I went through the Wifi install without any problems. After the install it said that port forwarding had been completed.
My portal and droid app aren't recognizing the ip address that I'm entering.
What did I miss?
Wifi Install help
dbmet
Wifi Install help
Did you check to make sure port 2000 is open ?
http://www.yougetsignal.com/tools/open-ports/
Wifi Install help
Also what ip are you entering? If you enter the one the wifi utility gives you that wont work on the portal...
kirkwood
Re: Wifi Install help
That's what I was using. What should I be using?lnevo wrote:Also what ip are you entering? If you enter the one the wifi utility gives you that wont work on the portal...
dbmet
