Is there documentation somewhere on all the Xml tags the portal can spit out and how the values can be interpreted? I have looked at some code, but just wondering if there's a doc I can reference as well?
portal xml documentation
Re: portal xml documentation
Not really, but most are self explanatory once you know the RA a bit. Which ones do you need info on?
