ReefAngel external web access [GUIDE]
Would you like to help?
PostPosted: Fri May 04, 2012 12:59 am
Hey All,
Attached is my guide to setting up ReefAngel External web access :)
Enjoy and let me know if it helps
EDIT - Using this guide first should make life a bit easier too! - viewtopic.php?f=14&t=3427
ReefAngel External Access.pdf
External Web Access Guide
(237.48 KiB) Downloaded 1061 times
PostPosted: Fri May 04, 2012 5:38 am
Note: Your "Add Custom Service" step should be able to just do Port 2000 to Port 2000 instead of Port 1999 to Port 2001.
Otherwise, nice guide. :)
Also, did you know that http://www.no-ip.com offers the free dynamic service (if you didn't want to pay dyndns)? I personally have accounts with both and they both work just fine for me.
PostPosted: Fri May 04, 2012 7:30 am
binder wrote:Note: Your "Add Custom Service" step should be able to just do Port 2000 to Port 2000 instead of Port 1999 to Port 2001.
cool :)
Problem is my router only offers dynamic DNS from dyndns.org. I can't use a different one :( I wish I couldve
PostPosted: Fri May 04, 2012 1:13 pm
Nice work :D
I will add a link to this from my "where to get started" guide, if that's ok?
PostPosted: Sat May 05, 2012 10:58 am
Sebyte wrote:Nice work :D
With pleasure :)
PostPosted: Tue Jun 04, 2013 11:08 am
Poiromaniax wrote:Problem is my router only offers dynamic DNS from dyndns.org. I can't use a different one :( I wish I couldve
Actually if you choose the dyndns from the dropdown menu and then input the host you get from no-ip.com, it works just the same... It stumped me too for a little while and then figured it's the same.
Hope it helps!
PostPosted: Wed Jun 05, 2013 8:34 am
Hope it helps!
It all depends on your brand of router and the firmware it's on I believe.
As far as I'm aware, you can also get custom firmware to add more dns service providers
Thanks for the info though - hopefully it will help someone out :)
PostPosted: Wed Apr 20, 2016 8:48 pm
So this reef angel cant be used to access from anywhere unless I BUY a dydns thing?
PostPosted: Thu Apr 21, 2016 3:04 am
viewtopic.php?f=20&t=4754
Return to Tutorials
