Web Banners
Would you like to help?
PostPosted: Fri May 24, 2013 3:55 pm
This should give you an idea.
I need to clean it up and optimize the SQL queries, but never had a chance...
banner_3.zip
(10.59 KiB) Downloaded 260 times
PostPosted: Fri May 24, 2013 10:10 pm
cool thank you..
PostPosted: Sat Feb 22, 2014 12:25 am
Ok I tried to update my signature but it says I can't post links and to change or remove reef angel dot com, what gives?
PostPosted: Sat Feb 22, 2014 6:00 am
Think you need to have 5 posts...
PostPosted: Sat Feb 22, 2014 9:03 am
Spam couter-measure feature.
It won't let you post links until you reach a certain number of posts.
I removed the restriction on your profile and you should be able to post links now :)
PostPosted: Sat Feb 22, 2014 6:03 pm
Perfect much appreciated.
Sent from my SPH-L900 using Tapatalk
PostPosted: Mon Dec 08, 2014 8:03 am
Any ideas why my web banner doesn't update?
portal ans IOS App working good.
My web banner stay at 2012.
[img]http://forum.reefangel.com/status/banner_4.aspx?id=Xender&t=1[/img]
Fresh Water Aquarium 180*60*80
Salt Water Aquarium 60*60*60
PostPosted: Mon Dec 08, 2014 9:59 am
It was the last time your controller sent data to the server.
Maybe you enabled the portal key in the portal settings and never updated your code.
Try disabling the key.
PostPosted: Mon Dec 08, 2014 10:41 am
Nice it's was that !thanks!
Previous
Return to Tutorials
