Weather Simulation for Dimming expansion module
Re: Weather Simulation for Dimming expansion module
Watchdog Timer
Version Menu
Simple Menu
Binary sketch size: 20,366 bytes (of a 258,048 byte maximum)
C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -P\\.\COM3 -b115200 -D -Uflash:w:C:\Users\CHRIST~1\AppData\Local\Temp\build1339424212411784875.tmp\sketch_jun02b.cpp.hex:i
Using Port : \\.\COM3
Using Programmer : stk500v2
Overriding Baud Rate : 115200
avrdude: Recv:
avrdude done. Thank you.
tried loading and got this error
Watchdog Timer
Version Menu
Simple Menu
avrdude: Recv:
If its from the original code it will assume that you are in GMT. So that makes things a but tricky.
That error usually needs cable reseated or even a reboot required (issues with serial port)
how do you reboot? also how would i set it to my time zone?
Make sure you set the controller to Reef Angel w/optiboot. Got timeout errors too when I tried to upload until Roberto said to set it to that option.
And yes, regardless of the coordinates you enter, it should adjust it to match your timezone.
ok cool thanks will give it another go
and presto it loaded without errors....now we will see if everything works as it should.....AWESOME!!!
ok so i loaded the program and lights were on for a few mins then they just completly shut off, my whites are at 8% and lights should kick off at 10% but my blues are showing at 16% so they should still be on. i also staggard my lights to go at different times left should be 30mins before middle and middle 30 mins before right. the only thing i would think that would cause that is the flicker settings? anyone agree or disagree?
YOU MUST READ EVERY WORD IN THIS SECTION IN ORDER TO APPROPRIATELY CONFIGURE THIS PROGERAM- READ EVERY LINE BELOW///
byte ChMax[]={102,89,102,89,102,89,0,0};//Incremental value (Max-flicker) above flicker you want as max intensity (!!!!!!! Light Set Point is ChMax PLUS Flicker !!!!!!)
byte flicker[]={29,29,29,29,29,29,0,0};//need to input actual values here for flicker point on all channels in PWM expansion box
also do i need to change anything with my original light schedual, will that interfere with this coding? reason i ask is since i loaded the new coding it should off set my lefts by 30 mins each from the way i set them up but all whites are reading same percent and all blues are reading same percent almost like my wizard set up for lights is interfering with this code?
Did you modify the ChOffset settings? Those are what will determine how much (if any) delay and advance is configured for sunset and sunrise.
As far as I know, any settings you coded into your RA module with the wizard should have no effect, since the Weather Sim code takes over the PWM dimming completely.
yes i set the offset by 2hrs
int Choffset[]={
-7200,7200,-7200,7200,-6600,6600,-6600,6600,-6000,6000,-6000,6000,0,0,0,0};
now when i woke up this morning my lights look like there on full power but my RA display and the portal are showing that my blues are at 4%. so it seems the wizard is still working the display but the coding is working the expansion. only question i have is why is it so bright this early in the morning? is it going to get brighter? how do i tell what % its really at?
int Choffset[]={
According to the tutorial text, the lights should hit ChMax around noon time so they shouldn't have been at max brightness that early in the morning. As for getting the % value to output to the controller display, we'd have to wait for rufessor to wander back in here for assistance.
well its now 2:43 and the lights havent gotten any brighter they may have dimed a little hard to tell. I did get some cloud action kinda freaked me out at first thought something was going crazy and burning up the way it was going dim bright dim bright but then it went bright and stayed. i dont know if i put something in the code wrong, most likely did. if anyone can see anything here is the parts i changed in the code
boolean Wchannel[]={0,1,0,1,0,1,0,0}
byte DimOrder[]={0,0,1,1,0,0,0,0};
//set all channel positions that you would like to use for the lightning strike effect to 1 (0-5 are PWM channels 6,7 are Main PWM outs)- and channels with a 0 are not used in strike
byte StrikeChannel[]={0,0,0,1,0,0,0,0};
byte MoonCh[]={0,0,0,0,0,0,0,0};/
int Choffset[]={
// NOW SET YOUR LATIDTUDE AND LONGITUDE COORDINATES as Degrees, Minutes, Seconds of Lat and Lon
//If Your NORTH of the equator your LONGITUDE must START with a NEGATIVE number (the rest are positive) e.g. All of North America, Europe, Russia etc are negative
//If Your EAST of the Prime Meridian your LATITUDE must START with a NEGATIVE number (the rest are positive), e.g. Most of Europe, All of China, India, Austraila, Russia etc are negative
latitude=dmsToSeconds(20,54,00);//United States of America- Salt Lake City, local time is -7 hours GMT
longitude=dmsToSeconds(-155,35,00);
that LAT and LONG is Hawaii and im in Georgia. While sitting here typing this two more clouds passed. they seem to go really fast.
int Choffset[]={
heres a video of the clouds on my set up. kinda hard to see but its more noticable in person. I think the iphone auto adjusted when the lights changed.
http://s1302.photobucket.com/user/jjdez ... 4.mp4.html
Well I think I figured out what I did. In the time offset I wanted the lights to come on later and turn off later. I put a negative infront of the on time so instead of them turning on later there turning on earlier. Whooopsy
Yeah the wife had to get up at 5:30 and said lights were on that's when I put two and two together. Might still have to play with it to get it to come on at the right time. Thanks for everyone's help. I will post a video of the lightening when I can catch it
is there anyway to code this so that the light percent will display on the lcd, portal, and apps?
ok got another question on this, i read through the cloud dimming part and it says to pair the lights you want to dim together with 0's and 1's. I have three different lights that go from left to right on my tank i put the left lights (blues and whites) as 0 then put the center lights (blues and white) as 1 then the right lights (whites and blues) i put as 0. does that make them dim with the left lights? if so is there a way to make them dim as a third set, so it would go left lights center lights then right lights? could i plug the number 2 in there or would that mess the code up? any help would be greatly appreciated.
Pretty sure it's only 0 or 1, so yeah anything that's 0 will dim together and then anything with 1 will dim 400ms (if I recall correctly) after it. You can do left and center as 0 and then the right as 1, it should still look like a sweep.jjdezek wrote:ok got another question on this, i read through the cloud dimming part and it says to pair the lights you want to dim together with 0's and 1's. I have three different lights that go from left to right on my tank i put the left lights (blues and whites) as 0 then put the center lights (blues and white) as 1 then the right lights (whites and blues) i put as 0. does that make them dim with the left lights? if so is there a way to make them dim as a third set, so it would go left lights center lights then right lights? could i plug the number 2 in there or would that mess the code up? any help would be greatly appreciated.
Wow-
Sorry... busy doing at work and didn't catch the Q's, but you guys rock. Corresponded a bit my PM/email with jjdezek re the dimming order.
Currently it only accepts a 0 or a 1 (e.g. two channel "bins" with the 0 channel getting the first dim value).
As for the dimming being choppy, that should not occur. The update frequency was played with during development to ensure it DID NOT look choppy. Are you still seeing this? Because I can video it and look frame by frame and not see incremental intensity increases. Maybe you hit on a combo of dimming circuitry thats different from mine. But the update frequency is something like <300 msec (I can look it up exactly just not sitting in front of the code).
Any other Q's please post and I will monitor this a bit more carefully.
I'm going to try it as 0,0,0,1,1,1,0,0 set up which will split the center lights in half. Thanks
Not sure what you mean by choppy. I do get a lot of cloud action that goes bright dim bright dim repeatedly. Thinking I need to reduce the cloud percent.
had perhaps didn't read it correctly, but I thought someone had posted that they could see the lights "flicker" as they changed intensity during a cloud/storm. That should not be visually apparent.
If you want to reduce cloud number, you can do this by changing a couple things
byte CloudsMax=10;//DONT INCREASE BEYOND 10 or it will DIE
one could lower that number...
byte CloudsMin=4;//use 2 as a minimum
One could lower this number but please note the suggest minimum value of 2- else the clouds may become quite long or something worse may happen...
one could lower that number so that on some days there are NO clouds...
I think that should cover mods to the frequency of days with clouds and the number of clouds per day.
For those a bit more adventurous. The total duration of any cloud is random, twice over. The percentage of the total day length that will be occupied by clouds is a decimal fraction of the day length and is calculated in this segment. If you look at it carefully you will see that the overcastMin and overcastMax values can be changed by altering the denominator in their calculation. This will then alter the possible range of fractional day lengths that will be cloudy that day. I tried to comment this originally to give a general idea of what its doing the math is pretty simple to understand. Perhaps look at the last bit first, e.g. how the value for Overcast is calculated... then you will see how changing the denominator for OvercastMin and Max will alter total length of day thats cloudy.
Then, in a segment not shown the placement (e.g. when in the day) and the relative duration of every cloud is further randomized.
So, if you change the %chance of a cloudy day and alter it from 100 you will get "boring days" with no clouds.
If you like the clouds but want them to be fewer change the max and min cloud # values.
If you want them to be on average shorter, you need to play with the last segment I just posted and think about what those values are doing.
The values for min cloud length in the comments are dependent of course on the number for the day, the day length etc... so the comments may not exactly reflect the values in the code- they should however inform what the code is doing more or less
Overcast=(Overcast/100);
Welcome back! And I'm still seeing it and by choppy I mean that the dimming steps are fairly discernible. It's not SUPER noticeable, I'm sure most people who see it won't be bothered, but it's not as smooth as say, a smartphone LCD dimming according to ambient light.rufessor wrote:Wow-
For our reference, I'm using a DIY fixture with Meanwell LDD drivers, Meanwell 48v power supply, and Cree XT-E LEDs.
Let me look into the update interval. I can change it I think.... but I have to look carefully- I believe a few things run off this...
Hi,
I just make some changes in the code as per my liking & i am getting an error as invalid suffix "0" on integar constant.
Don't getting whats wrong m doing.
here is my code
Witing for the help
here is my code
//By Matthew Hockin 2012.
//SWFLTEK library functions, #includes, and #define were copied directly from the Epherma library
//Epherma (SWFLTEK.com) was written by Michael Rice- thanks Michael it works great.
//If you copy from this (its all open source) please
//acknowledge Michael for SWFLTEK library code (obviously labeled) or Matthew Hockin (for the rest).
#include <avr/wdt.h>
#include <stdlib.h>
#include <math.h>
//***********************************ARRAYS YOU MUST MODIFY TO MAKE YOUR TANK SET UP WORK*****************************
//YOU MUST READ EVERY WORD IN THIS SECTION IN ORDER TO APPROPRIATELY CONFIGURE THIS PROGERAM- READ EVERY LINE BELOW///
byte ChMax[]={215,220,215,220,211,0,0,0};//Incremental value (Max-flicker) above flicker you want as max intensity (!!!!!!! Light Set Point is ChMax PLUS Flicker !!!!!!)
byte flicker[]={31,31,31,31,40,0,0,0};//need to input actual values here for flicker point on all channels in PWM expansion box
boolean Wchannel[]={1,1,0,0,0,0,0,0}; //use 1 to designate white channel (i.e. off during storm and used for lightning). Array corresponds to PWM channel 0-5 in order
//Array to give direction to dimming. e.g. DimOrder[]={0,0,1,1,0,0} (cloud chase effects, just group channels you want to dim together during a cloud or storm
//(which is zero or 1 will change who dims first). set them all to 0 if your tank has no left/right or front/back lights.
byte DimOrder[]={0,0,1,1,1,0,0,0};
byte StrikeChannel[]={1,1,1,1,1,0,0,0};
byte MoonCh[]={0,0,0,1,1,0,0,0};//place a 1 in the array position of all lighting channels you would like to use a moon lighting (this does not preclude their use in other phases (day, storm etc)
//**********************************DONE CHANGING THINGS HERE BUT YOU MUST CHANGE ChOffset array IN CalcSUN function******
// arc-seconds per radian
#define _sec_rad 206264.806247096370813
// axial tilt of earth at epoch, in radians
#define _tilt 0.409092804222329
// tropical year in seconds... rounding error accumulates to 26 seconds by the year 2136
#define _tropical_year 31556925
// 'zenith' of rising (setting) sun in radians (360 - 2 * 90.833 degrees)
#define _zenith 3.11250383272322
//Unless your planning on editing the program DO NOT CHANGE ANYTHING HERE
long latitude, longitude;
byte TrueIntensity[8];//array used to place hold final write values for PWM intensity setting
long elapsedTime;//used multiple places as elapsed since midnight
long newDay;
unsigned long rise;//time in seconds from the year 2000 (GMT) for sunrise
unsigned long set;//time in seconds from the year 2000 (GMT) for sunrise
long CloudMaster[20];// Set up array to hold start and end times for clouds for the day-
long midDay;// exactly 1/2 way between rise and set, i.e. solar noon for latitudes <60 close enough for us...
byte PWMports[] ={
3,5,6,9,10,11};
byte ChannelValue[8];// Array to store output of insolaiton which may be modified and stored in TrueIntensity which is used to write to the PWM channels
byte cmdnum=255;
byte datanum=255;
byte dow=0;//day of week
boolean InsolationAdvance;//when true we recalculate light intensity during clear sky (every 3 seconds seems more than often enough)
//END HEADER/Global Variable declaration//
//Setup
void setup(){
Serial.begin(57600);
Wire.begin(8);
pinMode(3,OUTPUT);
pinMode(5,OUTPUT);
pinMode(6,OUTPUT);
pinMode(9,OUTPUT);
pinMode(10,OUTPUT);
pinMode(11,OUTPUT);
wdt_enable(WDTO_1S);
unsigned long seed=0, count=32;
while (--count){
seed = (seed<<1) | (analogRead(5)&1);
randomSeed(seed);//start random generator at a different point each time (not perfect but whatever its gonna be pretty damn random)
//End Setup
//Loop
void loop(){
elapsedTime=(now()-newDay);//Elapsed time is seconds from midnight of today- local processor time.
wdt_reset();
if (cmdnum!=255){
ProcessCMD(cmdnum,datanum);
cmdnum=255;
datanum=255;
if (dow!=day()){ //used to see that were in a new day and need to recalculate sunrise and sunset
CalSun();
dow=day();
if ((millis()-lastmillis)>=100){
counter+=1;
StormAdvance=true;
if (counter==0){
InsolationAdvance=true;//so that it runs on start up to provide light immediately
if (counter%30==0){
if (counter==210) counter=0;
if (InsolationAdvance==true) Insolation();//calculate clear sky solar intensity as the day advances
Weather();//run the weather overlay (cloud, storm)
if (StrikeNow==true){
byte intensity;
intensity=random(180,256);// this little bit should generate a randomly bright flash variation between the series of flashes in StrikeMaster
for (byte b=0; b<6; b++){
if (StrikeChannel[b]==1) analogWrite(PWMports[b],intensity);// set all strike channels to intensity of strike
if (StrikeCount==(StrikeNumber-1)){
StrikeNow=false;
StrikeCount=0;
for (byte a=0;a<6;a++){//using all prior mods to light intensity (Insolation-->Cloud-->Storm) lets make some light
//End Loop
//Standard PWM Functions Receive/Process
wdt_reset();
if (howMany==5){
cmd1=Wire.read();
cmd2=Wire.read();
cmd3=Wire.read();
cmd4=Wire.read();
cmd5=Wire.read();
cmdnum=cmd4;
datanum=cmd5;
//Serial.println(cmd4,DEC);
//Serial.println(cmd5,DEC);
else{
for (int a=0;a<howMany;a++){
Wire.read();
wdt_reset();
//End Standard Functions
//Start of sunrise, sunset and cloud calculations- runs on reset and once a day thereafter.
void CalSun(){
//*********************YOU NEED TO CHANGE THESE VALUES Read instructions in their ENTIRETY and CAREFULLY change to values for your tank and geographical region***************************
int Choffset[]={
60,0,60,0,600,-600,0,0,0,0,0,0,0,0,0,0};
latitude=dmsToSeconds(-26,3O,00);//India- Kanpur City, local time is 5.30 hours GMT
longitude=dmsToSeconds(-80,18,00);
//**********************ok now were done changing things IF YOU CHANGED the Top part of the GLOBAL variable decleration AND this... your FULLY configured and ready to load********************************************
if (dow==0){//if the controller has resarted we need to find midnight
long hours, minutes;//store current elapsed local hours as total seconds from midnight
time_t t=now();//store current clock time to parse
hours=hour(t);
hours=(hours*3600);//current hour number 0-23 as seconds
minutes=minute(t);
minutes=(minutes*60);//minutes of current hour as seconds
newDay=now();
newDay-=(hours+minutes);//Convert current local unix epoch time to local unix epoch time of midnight
else if (dow!=0){//if we did not restart but the day is new then it is midnight and were good to go..
newDay=now();
//#define SECS_YR_2000 (946684800) the time at the start of y2k (need to subtract from unix epoch time to bring to Y2K origin
newDay-=946684800;//convert GMT unix Epoch to seconds elasped since 2000 for GMT midnight of today
rise=newDay;//set value to send to SunRise as midnight GMT in seconds from Y2K
set=newDay;//
//Calculate rise time and set time using Epherma Library functions (see end of code)
SunRise(&rise);//call to Epherma function
SunSet(&set);//Call to Epherma functionunsigned long newDay;
/*Serial.print("rise and set= ");
Serial.println(rise);
Serial.println(set);
Serial.print("newDay as seconds since 2000 to todays midnight= ");
Serial.println(newDay);*/
rise=(rise-newDay);// set to elapsed seconds of day
set=(set-newDay);
/*Serial.print("rise and set as elapsed seconds of day= ");
Serial.println(set);*/
newDay+=946684800;//Convert newDay back to unix epoch GMT midnight today (used in loop to determine how far we are into the day)
/*Serial.print("newDay as seconds since since 1970 to todays midnight= ");
Serial.print("elapsed is");
long elapsed=now()-newDay;
Serial.println(elapsed);*/
midDay=(((set-rise)/2)+rise);
if (b%2==0){
ChRiseSet[b]=rise+(Choffset[b]);
ChSlope[b]=(deltaY/(float)(HalfDayLength-(Choffset[b])));
else if (b%2==1){
ChRiseSet[b]=set+(Choffset[b]);
ChSlope[b]=(deltaY/(float)(HalfDayLength+(Choffset[b])));
byte RainMaker=random(1,101);
if (RainMaker<=CloudChance){
return;
long dayLength=0;
for (byte a=1;a<16;a=(a+2)){//determine maximum day length given light on tank that is not moon light, this will yield night clouds and storms (and a storm after dark is severe... always
if (a==0){
if (((set+Choffset[a])-rise)>(set-rise)){
dayLength=((set+Choffset[a])-rise);
else dayLength=(set-rise);
else if (a!=0){
if (dayLength<((set+Choffset[a])-rise)){
byte CloudsMax=10;//DONT INCREASE BEYOND 10 or it will DIE, or increase array size to handle it (among other things)
// split the total lenght of time for clouds into equal segments and then to randomly chop or add time to the
//segments such that cloud length is variable. Then distribute into random parts of the day and fill array with start,duration pairs for clouds
int CloudLength;
float CloudFraction=0;
float SunFraction=0;
for (byte a=0; a<20; a++){
CloudMaster[a]=0;
if (a%2==0){
if (b==0){
if (a==0){
else if (a<((CloudsTotal*2)-2)){
b++;
else if (a==((CloudsTotal*2)-2)){
SunFraction=(2-((float)CloudMaster[0]/(float)SunSegment));
else if (b==1){
if (c==0){
c++;
else if (c==1){
for (byte a=0;a<20;a++){
//reframe array to generate cloud start, cloud end, cloud start, cloud end
else {
/*Serial.println("here is cloud master in is entirety as start and end pairs");
if (a%2==0){
Serial.print("Start time=");
else {
Serial.print("End time=");
}//END SunCalc FUNCTION
void Insolation()
use flicker points to adjust minimum intensity to stable light. Turn off lights after set or before rise etc.
if (elapsedTime<=midDay){
byte c=0;//loop counter
for (byte b=0;b<16;b=(b+2)){
if (elapsedTime>=ChRiseSet[b]){
secSoFar=(elapsedTime-ChRiseSet[b]);//just account for length of every channel 1/2 day and switch at midDay
ChannelValue[c]=flicker[c]+ChMax[c]*(-cos(PiHalf+(ChSlope[b]*secSoFar)));
if (MoonCh[c]==1){
byte MoonToday=MoonPhase()*0.5;//SCALE FACTOR to DIM moon setting for use with HIGH power LED as moon light
if (MoonToday==0) ChannelValue[c]=0;
else if (MoonToday<flicker[c]) ChannelValue[c]=flicker[c];
else ChannelValue[c]=MoonToday;
else if (MoonCh[c]==0){
ChannelValue[c]=0;//its dark and this is not a moon phase channel
c++;//index by one so we count 0-7 as b goes 0-14 by twos
else if (elapsedTime>midDay){
for (byte b=1;b<16;b=b+2){
ChannelValue[c]=flicker[c]+ChMax[c]*(-cos(Pi+(ChSlope[b]*secSoFar)));
if (MoonCh[c]==1){
c++;//index to count 0-7 as b counts 1-15 by twos.
}//END function
//WEATHER FUNCTION BEGIN
void Weather ()
static byte loopCount;
static float PriorCloudCover; //used to "delay" one side of the tank from the other in cloud passing effects
static long StormStart;
static long StormEnd;
static long CloudEnd;
static byte Severity;
static int StepSize;
static int LastStepSize;
if (Cloud==false){
//Write Insolation values to TrueIntensity so the loop will pick them up and the cloud/storm will get the right data (since intensity changes during the day)
for (byte a=0; a<8; a++){//this must be above the next loop
//Serial.print("We started a cloud and its end is=");
//Serial.println(CloudEnd);
CloudCover=CloudStart(CloudMaster[a]);//CloudStart modifies TrueIntensity to get us to 50% intensity at the start of the cloud effect and also sets cloud=true to bypass this
Counter=0;
loopCount=1;
LastStepSize=0;//zero out cloud random walk variables
StepSize=0;//zero out cloud ranodm walk variables
return;//exit having started a cloud in CLoudStart routine called above
return;
if (elapsedTime>=CloudEnd){
return;
/*Use fractional intensity to set minimum value for any channel. Dimming is proportional to actual intensity output
and constrained by flicker point. Random walk uses static variable "CloudCover" constrained to 0-100 to represent fractional intensity (i.e. (1-(CloudCover/100))*Insolation SetPoint
if (loopCount==1){
PriorCloudCover=CloudCover; //e.g. PriorCloudCover=CloudCover with no float math to screw things up
LastStepSize=StepSize;
StepSize=(random(5,21));// in Percent% (0-100) This is how much light intensity will change over the loop count interval (this actual time is dependent upon the call frequency of StromAdvance as set in the loop)
if ((random(0,2)!=1)) StepSize=-(StepSize);
if ((CloudCover+StepSize)>=100){//cannot shut off lights more than 100% so limit here
StepSize=(100-CloudCover);//
Counter++;
else if ((CloudCover+StepSize)<=0){//cannot be brighter than 100% so since were in a cloud dont "limit" it but reflect it back down
if (Counter>=50) Counter-=random(-1,2);//since we got bright... lets further delay and randomize storm occurence
CloudCover=CloudCover+StepSize;
if ((Counter>=60) && ((CloudEnd-elapsedTime)>=300)) {//if Counter (indexes when cloud cover reaches 100) has accumulated and we still have time lets make a storm
if (StormCount>=1){//if we can have storms in this cloud (random- statisticly 1/3 clouds = no storm, 1/3 = 1 possible storm, 1/3 = 2 possible storms)
byte RandomStorm;
RandomStorm=random(0,11);//this randomizes for longer clouds without storm, avg cloud is much longer prior to storm occuring- thus short clouds will not generally have a storm
if (RandomStorm>=4){
StormCount-=1;//count down by 1 the number of storms in this cloud- this will not roll the byte since the loop requires it to be at least 1 to ever subtract here.
Counter=0;//reset this variable since Storm loop uses it as well.
Severity=StartStorm(LongestStorm, IsStorm, StormEnd);
loopCount=1;//reset counting loop for the storm
else if ((Counter>=60) && ((CloudEnd-elapsedTime)<300)){
Counter=0;//just reset the counter (does not really matter in this case but its clean)
for (int a=0;a<8;a++){
if (ChannelValue[a]==0) TrueIntensity[a]=0;// if were in an evening storm dont reset intensity (it would go to flicker point and possibly flicker)
else if (DimOrder[a]==0){
TrueIntensity[a]=(flicker[a]+(((float)(ChannelValue[a]-flicker[a]))*(1-((CloudCover-(StepSize-(StepSize/4)*loopCount))/100))));
else if (DimOrder[a]==1){
TrueIntensity[a]=(flicker[a]+(((float)(ChannelValue[a]-flicker[a]))*(1-((PriorCloudCover-(LastStepSize-(LastStepSize/4)*loopCount))/100))));
loopCount++;
if (loopCount>4) loopCount=1;
return;
IsStorm=false;
Counter=0;
return;
if (loopCount==1){
Counter++;
if (Counter>=2) Counter-=random(0,2);//since we got bright... lets further delay and randomize strike occurence
if (Counter>(Severity+2)) Counter=0;//allow if to accumulate on ocassion to train strike sequences 2-3 in a row but then dump it
if ((Counter>=(Severity+random(-1,4))) && (StrikeNow==false)) {//this is where a storm is triggered. Counter indexes when cloud cover reaches 100 on the random walk
byte RandomStriker;
RandomStriker=random(1,11);
if (RandomStriker>4){
if (a>=(StrikeNumber*2)){
StrikeMaster[a]=0;
if (a%2==0){
if (a==0){
StrikeMaster[a]=random(300,1601);//no need for random here but I am leaving it since I wrote it that way. This must be independent from a=2,4,6 etc...
else {
StrikeMaster[a]=(StrikeMaster[(a-2)]+random(200,1401));//position 0,2,4,6,8.. is strike delay
else if(a%2!=0){
StrikeMaster[a]=random(50,110);//position 1,3,5,7,9... is strike duration (I tried real lightning strike durations and its too short this is adjusted for visual effect
StrikeCount=0;
Counter=0;
if (Severity>5){
for (int a=0;a<8;a++) {
else if (Wchannel[a]==1){//if were in a storm but not a severe storm constrain whites to 50% of Insolation intensity
TrueIntensity[a]=(flicker[a]+((((float)(ChannelValue[a]-flicker[a])/4))*(1-((CloudCover-(StepSize-(StepSize/3)*loopCount))/100))));
TrueIntensity[a]=(flicker[a]+((((float)(ChannelValue[a]-flicker[a])/4))*(1-((PriorCloudCover-(LastStepSize-(LastStepSize/3)*loopCount))/100))));
TrueIntensity[a]=(flicker[a]+(((float)((ChannelValue[a]-flicker[a])))*(1-((CloudCover-(StepSize-(StepSize/3)*loopCount))/100))));
TrueIntensity[a]=(flicker[a]+((((float)(ChannelValue[a]-flicker[a])))*(1-((PriorCloudCover-(LastStepSize-(LastStepSize/3)*loopCount))/100))));
else if (Severity<=5){// severe storms occur throughout the day, but EVERY storm after sunset is severe...
else if (Wchannel[a]==1){//if were white we need to be off in a storm
TrueIntensity[a]=0;
else if (ChannelValue[a]==0){//if this light channel is dark... e.g. after sunset for this channel- it produces no cloud effect
TrueIntensity[a]=0;
else if (Wchannel[a]==0){//if were not shut off in a strom and not after our daylight period (this channel) then we produce storm light sequences.
if (DimOrder[a]==0){//if we dim first... do it
else if (DimOrder[a]==1){//else we dim second
}//end of CWHchannel==0 being true
}//end of for loop in severity <5 == true loop
}//end severity compairson loop no more else statements
loopCount++;
if (loopCount>3) loopCount=1;
}//end of storm if loop
}//End Weather function
//CloudStart drops light intensity to 50% of whatever daylight setting is to start the cloud at 50
int CloudStart(long StartTime){
byte elapsed;
elapsed=(elapsedTime-StartTime);//counts up since we start this at elapsedTime=StartTime and StartTime is fixed
TrueIntensity[a]=(flicker[a]+(((float)((ChannelValue[a]-flicker[a])))*(1-(elapsed*2.5)/100)));
if (elapsed>=20);
Cloud=true;//start the cloud
return 50;//set CloudCover to 50
}//end CloudStart function
//StartStorm sets up duration and severity of storm. Its currently limited to 90-600 sec in length- it will rarely be lower than 3 minutes
byte StartStorm(int MaxLength, boolean& trigger, long& EndTime){
byte LightningIntensity;
int StormDuration;
MaxLength-=120;//remove 2 mins from longest storm so that we end up with 2 minutes of cloud after the storm before the sky clears to daylight
if (MaxLength>720){
MaxLength=720;//modify local variable
StormDuration=random((MaxLength/3),(MaxLength+1));
EndTime=(elapsedTime+StormDuration);//Set by reference StormEnd static variable in weather
else {
StormDuration=random((MaxLength/2),(MaxLength+1));
if (elapsedTime<midDay){
LightningIntensity=random(3,11);//morning storms are generally less severe
else if (elapsedTime>midDay){//afternoon storms are more likely to be severe (every 10-15 sec or less) to about once in a minute or maybe less
if (elapsedTime>(set-rise)){//Storms after sunset are always severe... it just looks too cool!
LightningIntensity=3;
else {
LightningIntensity=random(3,8);
trigger=true;
return (LightningIntensity);
//End Storm Start Function
//Similar to Cloud start but in reverse... now ramp intensity from wherever we were at the end of the cloud to the value set by Insolation
void ClearSky(int CloudPercent, long TerminationTime)
byte elapsed=(elapsedTime-TerminationTime);//Counts up from the scheduled end of the cloud in seconds
float slope=(CloudPercent/30);//Just calculate how much to increment every second to go from CloudCover to clear sky (CloudCover of zero)
float LightAdvance;
LightAdvance=(CloudPercent-(slope*elapsed));//were reducing CloudCover from start to zero over 10 seconds.
TrueIntensity[a]=(flicker[a]+(((float)(ChannelValue[a]-flicker[a]))*(1-(LightAdvance/100))));
if (elapsed>=30){//at this point lights are back to full Insolation setting so cancel the cloud and start waiting for the next one
Cloud=false;//stop the cloud we are now outside of a true condition in the if loop so it will now stay false and lights are back on
IsStorm=false;//just to be redundant this is not called from a storm...
}//End Clear Sky function
byte MoonPhase()
int m,d,y;
int yy,mm;
long K1,K2,K3,J,V;
byte PWMvalue;
m = month();
d = day();
y = year();
yy = y-((12-m)/10);
mm = m+9;
if (mm>=12) mm -= 12;
K1 = 365.25*(yy+4712);
K2 = 30.6*mm+.5;
J = K1+K2+d+59-K3;
V -= int(V/100)*100;
V = abs(V-50);
PWMvalue = 4*abs(50-V); // 5.12=100% 4=~80%
//pinMode(lowATOPin,OUTPUT);
//return (PWMvalue*100)/255; //output is 0-100
return PWMvalue;//output is 0-255
// A big thank you for these library functions. Its great!
//convert degrees to seconds of arc
// decimal degrees
long ddToSeconds(float dd){
return dd * 3600.0;
//Degrees, minutes, seconds
long dmsToSeconds(int d, unsigned char m, unsigned char s){
long ret;
ret = labs((long)d);
ret = ret * 3600L + 60L * m + s;
ret = (d<0L) ? -ret : ret;
return ret;
'Equation of Time'
We use the 'short form equation, which has a theoretical accuracy of about 40 seconds.
The returned value is in seconds.
int equation_of_time(unsigned long dt){
double t;
dt -= 192540UL; // refer to Jan 3 2000 05:29 (first periapsis)
dt %= _tropical_year;
t = dt;
t /= _tropical_year;
t *= 6.283185307179586;
t = -459.27672 * sin(t) + 575.333472 * sin(2.0 * t + 3.588414);
return t;
'Solar Noon' adjusts the passed time stamp to the time (GMT) of local solar noon.
The accuracy is about 40 seconds (set by the equation of time).
void SolarNoon(unsigned long * dt){
long r;
// Set stamp to noon GMT
*dt /= 86400UL;
*dt *= 86400UL;
*dt += 43200UL;
// adjust for equation of time, at noon GMT
*dt -= equation_of_time(*dt);
// rotate to our longitude
r = longitude / 15L;
*dt -= r;
'Solar Declination'
Returns declination in radians
Accurate to within 50 arc-seconds
double SolarDeclination(unsigned long dt){
double y;
y = dt;
y /= _tropical_year; // fractional year
y *= 6.283185307179586;
y=0.006918-0.399912*cos(y)+0.070257*sin(y)-0.006758*cos(y*2)+0.000907*sin(y*2)-0.002697*cos(y*3)+0.00148*sin(y*3);
return y;
Return the period between sunrise and sunset, in seconds.
At high latitudes around the time of the solstices, this could be zero, or all day.
unsigned long daylightseconds(unsigned long dt){
float l, d, e;
long n;
d = -SolarDeclination(dt); // will be positive in Northern winter
l = latitude / _sec_rad; // latitude in radians
e += 60.0 * l * tan(l + d); // latitudinal error
d = tan(l) * tan(d); //
if(d>1.0) return 86400UL;
if(d < -1.0) return 0UL;
d = acos(d);
d /= _zenith;
n = 86400UL * d;
n += e;
return n;
Modify the passed time stamp to the time of sunrise (or sunset if 'set' is non-zero).
Returns 0 to signal 'normal' completion. If the position is in a polar circle, 1 will be
returned if the sun is above the horizon all day, and -1 if the sun is below the horizon
all day.
char SunRiseSet(unsigned long * dt, char set){
unsigned long daylen;
daylen = daylightseconds(*dt);
if(daylen == 86400UL) return 1; // there is no 'night' today (midnight sun)
if(daylen == 0UL) return -1; // there is no 'day' today
*dt /= 86400UL;
*dt *= 86400UL;
*dt += 43200UL; // set the time stamp to 12:00:00 GMT
*dt -= daylen / 2; // sunrise at the prime meridian
if(set) *dt += daylen; // sunset at the prime meridian
//*dt -= longitude / 15.0; // rotate to our own meridian
return 0;
// 'short' forms of SunRiseSet
char SunRise(unsigned long* when){
return SunRiseSet(when, 0);
char SunSet(unsigned long* when){
return SunRiseSet(when, 1);
What did you change and can you paste the compiler error? It should say which line the error is on.
Found it.
You had an O instead of 0 in your latitude
Try this:
Try this:
latitude=dmsToSeconds(-26,30,00);//India- Kanpur City, local time is 5.30 hours GMT
