Multiple on/off times
Re: Multiple on/off times
Actually, if you look closely, it's the other way around...
The scheduling is 1st and the override is 2nd.
Thanks Roberto.
Again I'll try it when I get home from work tonight.
How do you mean, Roberto?rimai wrote:Actually, if you look closely, it's the other way around...
I meant that your code comes in 2nd and not the 1st as he was thinking.
Oh, OK.
And thanks for the original framework for that code.
I added what you asked at the top and replaced the other code with what you gave me and I'm getting the following error...cosmith71 wrote:ReefAngel.Relay.Status returns a 0 for off and a 1 for on (boolean, true/false) so you can't just add 120 there.
Try this:
This goes near the top right above ////// Place global variable code above here
Remove this:Code: Select all
unsigned long ATOUpdate=0;
And try this instead:Code: Select all
if (ReefAngel.Relay.Status(Port5)) ReefAngel.Relay.Off(Port6); else ReefAngel.WaterLevelATO(Port6,720,29,31);
--ColinCode: Select all
if (ReefAngel.Relay.Status(Port5) && ATOUpdate==0) // Check to see if port 5 is on and update time is empty { ATOUpdate = now(); // If so, set the update time to now ReefAngel.Relay.Off (Port6); } // and turn off the ATO pump if (now() - ATOUpdate >= 120 && ATOUpdate != 0) // If it's been 120 sec, and the update time is NOT empty { ATOUpdate = 0; // Empty out the update time ReefAngel.WaterLevelATO(Port6,720,29.31); } // and turn the ATO sensor back on
Steves_Custom_Wave_Sketch.cpp: In function 'void loop()':
Steves_Custom_Wave_Sketch:78: error: no matching function for call to 'ReefAngelClass::WaterLevelATO(int, int, double)'
C:\Users\Steve\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:322: note: candidates are: void ReefAngelClass::WaterLevelATO(byte, int, byte, byte)
C:\Users\Steve\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:353: note: void ReefAngelClass::WaterLevelATO(byte)
Try this:
I think you typed wrong....
That was it. I wasn't even looking there because the error seemed to be referring to something different.rimai wrote:I think you typed wrong....
The 7pm cycle is coming up so I'll see what happens.
I got to start figuring this stuff out. I hate asking for help like this.
Thanks Colin and Roberto.
If you look at the error code, it gives exactly where the problem is:
That is the line in your code that is causing the error.
OK. I will try harder next time.
I was in a bit of a rush to get that uploaded before the 7pm cycle, so I can see how it works, because the next one is at 1am and I won't be awake to watch that one.
Oops. Sorry!
Not your fault Colin.cosmith71 wrote:Oops. Sorry!
Your original code had ReefAngel.WaterLevelATO(Port6,60,75,79);
I changed it to be the settings for my WaterLevlATO which is
I must have typed it wrong while I was doing other stuff at work.
Thanks for the code thought it seems to be working perfectly.
Just finished the 7pm cycle and the ATO did not kick in when the water exchange stopped at 7:20 and the level in the sump was still at 28% because all the water had not returned to the sump yet.
Final step is going to be rewiring the controller that came with the NatuReef De-nitrification chamber so the dosing pump can be plugged into the RA relay.
It won't be hard I looked at it over the weekend, but didn't want to do it until I knew all the other parts were working properly.
Glad it's working for you!
Colin;
Something isn't working with delay for the Water Level.
My water level has been at 26% all morning and the ATO has not turned on to bring the level up.
It's supposed to turn on at 29% and off at 31%
Something in the delay we set up yesterday is not turning the sensor back on.
And
ReefAngel.StandardLights( Port1,12,0,22,0 );
ReefAngel.StandardLights( Port2,13,0,21,0 );
ReefAngel.Relay.Set( Port3, !ReefAngel.Relay.Status( Port1 ) );
ReefAngel.StandardLights( Port7,13,0,21,0 );
ReefAngel.Relay.Set(Port5,(now()-3600)%21600<1200); // Runs for 1200s every 21600 seconds
ReefAngel.Relay.Set(Port8,((now()-3600)-1200)%21600<1200); // Runs for 1200s every 21600 seconds with 1200s offset
ReefAngel.WaterLevelATO(Port6,720,29,31); } // and turn the ATO sensor back on
ReefAngel.PWM.SetActinic(MyCustomWave(50));
if( ReefAngel.DisplayedMenu==FEEDING_MODE ) ReefAngel.PWM.SetActinic(0);
if( ReefAngel.DisplayedMenu==WATERCHANGE_MODE ) ReefAngel.PWM.SetActinic(0);
if (hour()<12 || hour()>=22) ReefAngel.PWM.SetActinic(30);
And
ReefAngel.WaterChangePorts = Port4Bit | Port6Bit;
//Set Standard Menu
ReefAngel.AddStandardMenu();
ReefAngel.Relay.On( Port4 );
ReefAngel.Portal( "Sacohen","Seth0310" );
int x,y;
// Parameters
// Water Level
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,66, "WL:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,66, ReefAngel.WaterLevel.GetLevel() );
// Main Relay Box
// Date and Time
byte MyCustomWave(byte maxspeed)
static byte randomspeed=0;
if (now()%11<5)
return randomspeed;
else if (now()%11>=5 && now()%11<10)
return maxspeed;
randomspeed=random(35,maxspeed);
return 0;
I'm not 100% sure, because I'm not at home to look at the head unit.
I only have access to the Portal & the Reef Angel Client, would it show me a time out on either of those?
I don't think it is because if I look at the relay activity Port6 has not activated since Thursday May 28th at 7:24 am and when I came home from work yesterday it was at the 32% level.
We should add ato timout and overheat flags to the r99 output..Sacohen wrote:I'm not 100% sure, because I'm not at home to look at the head unit.
Yeah, I even created a new variable to hold the status all flags
ReefAngel.Flags
It currently holds these flags as declared in Globals.h
// Flags bits
#define ATOTimeOutFlag 0
#define OverheatFlag 1
#define BusLockFlag 2
#define LightsOnFlag 3
I just need to put them in /r99 and SendPortal functions.
ReefAngel.Flags
// Flags bits
Doesn't it say something on the head unit if it was in a timeout?
I was using the head unit most of the night yesterday and didn't notice and warnings, the screen looked normal to me.
You would have a red light on the head unit. Do you have the Android app? You can clear it remotely.
The status light would be red?
If that's the case then there is not an ATO time out. I did not see that yesterday.
No I don't have the Android app. I'm not that far into the 21st century yet.
I still have an old Samsung Gravity 3.
My next phone will probably be an Andriod or IPhone when my contract runs out in a couple of weeks.
Ok. I got home and checked and the Status light was not on, just to be sure I went into the menu and cleared the ATO timeout and it still has not started topping off the water.
The water level is at 25% and I know no water went in today because I happened to mark the level it was on the storage tank when I left this morning and it is still at that level.
So something in the new code is not resetting the ATO to start.
I don't know enough to figure it out yet.
The problem is here...
This is the block of code where your ato is being called.. But it is only called one cycle when the ato update is reset.
ReefAngel.WaterLevelATO(Port6,720,29,31); // and turn the ATO sensor back on
I rearranged it a bit to be more readable for me,
This is broken too as its only going to cancel your ato port only for one cycle of loop
ReefAngel.Relay.Off (Port6); // and turn off the ATO pump
Give me a few minutes to code up a solution...
Ok try this
ReefAngel.WaterLevelATO(Port6,720,29,31); // Enable ATO the ATO
if (ReefAngel.Relay.Status(Port5)) // Check to see if port 5 is on and update time is empty
if (now() - ATOUpdate < 120) // If it hasnt been 120 seconds turn off the port
Yes, somehow the WaterLevelATO is never being called on to begin with. Deleted somehow?
Oh, and sorry Steve. Massive fail on my part.
No problem man.
At least you tried, more than I can do right now.
If it got deleted it may have been my fault.
