Hey All,
Attached is my guide to setting up ReefAngel External web access
Enjoy and let me know if it helps
EDIT - Using this guide first should make life a bit easier too! - http://forum.reefangel.com/viewtopic.php?f=14&t=3427
ReefAngel external web access [GUIDE]
- ReefAngel External Access.pdf
- External Web Access Guide
- (237.48 KiB) Downloaded 1481 times
Re: ReefAngel external web access [GUIDE]
Note: Your "Add Custom Service" step should be able to just do Port 2000 to Port 2000 instead of Port 1999 to Port 2001.
Otherwise, nice guide.
Also, did you know that http://www.no-ip.com offers the free dynamic service (if you didn't want to pay dyndns)? I personally have accounts with both and they both work just fine for me.
coolbinder wrote:Note: Your "Add Custom Service" step should be able to just do Port 2000 to Port 2000 instead of Port 1999 to Port 2001.
Problem is my router only offers dynamic DNS from dyndns.org. I can't use a different one I wish I couldve
Nice work
I will add a link to this from my "where to get started" guide, if that's ok?
With pleasureSebyte wrote:Nice work
Actually if you choose the dyndns from the dropdown menu and then input the host you get from no-ip.com, it works just the same... It stumped me too for a little while and then figured it's the same.Poiromaniax wrote: Problem is my router only offers dynamic DNS from dyndns.org. I can't use a different one I wish I couldve
Hope it helps!
It all depends on your brand of router and the firmware it's on I believe.oscarinw wrote:Actually if you choose the dyndns from the dropdown menu and then input the host you get from no-ip.com, it works just the same... It stumped me too for a little while and then figured it's the same.Poiromaniax wrote: Problem is my router only offers dynamic DNS from dyndns.org. I can't use a different one I wish I couldve
Hope it helps!
As far as I'm aware, you can also get custom firmware to add more dns service providers
Thanks for the info though - hopefully it will help someone out
So this reef angel cant be used to access from anywhere unless I BUY a dydns thing?
