rimai wrote:How about this one?
wow, looks great, will add it in tonight.
Just released. Enjoy.Xender wrote:So bad I can't test it until I've got the librairies fixes push for http errors
It was your work that made it easy.dmolton wrote: -Some type of graphing capability would be cool..
-Maybe provide a way to set a limited number of internal memory values (Dim%, on/off light times, wavemaker intervals etc..)
-ATO status.
The app is just called Reef Angel, I will let everyone know when it is published.Chris wrote:Prob a silly question but what's the app called so I can keep an eye open.
And did you get the push notifications going?
Good job guys. This will make the RA THE best on the Market. You can do so much more than other controllers
Nice work guys. What will you think of next.
DoneXender wrote:We need authentification also in the settings.
good job!
WifiAuthentication("xender:test");
YesXender wrote:Cool !!!
So I need to put this line in my pde? :Code: Select all
I tried it with mine and the Client no longer connects. Dave will probably just need to add it into the next update.Xender wrote: When can we have this feature in Client Suite? Because if I do that, my Client Suite won't work anymore right?
Good job !
The wifi authentication is being worked on in the Client right now. The next release will be coming out very shortly.Xender wrote:Cool !!!
So I need to put this line in my pde? :When can we have this feature in Client Suite? Because if I do that, my Client Suite won't work anymore right?Code: Select all
Good job !
Currently waiting for Apple's approval. As long as they don't find anything wrong should be available early next week.Rey wrote:Where can i get this App?
Not in this first version but I am working on adding that now. Trying to use it as justification with the wife to buy an Ai Nanoreefer wrote:Hope I can see slider for LED dim. control. Looking forward to getting app.
wolfador wrote:Not in this first version but I am working on adding that now. Trying to use it as justification with the wife to buy an Ai Nanoreefer wrote:Hope I can see slider for LED dim. control. Looking forward to getting app.
binder wrote:A suggestion would be to make the temp work better with Celsius. Also you make want to improve the temp setting so you have the decimal in it. Just a suggestion.... Otherwise looking good.![]()
binder wrote:You know, you could clean up that interface some. Maybe add in the units and all.
Yeah, I'm being nit picky....don't want you to think you can "rest & relax" now. haha
First the AI nano and now a macbook air...what next??wolfador wrote:Its okay, I bought a MacBook air yesterday so I can work on this at all times
binder wrote: First the AI nano and now a macbook air...what next??
