue, 2 moon lights, one jebao wp40 for now but would like 2. other not so key things are heater skimmer return pump and a few other power heads. I was going to order the RA + w/anolog, jegao calbe, and wifi expansion. Do I need anything else? another expansion to run all lights and jebao?
PostPosted: Fri May 17, 2013 5:28 pm
What drivers are you using?
The base system comes with 2 channels that can be used for either WP40 or LEDs.
You will need the dimming expansion module for more than 2 channels.
Return to You and your tank
