wave maker and skimmer
keitht
Post by keitht »
I would like to set ports 5 and 6 to random and port 1 to turn off with a float switch can this be done?
If so what codes need to be replaced and with what.
I want my skimmer to turn off when skimmate container is full.
Thank you
Keith
Re: wave maker and skimmer
Try this:
    ReefAngel.WavemakerRandom1( Port6,60,100 );
    ReefAngel.WavemakerRandom2( Port5,60,100 );
    ReefAngel.Relay.Set( Port1, ReefAngel.HighATO.IsActive );
keitht
Post by keitht »
Still not working for me where do i put this I keep getting an error.
You need to place it in the loop() section.
What is the error you are getting?
Actually... I just noticed a typo... :(
Use this:
  ReefAngel.Relay.Set( Port1, ReefAngel.HighATO.IsActive() );
keitht
Post by keitht »
I still cant get it where exactly do I put the code. I load the preloaded and try pasteing it in the ( ) after where it said loop() and i get an error
Watchdog Timer
Version Menu
Dimming Signal
Extra Font - Medium Size (8x8 pixels)
Date/Time Setup Menu
Standard Menu
RA_Preloaded:32: error: variable or field 'loop' declared void
RA_Preloaded:32: error: expected `)' before ';' token
RA_Preloaded:33: error: expected constructor, destructor, or type conversion before '.' token
RA_Preloaded:34: error: expected constructor, destructor, or type conversion before '.' token
RA_Preloaded:35: error: expected unqualified-id before ')' token
What am I doing wrong and I cant open the wizard on my netbook.
Put it after the { after void loop().
Like this:
Rest of the code...
