anolog expansion
anolog expansion
im going through the set up process so im going to have alot of questions. the instructions are for pwm expansion but i got the anolog expansion, do i go throug the same process and use the pwm set up method?
Re: anolog expansion
ok just wanted to make sure i dont mess something up here. thanks. probably gonna have (alot) more questions to come.
ok these instructions are pretty slim it doesnt tell me what to do after i load the code. i click the joy stick and and the option list has changed. theres no light option i got feeding water change apo clear overheat clear ph cal date time and version. Is this normal? the main screen shows pwm expansion with cho ch1 ch2.
I think you are talking about the test code in the manual, right?
That's just a test code and will do nothing more than output a certain % for a certain channel.
You can check the % shown on the screen and the output of that channel will follow.
For a code that will do something you want, please use the wizard.
Ok thanks that's what I needed, got the lights up and running only thing left is ATO floats and wifi
