WiFi Problems ...Again!!
cjrudy
Post by cjrudy »
I was hoping the latest firmware upgrade to 4.0 would finally solve the wifi issues once and for all, but I guess not.
I upgrade the firmware a week ago and have had to reboot the wifi at least 3-4 times.
At least with the older firmware it only needed to reboot a few times a month, maybe I need to downgrade. :(
Re: WiFi Problems ...Again!!
Or Ethernet and cheap ddwrt router repeater bridge ;)
Could it be the router?
I've heard of some other users that had problems with some routers and not with other ones.
Also, make sure you are using WPA2-PSK with AES encryption.
Can you post the "get e" dump?
cjrudy
Post by cjrudy »
I can post get e later when I get home.
The router is a new netgear, I doubt that's the issue considering I had less issues with the older firmware
cjrudy
Post by cjrudy »
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2013.05.22 06:53:51 =~=~=~=~=~=~=~=~=~=~=~=
<4.00> get e
wifly-GSX Ver 4.00.1, Apr 19 2013 11:48:31 on RN-131
Beacon=100
Reboot=0
IF=UP
DHCP=ON
IP=10.0.0.2:2000
NM=255.255.255.0
GW=10.0.0.1
HOST=198.171.134.6:80
PROTO=TCP,
MTU=1524
FLAGS=0x6
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=
CLOSE=
REMOTE=
FlushSize=1420
MatchChar=0
FlushTimer=10
IdleTimer=3
CmdChar=$
DNS=10.0.0.1
Name=www.reefangel.com
Backup=backup2
Lease=300
FTP=198.175.253.161:21
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=80
FTP_mode=0x0
SSID=NETGEAR07
Chan=0
ExtAnt=0
Join=1
Auth=OPEN
Mask=0x1fff
Rate=12, 24 Mb
Linkmon-Infra=5
Linkmon-AP=0
Passphrase=xxxxxxxxxxxxxxx
EAP_Id=
EAP_User=
SleepTmr=0
WakeTmr=0
Trigger=0x10
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
LaunchStr=
TimeEna=0
TIMEADR=129.6.15.28:123
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x2
Cmd_GPIO=0
Yeah, I don't see anything wrong with it.
Are you using WPA2-PSK with AES encryption?
